| | System hanging and unable to start in "safe" mode - FUBAR Hi, Running Vista Home Premium on a Dell laptoop. When I turned on yesterday evening, Windows looked like it was starting up ok ("Resuming Windows") except that instead of the normal screen where you pick your user to login, the screen just had my son's background picture. The mouse worked ok but there was no icons or anyway of progressing. I thought maybe my kids had left too many sessions logged in - which I have noticed almost hangs the PC before. Tried "ctrl alt del" to log out users but no reaction. In fact no matter what I did, the stupid Ferrari picture remained. Assuming some download may have caused this, I thought I would start in safe mode and look to either uninstall or restore to a previous backup point. When I manually turned off and on and held F8 on reboot, I just came back to the same screen. I was however able to use the F2 and F12 keys on reboot to access system setup etc. I also tried rebooting with the system disk in the drive - but again got the stupid picture (sensing my frustration here? Gone right off Ferraris) The last thing I am aware of that was downloaded was an adobe flash update. However the PC was rebooted once after that and worked. If anyone has any sort of suggestion I would be most grateful. The only thing I can think of now is to put my sons fingers in a vice but not sure that will solve my PC issue (though it may reduce my frustration level) |
| | RE: System hanging and unable to start in "safe" mode - FUBAR 1. Right when you power on the computer start tapping the F8 Key to get to list including Safe Mode; don't hold F8 down, tap it! Start>Programs>Accessories>System Tools>System Restore. Also, look on your keyboard and make sure there is not an F Lock Key in use! You have the proper Vista DVD, not Dell recovery disks? If 1 does not work, alter your boot order to make the CD/DVD drive 1st in the boot order; put disk in drive, reboot, and do a startup repair and/or a system restore Cheers! -- Mick Murphy - Qld - Australia "Morgan" wrote: Quote: > Hi, > > Running Vista Home Premium on a Dell laptoop. When I turned on yesterday > evening, Windows looked like it was starting up ok ("Resuming Windows") > except that instead of the normal screen where you pick your user to login, > the screen just had my son's background picture. The mouse worked ok but > there was no icons or anyway of progressing. I thought maybe my kids had left > too many sessions logged in - which I have noticed almost hangs the PC > before. Tried "ctrl alt del" to log out users but no reaction. In fact no > matter what I did, the stupid Ferrari picture remained. > > Assuming some download may have caused this, I thought I would start in safe > mode and look to either uninstall or restore to a previous backup point. When > I manually turned off and on and held F8 on reboot, I just came back to the > same screen. I was however able to use the F2 and F12 keys on reboot to > access system setup etc. I also tried rebooting with the system disk in the > drive - but again got the stupid picture (sensing my frustration here? Gone > right off Ferraris) > > The last thing I am aware of that was downloaded was an adobe flash update. > However the PC was rebooted once after that and worked. > > If anyone has any sort of suggestion I would be most grateful. The only > thing I can think of now is to put my sons fingers in a vice but not sure > that will solve my PC issue (though it may reduce my frustration level) > |
| | RE: System hanging and unable to start in "safe" mode - FUBAR OK Had been holding down F8 - will try. Yes I do have the proper Vista DVD but just realised about the boot order - stupid but by the time I was trying that I may have lost reason and logic :-) Appreciate the suggestions Morgan "Mick Murphy" wrote: Quote: > 1. Right when you power on the computer start tapping the F8 Key to get to > list including Safe Mode; don't hold F8 down, tap it! > > Start>Programs>Accessories>System Tools>System Restore. > > Also, look on your keyboard and make sure there is not an F Lock Key in use! > > You have the proper Vista DVD, not Dell recovery disks? > > If 1 does not work, alter your boot order to make the CD/DVD drive 1st in > the boot order; put disk in drive, reboot, and do a startup repair and/or a > system restore > > Cheers! > -- > Mick Murphy - Qld - Australia > > > "Morgan" wrote: > Quote: > > Hi, > > > > Running Vista Home Premium on a Dell laptoop. When I turned on yesterday > > evening, Windows looked like it was starting up ok ("Resuming Windows") > > except that instead of the normal screen where you pick your user to login, > > the screen just had my son's background picture. The mouse worked ok but > > there was no icons or anyway of progressing. I thought maybe my kids had left > > too many sessions logged in - which I have noticed almost hangs the PC > > before. Tried "ctrl alt del" to log out users but no reaction. In fact no > > matter what I did, the stupid Ferrari picture remained. > > > > Assuming some download may have caused this, I thought I would start in safe > > mode and look to either uninstall or restore to a previous backup point. When > > I manually turned off and on and held F8 on reboot, I just came back to the > > same screen. I was however able to use the F2 and F12 keys on reboot to > > access system setup etc. I also tried rebooting with the system disk in the > > drive - but again got the stupid picture (sensing my frustration here? Gone > > right off Ferraris) > > > > The last thing I am aware of that was downloaded was an adobe flash update. > > However the PC was rebooted once after that and worked. > > > > If anyone has any sort of suggestion I would be most grateful. The only > > thing I can think of now is to put my sons fingers in a vice but not sure > > that will solve my PC issue (though it may reduce my frustration level) > > |
| | Re: System hanging and unable to start in "safe" mode - FUBAR I would also suggest either System Restore or taking the "diagnose common problems" option when you boot from the Vista CD. Holding the F8 key doesn't work because it takes it as a single keystroke, which gets dumped from the buffer right before it goes to check for the F8 key being pressed. If you tap it one every second or so, starting at the Dell splash screen, you are almost sure to get into it. Unfortunately, it only gives you about 2 seconds to hit the key from the time it asks before it moves on and tries to boot normally. By the way, Dell operating system disks are always "full" Windows disks and not recovery CDs. We do have Software Recovery CD (SRCD) sets, but they are special built to reinstall the factory image for a specific individual system and are not an option when ordering the computer. Normally, SRCDs are sent out when tech support determines the OS needs to be reinstalled but the PC Restore (aka Image Restore) partition doesn't work for whatever reason, but the hard drive itself is not the problem. If a customer does not have the Windows CD itself, tech support can easily send it out, assuming we still have the correct version in stock (e.g., we can't send out WinME CDs any more because we literally don't have them). Larry Dell Customer Advocate Morgan;3562292 Wrote: Quote: > OK > > Had been holding down F8 - will try. Yes I do have the proper Vista DVD > but > just realised about the boot order - stupid but by the time I was > trying that > I may have lost reason and logic :-) > > Appreciate the suggestions > > Morgan > > > "Mick Murphy" wrote: > Quote: > > 1. Right when you power on the computer start tapping the F8 Key to Quote: > > list including Safe Mode; don't hold F8 down, tap it! > > > > Start>Programs>Accessories>System Tools>System Restore. > > > > Also, look on your keyboard and make sure there is not an F Lock Key Quote: > > > > You have the proper Vista DVD, not Dell recovery disks? > > > > If 1 does not work, alter your boot order to make the CD/DVD drive Quote: > > the boot order; put disk in drive, reboot, and do a startup repair Quote: > > system restore > > > > Cheers! > > -- > > Mick Murphy - Qld - Australia > > > > > > "Morgan" wrote: > > Quote: > > > Hi, > > > > > > Running Vista Home Premium on a Dell laptoop. When I turned on Quote: Quote: > > > evening, Windows looked like it was starting up ok ("Resuming Quote: Quote: > > > except that instead of the normal screen where you pick your user Quote: Quote: > > > the screen just had my son's background picture. The mouse worked Quote: Quote: > > > there was no icons or anyway of progressing. I thought maybe my Quote: Quote: > > > too many sessions logged in - which I have noticed almost hangs the Quote: Quote: > > > before. Tried "ctrl alt del" to log out users but no reaction. In Quote: Quote: > > > matter what I did, the stupid Ferrari picture remained. > > > > > > Assuming some download may have caused this, I thought I would Quote: Quote: > > > mode and look to either uninstall or restore to a previous backup Quote: Quote: > > > I manually turned off and on and held F8 on reboot, I just came Quote: Quote: > > > same screen. I was however able to use the F2 and F12 keys on Quote: Quote: > > > access system setup etc. I also tried rebooting with the system Quote: Quote: > > > drive - but again got the stupid picture (sensing my frustration Quote: Quote: > > > right off Ferraris) > > > > > > The last thing I am aware of that was downloaded was an adobe flash Quote: Quote: > > > However the PC was rebooted once after that and worked. > > > > > > If anyone has any sort of suggestion I would be most grateful. The Quote: Quote: > > > thing I can think of now is to put my sons fingers in a vice but Quote: Quote: > > > that will solve my PC issue (though it may reduce my frustration Quote: Quote: > > > -- DellCA ------------------------------------------------------------------------ DellCA's Profile: http://forums.techarena.in/member.php?userid=20193 View this thread: http://forums.techarena.in/showthread.php?t=922706 http://forums.techarena.in |
| | RE: System hanging and unable to start in "safe" mode - FUBAR Mick, You are a gentleman - I hope something good happens to you in this life.... can you tell your suggestion worked :-) Appreciate the help. Many thanks Morgan "Mick Murphy" wrote: Quote: > 1. Right when you power on the computer start tapping the F8 Key to get to > list including Safe Mode; don't hold F8 down, tap it! > > Start>Programs>Accessories>System Tools>System Restore. > > Also, look on your keyboard and make sure there is not an F Lock Key in use! > > You have the proper Vista DVD, not Dell recovery disks? > > If 1 does not work, alter your boot order to make the CD/DVD drive 1st in > the boot order; put disk in drive, reboot, and do a startup repair and/or a > system restore > > Cheers! > -- > Mick Murphy - Qld - Australia > > > "Morgan" wrote: > Quote: > > Hi, > > > > Running Vista Home Premium on a Dell laptoop. When I turned on yesterday > > evening, Windows looked like it was starting up ok ("Resuming Windows") > > except that instead of the normal screen where you pick your user to login, > > the screen just had my son's background picture. The mouse worked ok but > > there was no icons or anyway of progressing. I thought maybe my kids had left > > too many sessions logged in - which I have noticed almost hangs the PC > > before. Tried "ctrl alt del" to log out users but no reaction. In fact no > > matter what I did, the stupid Ferrari picture remained. > > > > Assuming some download may have caused this, I thought I would start in safe > > mode and look to either uninstall or restore to a previous backup point. When > > I manually turned off and on and held F8 on reboot, I just came back to the > > same screen. I was however able to use the F2 and F12 keys on reboot to > > access system setup etc. I also tried rebooting with the system disk in the > > drive - but again got the stupid picture (sensing my frustration here? Gone > > right off Ferraris) > > > > The last thing I am aware of that was downloaded was an adobe flash update. > > However the PC was rebooted once after that and worked. > > > > If anyone has any sort of suggestion I would be most grateful. The only > > thing I can think of now is to put my sons fingers in a vice but not sure > > that will solve my PC issue (though it may reduce my frustration level) > > |
| | #6 (permalink) |
| | Re: System hanging and unable to start in "safe" mode - FUBAR Thanks DellCA Actually while I have a dell person - I have an inspiron with problems as well - seperate laptop (yep - really having a good time). It shuts down at random intervals and after chasing my tail on software, ran a program monitoring chip temperature. They were regularly getting into the mid 50's C and then the PC would fall over. You don't happen to know where the temp should be (think it is in 40-50 range). Looks like I have a hardware problem. Thanks Morgan "DellCA" wrote: Quote: > > I would also suggest either System Restore or taking the "diagnose > common problems" option when you boot from the Vista CD. > > Holding the F8 key doesn't work because it takes it as a single > keystroke, which gets dumped from the buffer right before it goes to > check for the F8 key being pressed. If you tap it one every second or > so, starting at the Dell splash screen, you are almost sure to get into > it. Unfortunately, it only gives you about 2 seconds to hit the key > from the time it asks before it moves on and tries to boot normally. > > By the way, Dell operating system disks are always "full" Windows disks > and not recovery CDs. We do have Software Recovery CD (SRCD) sets, but > they are special built to reinstall the factory image for a specific > individual system and are not an option when ordering the computer. > Normally, SRCDs are sent out when tech support determines the OS needs > to be reinstalled but the PC Restore (aka Image Restore) partition > doesn't work for whatever reason, but the hard drive itself is not the > problem. If a customer does not have the Windows CD itself, tech > support can easily send it out, assuming we still have the correct > version in stock (e.g., we can't send out WinME CDs any more because we > literally don't have them). > > Larry > Dell Customer Advocate > > Morgan;3562292 Wrote: Quote: > > OK > > > > Had been holding down F8 - will try. Yes I do have the proper Vista DVD > > but > > just realised about the boot order - stupid but by the time I was > > trying that > > I may have lost reason and logic :-) > > > > Appreciate the suggestions > > > > Morgan > > > > > > "Mick Murphy" wrote: > > Quote: > > > 1. Right when you power on the computer start tapping the F8 Key to Quote: > > > list including Safe Mode; don't hold F8 down, tap it! > > > > > > Start>Programs>Accessories>System Tools>System Restore. > > > > > > Also, look on your keyboard and make sure there is not an F Lock Key Quote: > > > > > > You have the proper Vista DVD, not Dell recovery disks? > > > > > > If 1 does not work, alter your boot order to make the CD/DVD drive Quote: > > > the boot order; put disk in drive, reboot, and do a startup repair Quote: > > > system restore > > > > > > Cheers! > > > -- > > > Mick Murphy - Qld - Australia > > > > > > > > > "Morgan" wrote: > > > > > > > Hi, > > > > > > > > Running Vista Home Premium on a Dell laptoop. When I turned on Quote: > > > > evening, Windows looked like it was starting up ok ("Resuming Quote: > > > > except that instead of the normal screen where you pick your user Quote: > > > > the screen just had my son's background picture. The mouse worked Quote: > > > > there was no icons or anyway of progressing. I thought maybe my Quote: > > > > too many sessions logged in - which I have noticed almost hangs the Quote: > > > > before. Tried "ctrl alt del" to log out users but no reaction. In Quote: > > > > matter what I did, the stupid Ferrari picture remained. > > > > > > > > Assuming some download may have caused this, I thought I would Quote: > > > > mode and look to either uninstall or restore to a previous backup Quote: > > > > I manually turned off and on and held F8 on reboot, I just came Quote: > > > > same screen. I was however able to use the F2 and F12 keys on Quote: > > > > access system setup etc. I also tried rebooting with the system Quote: > > > > drive - but again got the stupid picture (sensing my frustration Quote: > > > > right off Ferraris) > > > > > > > > The last thing I am aware of that was downloaded was an adobe flash Quote: > > > > However the PC was rebooted once after that and worked. > > > > > > > > If anyone has any sort of suggestion I would be most grateful. The Quote: > > > > thing I can think of now is to put my sons fingers in a vice but Quote: > > > > that will solve my PC issue (though it may reduce my frustration Quote: > > > > > > -- > DellCA > ------------------------------------------------------------------------ > DellCA's Profile: http://forums.techarena.in/member.php?userid=20193 > View this thread: http://forums.techarena.in/showthread.php?t=922706 > > http://forums.techarena.in > > |
| | #7 (permalink) |
| | Re: System hanging and unable to start in "safe" mode - FUBAR Morgan;3563400 Wrote: Quote: > Thanks DellCA > > Actually while I have a dell person - I have an inspiron with problems > as > well - seperate laptop (yep - really having a good time). It shuts down > at > random intervals and after chasing my tail on software, ran a program > monitoring chip temperature. They were regularly getting into the mid > 50's C > and then the PC would fall over. > > You don't happen to know where the temp should be (think it is in > 40-50 > range). Looks like I have a hardware problem. > > Thanks > Morgan are using I can't list any specifics. However, if it is shutting down due to heat then the first things I would check are: 1) Are the fans spinning? 2) Is air coming out of the air vents? 3) Is there anything in or on the air vents that could be blocking airflow? Checking those three things will usually fix most overheating problems. You can check the fans using the Dell Diagnostics program, or the i8k fan utility (not a Dell application, but useful for checking the fans). If you wish to be really thorough, you can open up the system to make sure there isn't any dust on the heatsink assembly for the CPU as that could also be preventing proper heat transfer away. The service manual for all of the Dell computers is available from the support website (http://support.dell.com) and has instructions for opening up the computer and removing parts. That would show you what is needed to get to the fans and/or heatsink on your Inspiron to clean them. If you have other questions on the system I'll be happy to help. Larry Dell Customer Advocate -- DellCA ------------------------------------------------------------------------ DellCA's Profile: http://forums.techarena.in/member.php?userid=20193 View this thread: http://forums.techarena.in/showthread.php?t=922706 http://forums.techarena.in |
| Monitor shows "out of range" when using safe mode | Vista General | |||
| Subject: Vista question about "compatibility mode" and "safe mode" | Vista General | |||
| Transferring files in "safe" mode | Vista hardware & devices | |||
| Safe to stay in "Test Mode"? | Vista General | |||
| Need to delete \csc Folder, "Access Denied" even in safe mode | Vista General | |||
