| | ?Losing Internet Connection - Please help me I have a new computer with Windows Vista Home Edition. My computer is connected to a cable modem (Motorola SB5120). I'm constantly losing connection to the internet - All the lights in the modem stays on. When this happens, I have to right click on the network icon in the system tray (internet globe) to diagnose and repair. Windows suggests: 1) A problem with your network router or broadbent modem might be preveting an internet connection (requires to turn off the modem and unplug the power cord) 2) Automatic get new IP settings for the network adapter 3) Reset network adapter "Local Area Connection" I have tried option 1 and 3, but the problem continues. I had the same problem with my old windows XP computer. Is this problem created by the modem? Should I replace the modem (which is only 1 yr old) Any suggestions. RReis |
| | Re: ?Losing Internet Connection - Please help me Start a Command Prompt, and type: IPCONFIG Your "Default Gateway" is the IP of the modem. When it fails, use the prompt to run the command: ping 192.168.0.1 (or whatever your default gateway happens to be) Usually, if you go to that site with IE (e. g. http://192.168.0.1) you may get a report on the modems connectivity at the moment. -- Was this helpful? Then click the "Yes" Ratings button. Voting helps the web interface. http://www.microsoft.com/wn3/locales....htm#RateAPost Mark L. Ferguson .. "RReis" <RReis@xxxxxx> wrote in message news:ECA5E752-03DE-448A-99B0-9AFAE0B59368@xxxxxx Quote: >I have a new computer with Windows Vista Home Edition. My computer is > connected to a cable modem (Motorola SB5120). I'm constantly losing > connection to the internet - All the lights in the modem stays on. > > When this happens, I have to right click on the network icon in the system > tray (internet globe) to diagnose and repair. > Windows suggests: > 1) A problem with your network router or broadbent modem might be > preveting > an internet connection (requires to turn off the modem and unplug the > power > cord) > 2) Automatic get new IP settings for the network adapter > 3) Reset network adapter "Local Area Connection" > > I have tried option 1 and 3, but the problem continues. > > I had the same problem with my old windows XP computer. > > Is this problem created by the modem? Should I replace the modem (which > is > only 1 yr old) > > Any suggestions. > > RReis > |
| | Re: ?Losing Internet Connection - Please help me Since you had the same problem with your other computer I would suggest the problem is your modem or an issue with your ISP. "RReis" <RReis@xxxxxx> wrote in message news:ECA5E752-03DE-448A-99B0-9AFAE0B59368@xxxxxx Quote: >I have a new computer with Windows Vista Home Edition. My computer is > connected to a cable modem (Motorola SB5120). I'm constantly losing > connection to the internet - All the lights in the modem stays on. > > When this happens, I have to right click on the network icon in the system > tray (internet globe) to diagnose and repair. > Windows suggests: > 1) A problem with your network router or broadbent modem might be > preveting > an internet connection (requires to turn off the modem and unplug the > power > cord) > 2) Automatic get new IP settings for the network adapter > 3) Reset network adapter "Local Area Connection" > > I have tried option 1 and 3, but the problem continues. > > I had the same problem with my old windows XP computer. > > Is this problem created by the modem? Should I replace the modem (which > is > only 1 yr old) > > Any suggestions. > > RReis > |
| Vista Ultimate 32bit | Re: ?Losing Internet Connection - Please help me I found this post when I was searching for this problem. I have Vista Ultimate 32bit with wireless internet and I am having the same problem. It keeps dropping the connection. 9 out of 10 times it tells me to reset my adapter and that fixes the problem. But occasionally it will tell me that the problem could not be fixed and then I have to reboot. Any ideas would be greatly appreciated. |
| Keep on Losing Wireless Internet Connection | Vista General | |||
| Keep losing Internet connection | Vista networking & sharing | |||
| Keep losing Internet Explorer connection | Vista networking & sharing | |||
| losing internet connection | Vista networking & sharing | |||
