| ultimate32 | start menu right pane Does any one know how to add a link to the right pane of the start menu? Thanks |
| | Re: start menu right pane right-click on the Start button, select Properties Start Menu Customize you can select from this list, but I don't think you can add your own shortcuts -- http://get.live.com/wlmail/overview "car54" <car54.35afxz@xxxxxx-mx.forums.net> wrote in message news:car54.35afxz@xxxxxx-mx.forums.net... Quote: > > Does any one know how to add a link to the right pane of the start menu? > > Thanks > > > -- > car54 |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: start menu right pane Hi car54, Welcome to Vista Forums. ![]() You can add or remove links from the available list of items to the right side of the Start menu. This will show you how. Start Menu - Customize However, you cannot add any of your own in Vista without using some 3rd party program like WindowsBlinds. Stardock WindowBlinds Hope this helps, Shawn |
| Start Menu Right Pane | Vista file management | |||
| Start Menu Right Pane | Vista General | |||
| START MENU RIGHT PANE LINK OR MENU OPTION | Vista General | |||
| Start Menu right pane | Vista General | |||
