Vista Tutorial - Home Basic to Home Premium (Without Upgrade Anytime DVD)
Old 02-24-2008   #1 (permalink)
Boomstick
Guest
I'd like to upgrade my PC from Vista Home Basic to Home Premium but the
Ugrade Anytime thingy on my control pannel says I need an Upgrade Anytime
DVD-Rom "that came with the PC", well my PC didn't come with an Upgrade
Anytime DVD-Rom, so how am I suposed to update my PC?
If there's no way about this then I'd like to know is it possible to get
Windows Media Center on Vista Home Basic, if so, how?
Old 02-24-2008   #2 (permalink)
Mark L. Ferguson
Guest
Re: Home Basic to Home Premium (Without Upgrade Anytime DVD)
The start orb/all programs/Extras and upgrades/Windows Anytime Upgrade
takes you to a site that will let you walk through the buying process, but
stop before buying if you choose. There it explains that if you need a disk,
they will send it.
Was this helpful? Then click the "Yes" Ratings button. Voting helps the web
interface.
http://www.microsoft.com/wn3/locales....htm#RateAPost
Mark L. Ferguson
"Boomstick" <Boomstick@xxxxxx> wrote in message
news:AA3337DF-A296-4864-8C0A-8D28569298FE@xxxxxx
Old 02-24-2008   #3 (permalink)
Rick Rogers
Guest
You can order the disk for a nominal fee here:
http://www.windowsmarketplace.com/content.aspx?ctId=404
Or copy a friend's. You can't get/install/use Windows Media Center on Home
Basic.
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Windows help - www.rickrogers.org
My thoughts http://rick-mvp.blogspot.com
Old 02-25-2008   #4 (permalink)
Boomstick
Guest
"Rick Rogers" wrote:
Quote:
> Hi,
> Basic.
> Best of Luck,
I tryed that but it's an American site, I live in the UK and I can't find a
UK marketplace.
how to upgrade from Vista Home Basic to Home Premium? Vista General
Re: Anytime Upgrade from Vista Home Basic to Home Premium Vista installation & setup
Upgrade from Vista Home Basic to Home Premium Vista General
Upgrade from Home Basic to Home Premium question. Vista installation & setup
Problems after upgrade from home basic to home premium Vista General
