Tech,
First off there is no WMI Performance Adapter.
In the Event Log I see numerous events fot Source WMI, log Name:
Application. the Event ID = 63, also Event ID = 5617.
A provider, WmiPerfClass, has been registered in the Windows Management
Instrumentation namespace root\cimv2 to use the LocalSystem account. This
account is privileged and the provider may cause a security violation if it
does not correctly impersonate user requests.
Not sure what all these event id's are but I don't see anything out of the
ordinary..... Any further help would be appreciated....
Thanks,
Bob
"Technologist" wrote:
> Tell me the status of "WMI Performance Adapter" under services.
> Click "Start(Orb)", Right Click "Computer", then "Manage", then
> "Services and Applications" then "Services" to find it.
> Also check your event log while you are in there. Look for any WMI
> problems under the "Application" or "System" logs.
> --t
> Technologist
> Posted via http://ms-os.com Forum to Usenet gateway
