| | Error when removing ReadyBoost USB Flash Drive Whenever I remove my ReadyBoost drive (you can't use the "Safely Remove Hardware" feature) I get a warning error every 5 seconds in the Vista Event Viewer(system events). I have to remove it before putting my laptop to sleep otherwise the system will wake up when I remove the flash drive(while it's sleeping). I'd leave it in the usb port but it wont fit in my backpack with it in. Stupid huh? Here's the particulars: Event ID: 57 (qualifier=32772) "The system failed to flush data to the transaction log. Corruption may occur." Windows Vista Enterprise 6.0.6000.16386 If I reinsert the flash drive(into the same port) I still get the errors every 5 seconds. In order to stop the errors I need to reboot. Does anyone know a fix for this? I hate having to clean out my event logs. Thanks, Mike |
| | Re: Error when removing ReadyBoost USB Flash Drive Go to the properties of the flash drive and select "Do not use this device" in the ReadyBoost tab. Then click OK or Apply. You can then unplug the USB flash drive without getting those errors. "MiGKiller" <MiGKiller@xxxxxx> wrote in message news:AE23B23A-E5FD-4939-BD9C-8E403DFF46A2@xxxxxx Quote: > Whenever I remove my ReadyBoost drive (you can't use the "Safely Remove > Hardware" feature) I get a warning error every 5 seconds in the Vista > Event > Viewer(system events). I have to remove it before putting my laptop to > sleep otherwise > the system will wake up when I remove the flash drive(while it's > sleeping). > I'd leave it in the usb port but it wont fit in my backpack with it in. > Stupid huh? > > Here's the particulars: > > Event ID: 57 (qualifier=32772) > "The system failed to flush data to the transaction log. Corruption may > occur." > > Windows Vista Enterprise 6.0.6000.16386 > > If I reinsert the flash drive(into the same port) I still get the errors > every 5 seconds. > > In order to stop the errors I need to reboot. > > Does anyone know a fix for this? I hate having to clean out my event > logs. > > Thanks, > > Mike > > > |
| | Re: Error when removing ReadyBoost USB Flash Drive You could Hibernate instead of standby. Then you might be able to unplug the flash drive. "MiGKiller" <MiGKiller@xxxxxx> wrote in message news:AE23B23A-E5FD-4939-BD9C-8E403DFF46A2@xxxxxx Quote: > Whenever I remove my ReadyBoost drive (you can't use the "Safely Remove > Hardware" feature) I get a warning error every 5 seconds in the Vista > Event > Viewer(system events). I have to remove it before putting my laptop to > sleep otherwise > the system will wake up when I remove the flash drive(while it's > sleeping). > I'd leave it in the usb port but it wont fit in my backpack with it in. > Stupid huh? > > Here's the particulars: > > Event ID: 57 (qualifier=32772) > "The system failed to flush data to the transaction log. Corruption may > occur." > > Windows Vista Enterprise 6.0.6000.16386 > > If I reinsert the flash drive(into the same port) I still get the errors > every 5 seconds. > > In order to stop the errors I need to reboot. > > Does anyone know a fix for this? I hate having to clean out my event > logs. > > Thanks, > > Mike > > > |
| | Re: Error when removing ReadyBoost USB Flash Drive Thanks Gary, the hibernate option seems to be a good workaround. I was hoping that there would a hotfix or update to the ReadyBoost feature. Much appreciated. -Mike "Gary Mount" wrote: Quote: > You could Hibernate instead of standby. Then you might be able to unplug the > flash drive. > > "MiGKiller" <MiGKiller@xxxxxx> wrote in message > news:AE23B23A-E5FD-4939-BD9C-8E403DFF46A2@xxxxxx Quote: > > Whenever I remove my ReadyBoost drive (you can't use the "Safely Remove > > Hardware" feature) I get a warning error every 5 seconds in the Vista > > Event > > Viewer(system events). I have to remove it before putting my laptop to > > sleep otherwise > > the system will wake up when I remove the flash drive(while it's > > sleeping). > > I'd leave it in the usb port but it wont fit in my backpack with it in. > > Stupid huh? > > > > Here's the particulars: > > > > Event ID: 57 (qualifier=32772) > > "The system failed to flush data to the transaction log. Corruption may > > occur." > > > > Windows Vista Enterprise 6.0.6000.16386 > > > > If I reinsert the flash drive(into the same port) I still get the errors > > every 5 seconds. > > > > In order to stop the errors I need to reboot. > > > > Does anyone know a fix for this? I hate having to clean out my event > > logs. > > > > Thanks, > > > > Mike > > > > > > |
| | Re: Error when removing ReadyBoost USB Flash Drive I believe that because of security reasons, unplugging the ready boost flash drive in standby mode will cause the cache to need to be rebuilt. When hibernating, after coming out of hibernation the cache is rebuilt just in case the cache has been compromised. Maybe version 2.0 would allow a user to configure whether to rebuild the cache after coming out of hibernation. Only ReadyBoost memory that is built into the motherboard does not present a security problem (to a degree) and does not have to be rebuilt each time after coming out of hibernation. Service Pack 1 (available this month) might help with the problem that you are having. "MiGKiller" <MiGKiller@xxxxxx> wrote in message news:626DC951-90B9-4725-A8C6-687AC07C97D4@xxxxxx Quote: > Thanks Gary, the hibernate option seems to be a good workaround. I was > hoping that there would a hotfix or update to the ReadyBoost feature. > > Much appreciated. > > -Mike > > > "Gary Mount" wrote: > Quote: >> You could Hibernate instead of standby. Then you might be able to unplug >> the >> flash drive. >> >> "MiGKiller" <MiGKiller@xxxxxx> wrote in message >> news:AE23B23A-E5FD-4939-BD9C-8E403DFF46A2@xxxxxx Quote: >> > Whenever I remove my ReadyBoost drive (you can't use the "Safely Remove >> > Hardware" feature) I get a warning error every 5 seconds in the Vista >> > Event >> > Viewer(system events). I have to remove it before putting my laptop >> > to >> > sleep otherwise >> > the system will wake up when I remove the flash drive(while it's >> > sleeping). >> > I'd leave it in the usb port but it wont fit in my backpack with it in. >> > Stupid huh? >> > >> > Here's the particulars: >> > >> > Event ID: 57 (qualifier=32772) >> > "The system failed to flush data to the transaction log. Corruption >> > may >> > occur." >> > >> > Windows Vista Enterprise 6.0.6000.16386 >> > >> > If I reinsert the flash drive(into the same port) I still get the >> > errors >> > every 5 seconds. >> > >> > In order to stop the errors I need to reboot. >> > >> > Does anyone know a fix for this? I hate having to clean out my event >> > logs. >> > >> > Thanks, >> > >> > Mike >> > >> > >> > |
| | #6 (permalink) |
| | Re: Error when removing ReadyBoost USB Flash Drive Thank you so much for providing some clarification to this issue. I'll wait and see (and hope) if SP1 will provide a solution to this problem. Regards, -Mike "Gary Mount" wrote: Quote: > I believe that because of security reasons, unplugging the ready boost flash > drive in standby mode will cause the cache to need to be rebuilt. When > hibernating, after coming out of hibernation the cache is rebuilt just in > case the cache has been compromised. Maybe version 2.0 would allow a user to > configure whether to rebuild the cache after coming out of hibernation. > Only ReadyBoost memory that is built into the motherboard does not present a > security problem (to a degree) and does not have to be rebuilt each time > after coming out of hibernation. > Service Pack 1 (available this month) might help with the problem that you > are having. > > "MiGKiller" <MiGKiller@xxxxxx> wrote in message > news:626DC951-90B9-4725-A8C6-687AC07C97D4@xxxxxx Quote: > > Thanks Gary, the hibernate option seems to be a good workaround. I was > > hoping that there would a hotfix or update to the ReadyBoost feature. > > > > Much appreciated. > > > > -Mike > > > > > > "Gary Mount" wrote: > > Quote: > >> You could Hibernate instead of standby. Then you might be able to unplug > >> the > >> flash drive. > >> > >> "MiGKiller" <MiGKiller@xxxxxx> wrote in message > >> news:AE23B23A-E5FD-4939-BD9C-8E403DFF46A2@xxxxxx > >> > Whenever I remove my ReadyBoost drive (you can't use the "Safely Remove > >> > Hardware" feature) I get a warning error every 5 seconds in the Vista > >> > Event > >> > Viewer(system events). I have to remove it before putting my laptop > >> > to > >> > sleep otherwise > >> > the system will wake up when I remove the flash drive(while it's > >> > sleeping). > >> > I'd leave it in the usb port but it wont fit in my backpack with it in. > >> > Stupid huh? > >> > > >> > Here's the particulars: > >> > > >> > Event ID: 57 (qualifier=32772) > >> > "The system failed to flush data to the transaction log. Corruption > >> > may > >> > occur." > >> > > >> > Windows Vista Enterprise 6.0.6000.16386 > >> > > >> > If I reinsert the flash drive(into the same port) I still get the > >> > errors > >> > every 5 seconds. > >> > > >> > In order to stop the errors I need to reboot. > >> > > >> > Does anyone know a fix for this? I hate having to clean out my event > >> > logs. > >> > > >> > Thanks, > >> > > >> > Mike > >> > > >> > > >> > > >> |
| | #7 (permalink) |
| | Re: Error when removing ReadyBoost USB Flash Drive Thanks again for providing the information and clarification about this issue. I'll stand by for V2.0 and/or SP1. Hopefully either of those will provide some kind of solution. Regards, Mike "Gary Mount" wrote: Quote: > I believe that because of security reasons, unplugging the ready boost flash > drive in standby mode will cause the cache to need to be rebuilt. When > hibernating, after coming out of hibernation the cache is rebuilt just in > case the cache has been compromised. Maybe version 2.0 would allow a user to > configure whether to rebuild the cache after coming out of hibernation. > Only ReadyBoost memory that is built into the motherboard does not present a > security problem (to a degree) and does not have to be rebuilt each time > after coming out of hibernation. > Service Pack 1 (available this month) might help with the problem that you > are having. > > "MiGKiller" <MiGKiller@xxxxxx> wrote in message > news:626DC951-90B9-4725-A8C6-687AC07C97D4@xxxxxx Quote: > > Thanks Gary, the hibernate option seems to be a good workaround. I was > > hoping that there would a hotfix or update to the ReadyBoost feature. > > > > Much appreciated. > > > > -Mike > > > > > > "Gary Mount" wrote: > > Quote: > >> You could Hibernate instead of standby. Then you might be able to unplug > >> the > >> flash drive. > >> > >> "MiGKiller" <MiGKiller@xxxxxx> wrote in message > >> news:AE23B23A-E5FD-4939-BD9C-8E403DFF46A2@xxxxxx > >> > Whenever I remove my ReadyBoost drive (you can't use the "Safely Remove > >> > Hardware" feature) I get a warning error every 5 seconds in the Vista > >> > Event > >> > Viewer(system events). I have to remove it before putting my laptop > >> > to > >> > sleep otherwise > >> > the system will wake up when I remove the flash drive(while it's > >> > sleeping). > >> > I'd leave it in the usb port but it wont fit in my backpack with it in. > >> > Stupid huh? > >> > > >> > Here's the particulars: > >> > > >> > Event ID: 57 (qualifier=32772) > >> > "The system failed to flush data to the transaction log. Corruption > >> > may > >> > occur." > >> > > >> > Windows Vista Enterprise 6.0.6000.16386 > >> > > >> > If I reinsert the flash drive(into the same port) I still get the > >> > errors > >> > every 5 seconds. > >> > > >> > In order to stop the errors I need to reboot. > >> > > >> > Does anyone know a fix for this? I hate having to clean out my event > >> > logs. > >> > > >> > Thanks, > >> > > >> > Mike > >> > > >> > > >> > > >> |
| Remove ReadyBoost from USB flash drive | Vista performance & maintenance | |||
| Removing Readyboost Drive | Vista hardware & devices | |||
| removing usb flash drive | Vista hardware & devices | |||
| ReadyBoost killed my USB flash drive | Vista hardware & devices | |||
| usb flash drive and readyboost | Vista hardware & devices | |||
