| Guest | Need Help With Aero. PLZ Help!!! I installed a fresh copy of Vista Ultimate and when i go to the color schemes aero does not show up what could cause this plz help.. |
| Guest | RE: Need Help With Aero. PLZ Help!!! You need 64MBs minimum, recomm. 128MBs of graphics for aero to work properly. Also, your graphics card requires an LDDM(longhorn display driver model) and support for directX9 API -- Mick Murphy - Qld - Australia "Igneous Jester" wrote: Quote: > I installed a fresh copy of Vista Ultimate and when i go to the color schemes > aero does not show up what could cause this plz help.. |
| Member | Re: Need Help With Aero. PLZ Help!!! in addition, since you reinstalled, be sure that you have successfully activated vista. Areo will not become and option unless vista is activated, regardless of your graphics ability. |
| Guest | RE: Need Help With Aero. PLZ Help!!! One other thing you might try is to check your Windows Experience Index. It has to be above a certain value (I do not remember the value now) to be able to run Aero. Whenever I install new video drivers for my card I have to refresh the Windows Experience Index. During the installation of Vista, the WEI is determined. In my case when I installed Ultimate, the video rating were 1.0 with the default drivers. After installing Ultimate, the very next step was to install the latest video drivers. When I looked at the WEI, it was showing 1.0/1.0 and "Unrated". I "refreshed" the WEI and now had 5.9/5.5 for the two video ratings and now had Aero capabilities "Igneous Jester" wrote: Quote: > I installed a fresh copy of Vista Ultimate and when i go to the color schemes > aero does not show up what could cause this plz help.. |
| Guest | Re: Need Help With Aero. PLZ Help!!! Pbb321 wrote : Quote: > in addition, since you reinstalled, be sure that you have successfully > activated vista. Areo will not become and option unless vista is > activated, regardless of your graphics ability. activated it (used the "rearm" method to postpone activation for a bit). Aero worked fine all the time, also when Vista was not yet activated. -- Kind regards, Mark Veldhuis. |
| Aero theme missing, vista theme were actually aero | Vista General | |||
| Aero Theme will not stay set and so cannot turn on Aero | Vista General | |||
| Dreamscene broke Aero. I want Aero back. Help please. | Vista General | |||
| aero with 2.9? | Vista performance & maintenance | |||
| Aero | Vista performance & maintenance | |||
