Vista Forums Home Join Vista Forums Windows 7 help and support Forum Windows 8 Forum Vista Tutorials
Go Back   Vista Forums > Vista Newsgroup Archive > Vista Newsgroups > Vista General
Vista - pxhelp20.sys Problem on Vista
08-15-2006   #1 (permalink)
=?Utf-8?B?SnVzdGlu?=
Hello:
Help! Please? :-)
I did a bad thing. Despite the incompatibility warnings, I installed Sonic
RecordNow Deluxe. When I uninstalled it. I get the error on boot that
pxhelp20.sys is corrupt or missing. Start up repair is unable to repair the
system. The only way to fix the problem is to use System Restore to bring the
system back to the state when Sonic was installed.
Can someone who is knowledgeable please help me to troubleshoot this
problem. I think I should remove RecordNow, but if I do there are problems.
If I don't, there are little quirks now with accessing the CD/DVD drive.
Many thanks
Justin
08-15-2006   #2 (permalink)
Mark D. VandenBeg
Re: pxhelp20.sys Problem on Vista
Have you tried System Restore?
"Justin" <Justin@discussions.microsoft.com> wrote in message
news:39D5668A-1F07-4244-B6AC-15E04134F4A6@microsoft.com...
> Hello:
> Help! Please? :-)
> the
> the
> problems.
> Many thanks
> Justin
08-15-2006   #3 (permalink)
Max
Uninstall the program, then before rebooting use regedit (or Registry
Detective et al) to search the registry for all references to
pxhelp20.sys.
Delete any and all references found.
Then reboot.
If another 'missing or corrupt' message pops up, Lather, Rinse, Repeat.
Maxwell Bluemeanie
Not just FYI
> Hello:
> Help! Please? :-)
> the
> the
> problems.
08-15-2006   #4 (permalink)
I have tried System Restore. However, and unfortunately the only system
Restore points that appear to be present are from the time that Sonic's
software was installed! Go figure. I have no idea what happened to the other
restore points. I'm quite certain that I made the setting to maximize the
number of restore points. Perhaps you can, if you don't mind, educate me on
this one too! How can I be sure that I have maximized the number of restore
points? Ughhhh. Do you agree with Max's post of uninstalling the software and
using Reg Edit to remove all instances of PXhelp20.sys from the registry?
Many thanks!
> > Hello:
> > Help! Please? :-)
> > the
> > the
> > problems.
> > Many thanks
> > Justin
08-15-2006   #5 (permalink)
Hello Max,
Thank you for the suggestion. I would like to try your method but here is
what I am anticipating. If as you indicate, the error message might come
back, how to I "Rinse and Repeat?" I won't have access to the Regedit utility
will I ?
Thanks
Justin
> pxhelp20.sys.
> Then reboot.
> Maxwell Bluemeanie
> Not just FYI
> > Hello:
> > Help! Please? :-)
> > the
> > the
> > problems.
08-15-2006   #6 (permalink)
=?Utf-8?B?S2V2aW4gUGFuemtl?=
RE: pxhelp20.sys Problem on Vista
Have you tried LKGC (Last Known Good Configuration)?
Kevin John Panzke (MSDN OS Level Subscriber)
Windows Vista Beta 2 (I am Boycotting Build 5472, doesn't work on my
computer anymore, Just FYI.)
"Justin" wrote:
> Hello:
> Help! Please? :-)
> Many thanks
> Justin
08-15-2006   #7 (permalink)
MICHAEL
You must be dual-booting.
WinXP will delete Vista's SR points every time you boot
back to XP.
Do a search for "System Restore" and "volsnap.sys",
you'll get an idea of what is going on.
Microsoft needs to put some type of warning
in Vista about this massive malfunction.
-Michael
news:BC7581DF-5985-4F2F-8EBB-E0147669BD01@microsoft.com...
> Many thanks!
>> > Hello:
>> > Help! Please? :-)
>> > the
>> > the
>> > problems.
>> > Many thanks
>> > Justin
08-15-2006   #8 (permalink)
NOPE! Sorry Michael, your guess is wrong. I'm not dual booting. I did a clean
install and did not load XP.
> back to XP.
> -Michael
> > Many thanks!
> >> > Hello:
> >> > Help! Please? :-)
> >> > the
> >> > the
> >> > problems.
> >> > Many thanks
> >> > Justin
08-15-2006   #9 (permalink)
Yes I did. Sorry Kevin, that gives the same results as a normal boot.
> "Justin" wrote:
> > Hello:
> > Help! Please? :-)
> > Many thanks
> > Justin
08-15-2006   #10 (permalink)
Max
Chances are, it won't come back--at least not associated with that
particular file.
But if the 'uninstall' leaves other crap file references that Windows feels
it MUST have access to (due to crappy install and crappy uninstall) that
cannot be found in order to boot normally, booting to Safe Mode will likely
let you in to run Regedit and purge the references.
Maxwell Bluemeanie
And not just FYI again
news:15D65320-77DD-411E-AB17-142F26C22317@microsoft.com...
> Hello Max,
> utility
> will I ?
> Thanks
> Justin
>> pxhelp20.sys.
>> Then reboot.
>> Maxwell Bluemeanie
>> Not just FYI
>> > Hello:
>> > Help! Please? :-)
>> > Sonic
>> > the
>> > bring
>> > the
>> > problems.
>> > drive.
 pxhelp20.sys Problem on Vista problems?
Similar topics to: pxhelp20.sys Problem on Vista
I have problem starting up Vista - problem with driver Drivers
Vista problem, or keyboard problem? Vista General
Generic McAfee Problem Message in Vista Problem Reports Vista performance & maintenance
Vista Sleep Problem / Network Problem Vista networking & sharing
Vista Upgrade Problem - Windows Explorer Loop problem Vista installation & setup
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50
