| | Problem with Vista waking up from sleep I just upgraded my video card to an Nvidia BFG 8800GT and because I had a 350W power supply I thought I should also upgrade the power supply. So I put in a BFG 650W power supply. I had an 8600GT card before. Anyway my sytem will go into sleep mode after about 20 minuets, which is fine, but I used to be able to move the mouse first thing in the morning and my unit would wake up and I would login and everything was fine. Now once it goes to sleep I can not wake it up. I have to turn the power switch off on the back of the power supply and then when Vista boots up it says do you want to boot into safe mode. I have a wireless keyboard and mouse. I sent an email to BFG and their response was to update my BIOS, but I have the latest BIOS and it worked before. Any suggestions would be greatly appreciated. I am thinking that it may just be the power supply and I might have to take it back and try another brand. THANKS! |
| | Re: Problem with Vista waking up from sleep Go to Advance Power Settings. Set hard drive to turn off a minute or 2 before sleep. Set Hybrid and Hibernate modes to "Never" Under USB settings select "Disable" Under Multimedia select "Allow ....." "BLinAZ" <BLinAZ@xxxxxx> wrote in message news:911997AB-8955-484B-B814-7247ACA7BBF1@xxxxxx Quote: >I just upgraded my video card to an Nvidia BFG 8800GT and because I had a > 350W power supply I thought I should also upgrade the power supply. So I > put > in a BFG 650W power supply. I had an 8600GT card before. Anyway my sytem > will go into sleep mode after about 20 minuets, which is fine, but I used > to > be able to move the mouse first thing in the morning and my unit would > wake > up and I would login and everything was fine. Now once it goes to sleep I > can not wake it up. I have to turn the power switch off on the back of > the > power supply and then when Vista boots up it says do you want to boot > into > safe mode. I have a wireless keyboard and mouse. I sent an email to BFG > and > their response was to update my BIOS, but I have the latest BIOS and it > worked before. Any suggestions would be greatly appreciated. I am > thinking > that it may just be the power supply and I might have to take it back and > try > another brand. THANKS! |
| | Re: Problem with Vista waking up from sleep Tried this but still won't wake up. I see the blue power light on the back of the computer flash when I move the mouse, but the computer does not wake up. I still have to turn the power switch off on the back of the power supply. I did not see the Set Hybrid and Hibernate modes in the Advanced Settings? Thanks! "Bob" wrote: Quote: > Go to Advance Power Settings. > Set hard drive to turn off a minute or 2 before sleep. > Set Hybrid and Hibernate modes to "Never" > Under USB settings select "Disable" > Under Multimedia select "Allow ....." > > "BLinAZ" <BLinAZ@xxxxxx> wrote in message > news:911997AB-8955-484B-B814-7247ACA7BBF1@xxxxxx Quote: > >I just upgraded my video card to an Nvidia BFG 8800GT and because I had a > > 350W power supply I thought I should also upgrade the power supply. So I > > put > > in a BFG 650W power supply. I had an 8600GT card before. Anyway my sytem > > will go into sleep mode after about 20 minuets, which is fine, but I used > > to > > be able to move the mouse first thing in the morning and my unit would > > wake > > up and I would login and everything was fine. Now once it goes to sleep I > > can not wake it up. I have to turn the power switch off on the back of > > the > > power supply and then when Vista boots up it says do you want to boot > > into > > safe mode. I have a wireless keyboard and mouse. I sent an email to BFG > > and > > their response was to update my BIOS, but I have the latest BIOS and it > > worked before. Any suggestions would be greatly appreciated. I am > > thinking > > that it may just be the power supply and I might have to take it back and > > try > > another brand. THANKS! > |
| | Re: Problem with Vista waking up from sleep You'll find hibernate mode if you expand "Sleep". "BLinAZ" <BLinAZ@xxxxxx> wrote in message news:BAC9548C-6A80-49F2-8142-9D488D9534B6@xxxxxx Quote: > Tried this but still won't wake up. I see the blue power light on the > back > of the computer flash when I move the mouse, but the computer does not > wake > up. I still have to turn the power switch off on the back of the power > supply. I did not see the Set Hybrid and Hibernate modes in the Advanced > Settings? Thanks! > > "Bob" wrote: > Quote: >> Go to Advance Power Settings. >> Set hard drive to turn off a minute or 2 before sleep. >> Set Hybrid and Hibernate modes to "Never" >> Under USB settings select "Disable" >> Under Multimedia select "Allow ....." >> >> "BLinAZ" <BLinAZ@xxxxxx> wrote in message >> news:911997AB-8955-484B-B814-7247ACA7BBF1@xxxxxx Quote: >> >I just upgraded my video card to an Nvidia BFG 8800GT and because I had >> >a >> > 350W power supply I thought I should also upgrade the power supply. So >> > I >> > put >> > in a BFG 650W power supply. I had an 8600GT card before. Anyway my >> > sytem >> > will go into sleep mode after about 20 minuets, which is fine, but I >> > used >> > to >> > be able to move the mouse first thing in the morning and my unit would >> > wake >> > up and I would login and everything was fine. Now once it goes to >> > sleep I >> > can not wake it up. I have to turn the power switch off on the back of >> > the >> > power supply and then when Vista boots up it says do you want to boot >> > into >> > safe mode. I have a wireless keyboard and mouse. I sent an email to >> > BFG >> > and >> > their response was to update my BIOS, but I have the latest BIOS and it >> > worked before. Any suggestions would be greatly appreciated. I am >> > thinking >> > that it may just be the power supply and I might have to take it back >> > and >> > try >> > another brand. THANKS! >> |
| Vista crashes when waking up from hibernate/sleep | Vista performance & maintenance | |||
| vista sleep waking up for no apparent reason | General Discussion | |||
| vista waking itself up out of sleep | Vista performance & maintenance | |||
| Problem with Outlook after waking up from Sleep mode | Vista General | |||
| Vista RC1 MCE - No sound recorded when waking from sleep | Vista music pictures video | |||
