remove some right click options
  1. #1
    dwolf Guest
    I installed a new version on Acdsee.. and now when I right click on a folder
    both version are still in the right click drop down.. I would like to get
    rid of the old one, and while I'm at it there are other options I would like
    to remove too.. for example winamp has 3 lines
  2. #2
    Don Varnau Guest
    Re: remove some right click options
    Context menu items can be removed by ediing the registry, see
    http://windowsxp.mvps.org/context_folders.htm Mistakes in registry editing
    can be hazardous to your system.
    ShellExView - free Shell Extension Manager For Windows:
    http://www.nirsoft.net/utils/shexview.html is a safe, easy wat to clean up
    the context menu.
    Don
    [MS MVP- IE]
    "dwolf" <jojonospam@xxxxxx> wrote in message
    news:utfHQ1idIHA.2268@xxxxxx
    folder
    like
  3. #3
    dwolf Guest
    I downloaded the shell program and Acdsee was not to be found on the list.
    Basically I want to remove this menu when right clicking on a folder. Winamp
    has 3 in the menu, but also not on the list.. I was able to remove them from
    within Winamp... but so far within Acdsee I can't remove the menu option
    "Don Varnau" <don_04[at]varnau[dot]org> wrote in message
    news:#R7wsWndIHA.5208@xxxxxx
    > Hi,
    > the context menu.
    > Hope this helps,
    > Don
    > [MS MVP- IE]
    > folder
    > like
  4. #4
    Don Varnau Guest
    Sorry, I lost track of this thread.
    It seems like ShellExView would have found it, but if the previous version
    of ACDSee was uninstalled, you might search the registry for the exact
    string (text) in the ACDSee context menu item. If found, backup the registry
    and delete the entry.
    If you decide to search for and remove the entry manually, be sure to backup
    the registry.
    Don
    [MS MVP- IE]
    news:eDas%23$ndIHA.4172@xxxxxx
    Winamp
    from
    > > Hi,
    editing
    up
    > > the context menu.
    > > folder
    get
    > > like
  5. #5
    dwolf Guest
    Thanks.. I will take a look
    news:uVFkimSeIHA.536@xxxxxx
    > registry
    > backup
    > the registry.
    > Don
    > [MS MVP- IE]
    >> list.
    > Winamp
    > from
    >> > Hi,
    > editing
    > up
    >> > the context menu.
    >> > folder
    > get
    >> >> would
    >> > like
remove some right click options problems?
Partition Management--How do you label Partitions via Disk Mgmt's Rt. Click to maximize options? Chad Harris Vista installation & setup 0 22 Apr 2009
Log On Shutdown Options - Remove or Restore Brink Tutorials 0 29 Aug 2008
Remove dual boot options Daniel Vista General 19 15 Oct 2007
No right-click options in IE7 Tim Vista General 2 28 Sep 2006
Right click options i IE7 are gone - bug ? Allan Knaap Vista General 1 19 Sep 2006
