| | Generic Volume Driver not working/recognized I have a Western Digital My Book external USB drive and also a USB card reader. Both have been running for months on my Gateway CX210X notebook under VISTA. Suddenly neither work anymore. When I plug them in, they try to install and I get a window entitled "Found New Hardware Unknown Device". The message states: " Windows found driver software for your device but encountered an error while attempting to install it. Generic Volume The system can not find the file specified. If you know the manufacturer of your device, you can visit its website and check the support section for driver software." Never before did I ever need to install any drivers other than the generic drivers provided by windows to make these devices run. I have tried to install drivers from my windows\system32 folder and its subfolders, but that does not seem to work. Does anybody have any advice? Stuart J. Cohen |
| | Re: Generic Volume Driver not working/recognized Go to Start/Run, and type DEVMGMT.MSC , highlight the USB Root Hub device(s), Action menu, "Uninstall", then Action menu, 'scan for hardware changes", to find the device drivers again automatically. -- Was this helpful? Then click the "Yes" Ratings button. Voting helps the web interface. http://www.microsoft.com/wn3/locales....htm#RateAPost Mark L. Ferguson .. "Disturbed" <Disturbed@xxxxxx> wrote in message news:E09F1F60-CD7E-40B0-B0A6-666E8385C2B0@xxxxxx Quote: >I have a Western Digital My Book external USB drive and also a USB card > reader. Both have been running for months on my Gateway CX210X notebook > under VISTA. Suddenly neither work anymore. When I plug them in, they try > to > install and I get a window entitled "Found New Hardware Unknown Device". > The > message states: > > " Windows found driver software for your device but encountered an error > while attempting to install it. > > Generic Volume > > The system can not find the file specified. If you know the manufacturer > of > your device, you can visit its website and check the support section for > driver software." > > Never before did I ever need to install any drivers other than the generic > drivers provided by windows to make these devices run. > > I have tried to install drivers from my windows\system32 folder and its > subfolders, but that does not seem to work. > > Does anybody have any advice? > > Stuart J. Cohen |
| Generic Volume Driver Error | Drivers | |||
| Windows can't stop Generic volume | Vista hardware & devices | |||
| poss solution to generic volume and usb drive problems | Vista hardware & devices | |||
| Generic Volume drivers | Vista hardware & devices | |||
| Generic Volume Driver | Drivers | |||
