Vista - stuck in system repair
Old 02-23-2008   #1 (permalink)
wpaul
i am trying to fix the sp1 reboot problem and have gotten stuck in the system
repair mode. any suggestions?
Old 02-23-2008   #2 (permalink)
TaurArian
Re: stuck in system repair
See if there's anything in the article to help -
The update is not installed successfully, you receive a message, and the computer restarts
when you try to install an update in Windows Vista
http://support.microsoft.com/kb/949358
TaurArian [MVP] 2005-2008 - Australia
How to ask a question: http://support.microsoft.com/kb/555375
http://taurarian.mvps.org/index.htm
Emails will not be acknowledged - please post to the newsgroup so all may benefit.
Computer Maintenance: Acronis / Diskeeper / Paragon / Raxco
"wpaul" <wpaul@xxxxxx> wrote in message
news:3F3D9236-AFA7-432E-AF25-237E9A719263@xxxxxx
Old 02-23-2008   #3 (permalink)
wpaul
None of those suggestions helped. I was trying the system restore when this
happened. Just trying to get it running enough to save some data and do a
system restore from the DVD
Old 02-23-2008   #4 (permalink)
John Barnes
system restore won't affect your data, but you could try doing the copies
from a command prompt on the DVD
news:0D16A719-2F3B-467C-B61D-BD9851EED171@xxxxxx
> this
>> computer restarts
>> benefit.
>> system
System Repair Problem :@ General Discussion
Stuck in Startup Repair w/o OS listed Vista installation & setup
Vista install problem - Now stuck on Startup Repair Vista installation & setup
Stuck in "Start Up Repair" mode Vista General
System Stuck in Loop on Both Reboot and System Restore Vista General
