| | Vista Digital Cable OEM PC w/ ATI TV Wonder Digital Cable Tuner -H I have a new HP 4999t PC with factory installed ViXS PureTV-U 48B0 (NTSC/ATSC Combo) AND an external ATI TV Wonder Digital Cable Tuner. The PC was ordered from the OEM with Digital Cable Support enabled. My goal is to configure three tuners within MCE: one analog tuner, one OTA digital antenna tuner, and one Digital Cable tuner. Worst case, two digital tuners is OK. I bought these expensive tuner options so I can watch Clear QAM HDTV using my basic cable signal (OCUR). I have a few issues that I can't figure out: 1. TV tuners are not found during Auto Configure scan in Vista MCE. 2. How do I get Digital clear QAM over cable? Do I need a separate set-top cable box even though I have an ATI External Digital Cable Tuner? (All of my LCD televisions get the "free" clear QAM cable broadcasted HDTV channels just fine like ABC, NBC, CBS, etc...that is all I'm trying to do in MCE.) Thanks -- Brian Stillwater, MN |
| | Re: Vista Digital Cable OEM PC w/ ATI TV Wonder Digital Cable Tuner -H Can't tell if this would help or not: Windows Media Center does not correctly configure a combo TV tuner that supports both ATSC and NTSC signals: http://support.microsoft.com/kb/929011 -- Was this helpful? Then click the "Yes" Ratings button. Voting helps the web interface. http://www.microsoft.com/wn3/locales....htm#RateAPost Mark L. Ferguson .. "bjwerti" <bjwerti@xxxxxx> wrote in message news:73EEE98F-BD50-41CA-87C4-552DDF6C64F9@xxxxxx Quote: >I have a new HP 4999t PC with factory installed ViXS PureTV-U 48B0 >(NTSC/ATSC > Combo) AND an external ATI TV Wonder Digital Cable Tuner. The PC was > ordered > from the OEM with Digital Cable Support enabled. My goal is to configure > three tuners within MCE: one analog tuner, one OTA digital antenna tuner, > and one Digital Cable tuner. Worst case, two digital tuners is OK. > > I bought these expensive tuner options so I can watch Clear QAM HDTV using > my basic cable signal (OCUR). I have a few issues that I can't figure > out: > 1. TV tuners are not found during Auto Configure scan in Vista MCE. > 2. How do I get Digital clear QAM over cable? Do I need a separate > set-top > cable box even though I have an ATI External Digital Cable Tuner? > > (All of my LCD televisions get the "free" clear QAM cable broadcasted HDTV > channels just fine like ABC, NBC, CBS, etc...that is all I'm trying to do > in > MCE.) > > Thanks > -- > Brian > Stillwater, MN |
| | Re: Vista Digital Cable OEM PC w/ ATI TV Wonder Digital Cable Tuner-H bjwerti wrote: Quote: > I have a new HP 4999t PC with factory installed ViXS PureTV-U 48B0 (NTSC/ATSC > Combo) AND an external ATI TV Wonder Digital Cable Tuner. The PC was ordered > from the OEM with Digital Cable Support enabled. My goal is to configure > three tuners within MCE: one analog tuner, one OTA digital antenna tuner, > and one Digital Cable tuner. Worst case, two digital tuners is OK. > > I bought these expensive tuner options so I can watch Clear QAM HDTV using > my basic cable signal (OCUR). I have a few issues that I can't figure out: > 1. TV tuners are not found during Auto Configure scan in Vista MCE. > 2. How do I get Digital clear QAM over cable? Do I need a separate set-top > cable box even though I have an ATI External Digital Cable Tuner? > > (All of my LCD televisions get the "free" clear QAM cable broadcasted HDTV > channels just fine like ABC, NBC, CBS, etc...that is all I'm trying to do in > MCE.) > > Thanks have to call yr cable co. and have them install a "card" in your machine (they don't have to open the machine, it goes in a slot on the back of the built-in tv tuner you have..) this "card" is equivalent to a digital cable box, and cable co. will charge you accordingly for it.. ($10/mo. or so...) then you have to activate the digital cable tv feature in Windows Media Center, by providing a digital cable product key that should have been supplied when you purchased your tuner(s) or is supplied with computer (on sticker next to Vista activation product key) if you purchased a machine w/built-in tuner(s).. (you should have at least two tuners so you can watch one thing and tape another simultaneously.. the tuners should come with built-in digital recorders, like a built-in TIVO..) however, I personally have not been able to do activate WMC for digital cable tv, Vista problems (what a surprise... , long story... (see mypost related to "digital cable" in vista.music_pictures_video..) I have not yet received a response, and will most probably have to do a clean re-install of Vista to solve the problem.. hopefully this won't happen to you.. not sure this answers all your questions.. HTH.. |
| | RE: ATI TV Wonder Digital Cable Tuner -H I have the same system and the same problem. HP actually told me to send the PC back to get it fixed. I don't think so. The PC works fine. The ATI shows proper status lights and appears on the network. It's got to be something else. I tried shutting down Norton 360 and ran Windows Media Center setup again. I got snow for pictures (which is actually farther than I've gotten before). Since I paid for 15 months of Norton 360, I hate to uninstall it (they don't send actual discs anymore, as you know...if I uninstall it, I'm buying a new one). When I went through the Norton "Add Programs" there was no .exe file that I could enable. Added all I could find in the ATI listing to the program list. Still not working Anyone have any other suggestions? Frustrated Digital Cable fan (less) |
| | RE: ATI TV Wonder Digital Cable Tuner -H Duck Fan, I had this same issue. I just bought an HP m9200t, with the two tuners in it. MCE could not identify the CableCard. I found a forum that discussed this very issue, and it turns out that it was Norton causing it. My computer came with 15 months of Norton service, I never directly paid for it, so I decided that I would prefer a fully functional computer than some virus scanner and firewall blocking it. I could always add it later. Once I uninstalled Norton it worked perfectly. There is probably some way to get by it without removing it completely from your computer. If you have the patience, you may want to check with Symantec (makers of Norton), to see if they have a solution. It probably will be an issue you will have to take beyond first tier Tech Support. Note that for some MCE functionality to work you may need to temporarily disable the Windows firewall, or at least make some exceptions in it (which will take more time to figure out). I found this out when MCE could not get the TV guide. I can excuse Norton for blocking traffic that actually become detrimental to the operation of MCE, but when it is Microsoft's own operating system one has to wonder. Seems like Microsoft still has some bugs to work out. After you get it going, it is a great thing. NOTE to MS: Please work these bugs out. I am a software developer, and I know if I have trouble getting things going, the average user certainly will. MCE is a great concept as a centerpiece for home theater, but there are things that need to be worked out if it is going to be widely adopted as such. Signed, Equally frustrated but hopeful "Duck Fan" wrote: Quote: > I have the same system and the same problem. HP actually told me to send the > PC back to get it fixed. I don't think so. The PC works fine. The ATI > shows proper status lights and appears on the network. It's got to be > something else. > > I tried shutting down Norton 360 and ran Windows Media Center setup again. > I got snow for pictures (which is actually farther than I've gotten before). > Since I paid for 15 months of Norton 360, I hate to uninstall it (they don't > send actual discs anymore, as you know...if I uninstall it, I'm buying a new > one). > > When I went through the Norton "Add Programs" there was no .exe file that I > could enable. Added all I could find in the ATI listing to the program list. > Still not working > > Anyone have any other suggestions? > > Frustrated Digital Cable fan (less) > |
| | #6 (permalink) |
| Vista Home Premium | Re: ATI TV Wonder Digital Cable Tuner -H I have an HP 4995 witth an analog internal TV tuner and and external ATI TV wonder Digital Cable Tuner. I am also a comcast customer. Spent hours trying to get the tuner working so that I could get HD channels. Had comcast here as well, and could not get it to work. I had comcst give me a cable card. After some research I removed Norton, then went throught the MCE setup of the cable tuner, but did not install the cable card. Once I finally got it working on basic cable stations (Non-HD), i plugged in the cable card and MCE gave me a screen with the cable card info. I closed that screen then tuned to a HD channel and it worked. Please note after hours on the phone with HP support who didn't even know what a Digital cable tuner was, I wrote letters to senior management of HP complaining and all they did was give you another customer service number to call. Was transfered several times to India and got even less help. Funny HP sells the OEM ATI TV wonder, but they have nobody in support that can help walk anyone through the setup. I am tempted to have a friend at a major network do a Buyer Beware series on HP, and see if that gets their attention. Please note I can now watch HD content, but another problem has surfaced where when watch for a period of time it appears the monitor wants to go to sleep mode, but if that occurs, the whole system shuts down and reboots. The the Microsoft trouble shooter comes up and says get with Microsoft of ATI. HP and ATI should publish so help on this after they have sold the product, but seem to want to wash their hands of it. Also be ware of the Vista service pack #1, which I installed, but when I went to view TV it pixelated the picture on a regular cycle, so I unistalled the service pack. |
| | #7 (permalink) |
| vista 32 | Re: Vista Digital Cable OEM PC w/ ATI TV Wonder Digital Cable Tuner -H Many Security software vendors are encountering the same issue. Norton 360 has a work around for this issue. http://service1.symantec.com/SUPPORT/norton2008.nsf/docid/2008042514433079?Open&docid=2008030313314575&nsf=norton360.nsf&view=docid Straylight. |
| | #8 (permalink) |
| | Re: Vista Digital Cable OEM PC w/ ATI TV Wonder Digital Cable Tuner -H I have this same problem: mine works until I insert the CableCard, then I lose everything. Sometimes I get a message that channels aren't available, sometimes I get a message that I'm not allowed to view the channels or my LCD isn't set up correctly. I've been able to determine that the Network isn't communicating with the tuner. I use McAfee. Has anyone experienced the same problems with McAfee that others were experiencing with Norton? ATI on their website says if the Tuner doesn't work with the CableCard, but does without, the tuner is bad. I've been working with HP for 2 months to get it replaced. They sent the internal cable card the first time, and now I'm pulling teeth to get them to figure out what part this is. It's so frustrating! -- Fluter ------------------------------------------------------------------------ Fluter's Profile: http://forums.techarena.in/members/86340.htm View this thread: http://forums.techarena.in/vista-help/925460.htm http://forums.techarena.in |
| | #9 (permalink) |
| Vista Home Premium | Re: Vista Digital Cable OEM PC w/ ATI TV Wonder Digital Cable Tuner -H I have comcast, and had them to my house. we went through about 6 cable cable cards before we found one that work. I was told by comcast they have a lot ob ad cards. Also with Windows media player, I recommend disabling Symatic and Mcafee if you have them running when you set up the tuner. Once you have it up and running you can turn them back on. There was a lot of hit or miss getting my HD tuner to work. HP who sold me the computer and tuner, were of no help. People in India do not even know what a digital cable tuner is. I still have problems from time to time as I still do not get all the cable stations that I have with my regular tv and Comcast tuner. HP does not back up third party hardware and will tell you to go to ATI who will tell you to go to the OEM. Again test a few cable cards. If you get your tuner to work, then put the cable card in and go to a HD station like ABC, NBC or CBS. Sorry I cannot be of more help. I even sent emails to the president of HP who referred me to a group that did nothing. But now I get a bunch of HP email. I will not buy HP again. I will shop around and see who supports what. |
| | #10 (permalink) |
| | Re: Vista Digital Cable OEM PC w/ ATI TV Wonder Digital Cable Tuner -H You people are the best! Last night I disabled my firewall and tried installing this thorn in my side again. Well, joy. This time I got the message that I wasn't HDCP compliant, so I removed my DVI cable hookup, went back to VGA and now I'm finally up and running. Unfortunately, my monitor doesn't seem to be HDCP compliant, so I had to downgrade it to VGA, but at least the ATI TV Wonder blah blah blah... is working after 6 months!!! I'm actually getting HD stations on this thing with the CableCARD! Shock! So much for HP support! I guess I can cancel that completely frustrating and useless HP support ticket now! -- Fluter ------------------------------------------------------------------------ Fluter's Profile: http://forums.techarena.in/members/86340.htm View this thread: http://forums.techarena.in/vista-help/925460.htm http://forums.techarena.in |
| Which HDTV Tuner card to use as a DVR with digital cable | Media Center | |||
| Vista Ultimate + Comcast w/digital cable | Media Center | |||
| Vista x64 TV Tuner with Comcast Digital Cable | Media Center | |||
| WMC/TV Tuner and Digital Cable Box - Scrambled Signal | Vista General | |||
| Windows Vista Anytime Upgrade and Digital Cable | Vista General | |||
