Vista - system volume information? What is it?
Old 03-09-2008   #1 (permalink)
T5
following my earlier post reference unusual amounts of hard disk space being
used......................................I have partitioned a 300gb HDD so
that C has 240GB and D has the remainder.
C is reporting that I have used 200GB but this cannot be so as I only have
operating system and a few progs and pics plus about 16gb music so where has
all the used space come from?
I probably have only used about 50gb max. I cannot find any file/folder that
has excessive amounts of data. How do I rectify this?
I have subsequently found a file called System volume information and it is
taking up 159gb of hard disk space but if I try to view the file there seems
to be nothing in it...what do I do to release all of this hard drive space?
Old 03-09-2008   #2 (permalink)
Mark L. Ferguson
Re: system volume information? What is it?
If you boot to Safe Mode (F8 on restart) you will log on as the default
'administrator' account. This will let you access the folder.
Was this helpful? Then click the Ratings button. Voting helps the web
interface.
http://www.microsoft.com/wn3/locales....htm#RateAPost
Mark L. Ferguson
"T5" <noanswer@xxxxxx> wrote in message
news:88EB20CA-34A1-46D9-84DC-AD259EBFC60E@xxxxxx
> being used......................................I have partitioned a 300gb
> HDD so that C has 240GB and D has the remainder.
> has
> that
> is taking up 159gb of hard disk space but if I try to view the file there
> seems to be nothing in it...what do I do to release all of this hard drive
> space?
Old 03-09-2008   #3 (permalink)
Ronnie Vernon MVP
T5
You need to set a custom size for the System Restore component.
You can do this from a command prompt. Go to Start and type cmd.exe in
the search Box. In the results, right click the cmd.exe and select 'Run As
Administrator' from the menu.
Type the following command:
vssadmin resize shadowstorage /For=C: /On=C: /MaxSize=10GB
(Make sure to enter the command exactly as shown, including the spaces)
Press Enter.
This will set the maximum size for System Restore for the C: drive to 10GB,
which is plenty for a 240GB partition.
Next, you need to clear that System Volume Information folder.
Go to Start/All Programs/Accessories/System Tools. Click 'System Restore'.
In the System Restore dialog, click the link to 'System Protection'.
In the System Protection dialog, remove the check mark from the C: Drive.
This will turn System Restore 'off' for that drive. Click Apply/OK. Reboot
the computer.
The System Volume Information folder should now be empty.
Follow the steps to open System Protection again and place the check mark
back in the Crive. Click Apply. Click the Create Button and create a new
Restore Point for that drive.
Ronnie Vernon
Microsoft MVP
Windows Desktop Experience
> has
> that
> space?
43 GB System File in System Volume Information on 160 GB partition Vista General
Get rid of System Volume Information Vista file management
System Volume Information Vista performance & maintenance
System Volume Information Vista hardware & devices
