Vista - "I have WinXP Pro, Which Vista will be the closest in Features
Old 03-07-2008   #1 (permalink)
EdtheAminal
I am going to make my computer a Duel OS computer. Each OS will have it's
own Hard drive. I currently run WinXP Pro. Which Vista will be the closest
in features to the XP pro? I'm a gamer and do video as well as picture work
on my computer.
Old 03-07-2008   #2 (permalink)
Dustin Harper
Re: "I have WinXP Pro, Which Vista will be the closest in Features
If you don't use a domain or want the Ultimate Extras, then Home Premium
will do the trick. Otherwise Ultimate is probably the way to go.
Dustin Harper
dharper@xxxxxx
http://www.vistarip.com | Vista Resource & Information Page
"EdtheAminal" <EdtheAminal@xxxxxx> wrote in message
news:6E923E6D-E271-4BF6-A9AC-044A6987D94F@xxxxxx
> closest
> work
> on my computer.
Old 03-07-2008   #3 (permalink)
Malke
> closest
> work on my computer.
You want either Vista Home Premium or Vista Ultimate.
Comparison chart by MVP Tom Porterfield -
http://support.teloep.org/vistaver.htm
Vista product comparisons -
http://www.microsoft.com/windows/pro...ns/choose.mspx
Malke
MS-MVP
Elephant Boy Computers
www.elephantboycomputers.com
Don't Panic!
Old 03-07-2008   #4 (permalink)
ray
On Fri, 07 Mar 2008 08:09:01 -0800, EdtheAminal wrote:
> it's own Hard drive. I currently run WinXP Pro. Which Vista will be
> the closest in features to the XP pro? I'm a gamer and do video as well
> as picture work on my computer.
Lets hope that as they duel they don't kill any innocent bystanders. I
believe you mean 'dual' - as in 'two'.
Old 03-07-2008   #5 (permalink)
Andre Matuch
> on my computer.
Pro allows you to connect to your computer remotely. Your only choice is
Ultimate if you need that feature. Otherwise, Home Premium is fine.
Old 03-07-2008   #6 (permalink)
Ken Blake, MVP
On Fri, 7 Mar 2008 08:09:01 -0800, EdtheAminal
> on my computer.
Several points:
1. Dueling on a computer isn't a good idea. What you probably want is
to *dual* boot.
2. From your description of what you do with your computer, I don't
see any reason why you need XP Professional in the first place. XP
Home should work just as well for you.
3. The same is true of Vista. I don't see anything you've said that
tells me you need any more than Vista Home Premium.
4. But to be sure, you should read
or http://tinyurl.com/3843r3
to see the differences in the feature sets of the various Vista
editions.
Ken Blake, Microsoft MVP - Windows Desktop Experience
Please Reply to the Newsgroup
Old 03-07-2008   #7 (permalink)
Dwarf
RE: "I have WinXP Pro, Which Vista will be the closest in Features
Hi Ed,
According to the Windows Vista Upgrade Advisor, the recommended upgrade from
WinXP Pro is to the Business version. This is probably because the vast
majority of computers running XP Pro are in the business sector. However,
since you are also a gamer and do video and picture work I recommend that you
go for the Ultimate version. That way, you get everything that the Business
AND Home Premium versions have to offer.
Dwarf
> on my computer.
Re: Vista Explorer "features" Vista General
Re: How to manage the WinXP start menu OUTSIDE of "Documents andSettings"? Vista installation & setup
Is it possible to install a Vista "Recovery Console" in the boot menu, as in WinXP? Vista General
Vista new "security" features more a pain in the butt then anything else Vista installation & setup
