| | Problem accessing network Folder My Vista machine has trouble accessing a folder on my file server. This only started to occur recently. When I try to access the folder, I can see the files (with grey crosses over the icons), but when I try to open them the message "\\server\user\thys\my documents\*.doc is not accesible. You might not have permission to use this network resource..... This file is currently not available for use on this computer." I can access other files in other folders on this server. Reboot does not help. When I would restore to a previous restore point, it fixed the problem. Once when I did not wnat to restore futhther, I cancelled the previous restore, and the problem was also resolved. I can access the folder from any other PC. Any suggestions? Please help! |
| | Re: Problem accessing network Folder I edited the message: My Vista machine has trouble accessing a folder on my file server. This only started to occur recently. When I try to access the folder, I can see the files (with grey crosses over the icons), but when I try to open them this message appears: "\\server\user\thys\my documents\*.doc is not accesible. You might not have permission to use this network resource..... This file is currently not available for use on this computer." I can access other files in other folders on this server. Reboot does not help. When I would restore to a previous restore point, it fixed the problem. Once when I did not want to restore beyond the last restore point, I cancelled the previous restore, and the problem was also resolved. I can access the folder from any other PC. Any suggestions? Please help! |
| | Re: Problem accessing network Folder You may want to try these two mods on the Vista box thats not accessing the server: 1. Go into Command prompt as Administrator and run net localgroup "Administrators" "NT Authority\Local Service" /add 2. In regedit, navigate to: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Lsa Modify or create DWORD value named LmCompatibilityLevel Set value to 1 Exit and Reboot "Thys" wrote: Quote: > I edited the message: > > My Vista machine has trouble accessing a folder on my file server. This only > started to occur recently. When I try to access the folder, I can see the > files (with grey crosses over the icons), but when I try to open them this > message appears: "\\server\user\thys\my documents\*.doc is not accesible. > You might > not have permission to use this network resource..... This file is currently > not available for use on this computer." > > I can access other files in other folders on this server. > > Reboot does not help. > > When I would restore to a previous restore point, it fixed the problem. > Once when I did not want to restore beyond the last restore point, I > cancelled the previous > restore, and the problem was also resolved. > > I can access the folder from any other PC. > > Any suggestions? Please help! > |
| | Re: Problem accessing network Folder Thanks for your help. the solution didn't work though. Immediately after I installed the latest update (Office SP1), i was denied access to the folder again (\\server\users\). in the meantime, on the server, I shared the subfolder that I really need to work from (\\server\users\thys). I have no problem in accessing that share now! I no too little about permissions and shares on how to find out what the problem is. But at least this works! Thanks again "microsvc" wrote: Quote: > You may want to try these two mods on the Vista box thats not accessing the > server: > > 1. Go into Command prompt as Administrator and run > net localgroup "Administrators" "NT Authority\Local Service" /add > > 2. In regedit, navigate to: > HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Lsa > Modify or create DWORD value named LmCompatibilityLevel > Set value to 1 > Exit and Reboot > > "Thys" wrote: > Quote: > > I edited the message: > > > > My Vista machine has trouble accessing a folder on my file server. This only > > started to occur recently. When I try to access the folder, I can see the > > files (with grey crosses over the icons), but when I try to open them this > > message appears: "\\server\user\thys\my documents\*.doc is not accesible. > > You might > > not have permission to use this network resource..... This file is currently > > not available for use on this computer." > > > > I can access other files in other folders on this server. > > > > Reboot does not help. > > > > When I would restore to a previous restore point, it fixed the problem. > > Once when I did not want to restore beyond the last restore point, I > > cancelled the previous > > restore, and the problem was also resolved. > > > > I can access the folder from any other PC. > > > > Any suggestions? Please help! > > |
| Problem accessing a shared folder | Vista networking & sharing | |||
| Problem accessing network shares | Vista networking & sharing | |||
| problem accessing wireless network | Vista networking & sharing | |||
| Trouble accessing network folder | Vista networking & sharing | |||
| Blue screen when accessing a network folder or subst/mapdrive. | Vista General | |||
