Vista - Vista print screen help
Old 02-29-2008   #1 (permalink)
KSnow
I've always used print screen or alt-print screen to do screen/window
captures but it's never worked with Vista. Is there some feature that I need
to turn on/off? Help is appreciated. Thanks.
Old 02-29-2008   #2 (permalink)
Bob
Re: Vista print screen help
How to use the Windows Vista Snipping Tool
http://www.bleepingcomputer.com/tuto...torial135.html
"KSnow" <KSnow@xxxxxx> wrote in message
news:88C84DB5-4C8B-4303-B659-68E347918FB0@xxxxxx
> need
Old 02-29-2008   #3 (permalink)
SG
IMO, a better program than Vista's Snipping Tool is
http://www.mirekw.com/winfreeware/mwsnap.html
MWSnap does not require installation and does not need any special dlls,
drivers or system files.
All the best,
SG
ALEX NICHOL
(1935-2005)
http://www.aumha.org/alex.htm
You will never be forgotten my friend
> need
Old 02-29-2008   #4 (permalink)
John Barnes
Don't know where you are coming from but since Windows98 you have had to
paste to another program then print. Many use the paint program in
accessories.
> need
Old 02-29-2008   #5 (permalink)
Windows 95
well
How to print screen on a keyboard without print screen button? .NET General
Print Screen using Vista .NET General
Screen print vista Vista General
can't print screen with vista Vista General
Vista screen print Vista General
