| | My sata hard drive does not appear in Vista I have 3 internal hard drives. One is the 'C' drive. Then I have a 'D' drive for storage. Then I have 'L' drive which contains my MS games, ie Train Sim And Flight Sim. And lets add an external HD 'K' which contains private storage. All of these drives were visible when I was using XP Pro. I installed Vista the other day off a DVD-/+RW which is a Sata drive and had no problems. Now my drive 'L' is no where to be found. I checked with Computer Management and it still doesn't show. I updated the drivers for the ASUS motherboard, still a no show. What can I do here? There is way too much special info on that drive to fool around with reformating. Please help me find an answer. Thank you all! Mike |
| | RE: My sata hard drive does not appear in Vista Mike I would try the logical choice method. Open up your system and double check all of your wireing. Make sure your power plugs are all seated well and all wires in and seated as well. If that is a go, try unpluging your second internal drive and plugging in the drive you are having problems with. Use the same wires and plug from the one you unplugged. Start up and see if it shows up. If it does, come on back and we'll go from there! Good Luck ~~ Gunny "Mike" wrote: Quote: > I have 3 internal hard drives. One is the 'C' drive. Then I have a 'D' drive > for storage. Then I have 'L' drive which contains my MS games, ie Train Sim > And Flight Sim. And lets add an external HD 'K' which contains private > storage. All of these drives were visible when I was using XP Pro. I > installed Vista the other day off a DVD-/+RW which is a Sata drive and had no > problems. > Now my drive 'L' is no where to be found. I checked with Computer Management > and it still doesn't show. I updated the drivers for the ASUS motherboard, > still a no show. What can I do here? There is way too much special info on > that drive to fool around with reformating. > Please help me find an answer. Thank you all! > > Mike |
| | Re: My sata hard drive does not appear in Vista "Mike" <Mike@xxxxxx> wrote in message news:F835AD0F-FC1F-400F-9375-47A2CF5EB935@xxxxxx Quote: >I have 3 internal hard drives. One is the 'C' drive. Then I have a 'D' >drive > for storage. Then I have 'L' drive which contains my MS games, ie Train > Sim > And Flight Sim. And lets add an external HD 'K' which contains private > storage. All of these drives were visible when I was using XP Pro. I > installed Vista the other day off a DVD-/+RW which is a Sata drive and had > no > problems. > Now my drive 'L' is no where to be found. I checked with Computer > Management > and it still doesn't show. I updated the drivers for the ASUS motherboard, > still a no show. What can I do here? There is way too much special info on > that drive to fool around with reformating. > Please help me find an answer. Thank you all! > > Mike Ok, How many physical drives did you have when you started? Where these all SATA drives? Were any of these RAID drives? How were they formatted, that is to say, how were they partitioned? On big partition for each drive? What manufacturer drives are these and do you have the "disk tools" for the drives? You can get them from the respective manufacturers web sites. -- BobF. |
| | Re: My sata hard drive does not appear in Vista "Seidell23231" <Seidell23231@xxxxxx> wrote in message news:2CB4B200-5D72-432E-AE42-F8A07FC994E5@xxxxxx Quote: > Mike I would try the logical choice method. Open up your system and > double > check all of your wireing. Make sure your power plugs are all seated well > and all wires in and seated as well. If that is a go, try unpluging your > second internal drive and plugging in the drive you are having problems > with. > Use the same wires and plug from the one you unplugged. Start up and see > if > it shows up. If it does, come on back and we'll go from there! > trouble shooting process unless it it necessary. If the drives were found in your old OS, we'll find them in the new one. -- BobF. Quote: > Good Luck ~~ Gunny > > "Mike" wrote: > Quote: >> I have 3 internal hard drives. One is the 'C' drive. Then I have a 'D' >> drive >> for storage. Then I have 'L' drive which contains my MS games, ie Train >> Sim >> And Flight Sim. And lets add an external HD 'K' which contains private >> storage. All of these drives were visible when I was using XP Pro. I >> installed Vista the other day off a DVD-/+RW which is a Sata drive and >> had no >> problems. >> Now my drive 'L' is no where to be found. I checked with Computer >> Management >> and it still doesn't show. I updated the drivers for the ASUS >> motherboard, >> still a no show. What can I do here? There is way too much special info >> on >> that drive to fool around with reformating. >> Please help me find an answer. Thank you all! >> >> Mike |
| | Re: My sata hard drive does not appear in Vista Bob F, I have 3 installed hard drives. The L is the only one that is sata, the others are ata. They are all made by Maxtor. Here’s something I didn’t notice before. I went into ‘Device Manager’ to get the name of the drives because I forgot, and low and behold all 3 drives are listed! Why is it listed there and not in ‘My Computer’? Mike |
| | #6 (permalink) |
| | Re: My sata hard drive does not appear in Vista "Mike" <Mike@xxxxxx> wrote in message news:CE39831C-23BD-4EBD-9AAC-AFD9E9A29A62@xxxxxx Quote: > Bob F, > I have 3 installed hard drives. The L is the only one that is sata, the > others are ata. They are all made by Maxtor. Here’s something I didn’t > notice > before. I went into ‘Device Manager’ to get the name of the drives because > I > forgot, and low and behold all 3 drives are listed! Why is it listed there > and not in ‘My Computer’? > > Mike > That's good work Mike. The Device Manager will help you configure (somewhat) drives before they are initialized and mounted. Then they will show up in "My Computer" as part of the OS. Now you can deal with them. You can initialize them and assign letters. When you do, they should mount (appear in My Computer). Can you handle it from here? -- BobF. |
| | #7 (permalink) |
| | Re: My sata hard drive does not appear in Vista Bob F, I might need some help there. It still doesn't show up in the Computer Management window. Mike |
| | #8 (permalink) |
| | Re: My sata hard drive does not appear in Vista "Mike" <Mike@xxxxxx> wrote in message news:77D4BBE7-74BB-4DE0-87C4-1FC657B7788F@xxxxxx Quote: > > Bob F, > > I might need some help there. It still doesn't show up in the Computer > Management window. > > Mike > Any data on these drive that you care about. I understand you found them in the Device Manager but don't see them in the Disk Management section of the Computer Manager. Is that the case? Do you have the Maxtor tools for the disks? You might be able to mount them that way. Seagate bought Maxtor so you can get the tools from that site. BTW, the reference to ATA drives has changed these days. The term is now ambiguous. They are either (Serial) SATA or (Parallel) PATA, also known as IDE. Since SATA came about the new PATA nomenclature showed up. Same IDE drive, just new name. SCSI drives seemed to have lost favor. -- BobF. |
| | #9 (permalink) |
| | Re: My sata hard drive does not appear in Vista Bob F, You wrote: "I understand you found them in the Device Manager but don't see them in the Disk Management section of the Computer Manager". This is correct. I 'm going over to the site now. I have way too much data that I can't replace on that drive. I can never seem to keep up with all these name changes! It seems strange that it shows in one place but not the other. Wish me luck! Mike Mike |
| | #10 (permalink) |
| | Re: My sata hard drive does not appear in Vista "Mike" <Mike@xxxxxx> wrote in message news:4D8324F5-2D5E-458B-8655-35C7159073CB@xxxxxx Quote: > Bob F, > > You wrote: > "I understand you found them in > the Device Manager but don't see them in the Disk Management section of > the > Computer Manager". This is correct. I 'm going over to the site now. I > have > way too much data that I can't replace on that drive. I can never seem to > keep up with all these name changes! It seems strange that it shows in one > place but not the other. Wish me luck! > > Mike > > Mike ok...good luck. -- BobF. |
| Vista Will NOT Recognize 2nd SATA Hard Drive! | Vista hardware & devices | |||
| Reinstalling Vista Ultimate on second SATA hard drive | Vista hardware & devices | |||
| Vista install can't see SATA hard drive | Vista installation & setup | |||
| Vista SATA II Hard Drive Installation Problem | Vista General | |||
| Can't see SATA XP Hard drive with in Vista 64bit | Vista hardware & devices | |||
