Vista - Random Vista Shutdowns : Help - Running Out of Patience
Old 02-26-2008   #1 (permalink)
Morgan
Hi
I have posted before but solutions haven't worked. I have Vista Home Premium
running on a Dell Inspiron 1520. The machine shuts down randomly - though it
seems using YouTube brings on the problem it isn't just on YouTube and is
unpredictable.
The problem centre had identified a conflict with virus software. I had
McAfee, changed to Norton and at the suggestion here removed virus protection
completely and ran Windows firewall with Spybot. I don't seem to have the
conflict anymore but PC still fails.
I have also run every available update for Windows and Intel graphic card. I
also noticed that other errors were in the log including Windows Module
Installer and Superfetch stopping working (whatever that is).
I have also run every type of diagnostic including scandisk, defrag (even
though a new machine) and scannow. There were corrupted files in the scannow
but I can't interpret the file.
Final resort - I checked the battery wasn't loose just in case it was a
loose connection.
If anyone has had a similar experience or has suggestions for me to try or
some resource I should try I would really appreciate it.
Many thanks
Old 02-26-2008   #2 (permalink)
R. McCarty
Re: Random Vista Shutdowns : Help - Running Out of Patience
Abrupt shut off can be a sign of a Thermal issue. Unfortunately, Dell
doesn't
always apply the correct amount of Thermal paste to the processor's heat
dissipater. The 1520 has Core 2 Duo so it shouldn't get too hot. However
it's never a bad thing to use a resident monitor program like SpeedFan 4.33.
Heat could also be from the nVidia card, since many Video GPUs now have
more transistors than some processors.
"Morgan" <Morgan@xxxxxx> wrote in message
news:166EAC4F-CEBC-4BC8-A21E-C4E52CE6D93A@xxxxxx
Quote:
> Hi
> Premium
> it
> unpredictable.
> protection
> I
> scannow
> loose connection.
> Many thanks
Old 02-26-2008   #3 (permalink)
Steve Easton
Sounds like a classic case of an overheating CPU.
When a CPU reaches it's max temp limit, the machine will
behave just like someone pulled the plug.
There will be no errors logged about it because the CPU simply stops.
A memory error would cause a reboot, CPU overheat simply shuts down the machine.
Steve Easton
Quote:
> Hi
> unpredictable.
> loose connection.
> Many thanks
Old 02-26-2008   #4 (permalink)
Morgan
Thanks - I was wondering if something physical was going on.
Is there a solution to something like this or is it a case of returning to
Dell
> Steve Easton
Quote:
> > Hi
> > unpredictable.
> > loose connection.
> > Many thanks
Old 02-26-2008   #5 (permalink)
ineptgeek
>Dell
>[quoted text clipped - 30 lines]
Quote:
Quote:
>> > Many thanks
don't know if this will help but i had the same problem until three days ago
when i upgraded my memory and video card... check compatability on these at
microsoft
Normal Shutdowns show up as Disruptive Shutdowns General Discussion
Patience running thin Network & Sharing
random blue screen shutdowns Vista performance & maintenance
Patience and persaverence Vista installation & setup
Patience Vista General
