Vista - vista display problem
Old 05-17-2006   #1 (permalink)
Andre Da Costa [Extended64]
Re: vista display problem
Right click Desktop > Personalization > Display Settings > Advanced >
Adapter > List All Modes.... > select 1024 by 768, I would say running at
the highest Hertz you are allowed, mine is running at 75Hertz.
Andre
Windows Connected | http://www.windowsconnected.com
Extended64 | http://www.extended64.com
Blog | http://www.extended64.com/blogs/andre
http://spaces.msn.com/members/adacosta
"michael e dziatkowicz" <mnmma@comcast.net> wrote in message
news:ZPmdnUvSde7QS_bZnZ2dnUVZ_sednZ2d@comcast.com...
>I got into vista and got it to install. Was trying to change it to a higher
>resolution from 1024 to 12xx and well now i get a message saying this
>resolution is not supported across the screen in vista. How do I change
>back to 1024? I tried to in safe mode but when I rebooted the message was
>still there.
Old 05-17-2006   #2 (permalink)
Do a reinstall then.
Andre
news:2cednRJFQNXPe_bZnZ2dnUVZ_vydnZ2d@comcast.com...
>I can't even display the desktop. All I get is the message I indicated and
>a black screen, the mouse and keyboard won't respond.
> "Andre Da Costa [Extended64]" <andred25@hotmail.com> wrote in message
> news:OmvT2MieGHA.764@TK2MSFTNGP05.phx.gbl...
>> Andre
>>>higher resolution from 1024 to 12xx and well now i get a message saying
>>>this resolution is not supported across the screen in vista. How do I
>>>change back to 1024? I tried to in safe mode but when I rebooted the
>>>message was still there.
Old 05-18-2006   #3 (permalink)
Noozer
>still there.
It's your monitor displaying this message. Windows is still running fine -
you just can't see it.
Boot to safe mode and change the resolution to something low, like 800x600,
and also make sure that the refresh rate is 60. That should be enough to get
you back into the normal desktop.
Old 05-18-2006   #4 (permalink)
Robert Rixx
Have you tried restore to tha point that the video resolution worked?
"Noozer" <dont.spam@me.here> wrote in message
news:%23QantIjeGHA.5040@TK2MSFTNGP03.phx.gbl...
> 800x600, and also make sure that the refresh rate is 60. That should be
> enough to get you back into the normal desktop.
Old 05-18-2006   #5 (permalink)
Zack Whittaker
Nahh... if you can load up with "Last good configuration" on the boot menu -
that solved it for me when I screwed it up )
Zack Whittaker
» ZackNET Enterprises: www.zacknet.co.uk
» MSBlog on ResDev: www.msblog.org
» Vista Knowledge Base: www.vistabase.co.uk
» This mailing is provided "as is" with no warranties, and confers no
rights. All opinions expressed are those of myself unless stated so, and not
of my employer, best friend, Ghandi, my mother or my cat. Glad we cleared
that up!
--: Original message follows :--
news:%23QE7LuieGHA.4040@TK2MSFTNGP05.phx.gbl...
> Andre
>>> at the highest Hertz you are allowed, mine is running at 75Hertz.
>>> Andre
Old 05-18-2006   #6 (permalink)
Zack Whittaker
You're not able to change those properties in Safe Mode - try the "Last
Known Good Configuration" from the boot manager before Vista loads, that
worked for me.
Zack Whittaker
that up!
newsIOdnYIDya2-6_HZnZ2dnUVZ_vudnZ2d@comcast.com...
> I've tried changing it in safe mode, I haven't tried doing a restore point
> but the problem is I can't get to a restore point because I can only see
> the message when I boot to Vista.
> "Robert Rixx" <firerx@hotmail.com> wrote in message
> news:886D609F-0E03-44A2-84F6-CD45C1FDA813@microsoft.com...
>>> fine - you just can't see it.
Old 05-18-2006   #7 (permalink)
But that is unless he prompted to do so and it is not guaranteed to fix the
problem, especially under Vista.
Andre
"Zack Whittaker" <admin@zacknet.co.uk> wrote in message
news:eUvYFDoeGHA.4948@TK2MSFTNGP04.phx.gbl...
> worked for me.
> Zack Whittaker
> not
> that up!
>> point but the problem is I can't get to a restore point because I can
>> only see the message when I boot to Vista.
Old 05-18-2006   #8 (permalink)
Zack Whittaker
Of course it's not guaranteed - but it did work for me when their appeared
to be no other solution. To get the boot menu up, it's one of the Function
keys, but if you switch the power off half way through the boot screen then
on again, should come up with the available option )
Zack Whittaker
that up!
news:u8x$mooeGHA.1204@TK2MSFTNGP02.phx.gbl...
> the problem, especially under Vista.
> Andre
>> worked for me.
>> Zack Whittaker
>> not
>> that up!
>>>>>>saying this resolution is not supported across the screen in vista.
>>>>>>How do I change back to 1024? I tried to in safe mode but when I
>>>>>>rebooted the message was still there.
>>>>> be enough to get you back into the normal desktop.
Old 05-18-2006   #9 (permalink)
F8
Andre
news:O6MYzRqeGHA.3456@TK2MSFTNGP05.phx.gbl...
> then on again, should come up with the available option )
> Zack Whittaker
> not
> that up!
>> Andre
>>> worked for me.
>>> Zack Whittaker
>>> not
>>> cleared
>>> that up!
Old 05-18-2006   #10 (permalink)
Zack Whittaker
Aye that's the one - so many different F keys for different things... yikes
it can get muddling )
Zack Whittaker
that up!
news:%23RPZ1eqeGHA.3888@TK2MSFTNGP02.phx.gbl...
> F8
> Andre
>> appeared to be no other solution. To get the boot menu up, it's one of
>> the Function keys, but if you switch the power off half way through the
>> boot screen then on again, should come up with the available option )
>> Zack Whittaker
>> not
>> that up!
>>> Andre
>>>> that worked for me.
>>>> Zack Whittaker
>>>> and not
>>>> cleared
>>>> that up!
display driver problem in vista 64 Drivers
thumbnail display problem in Vista Vista General
Vista Display Problem Vista General
Win Vista (Beta 2) Desktop display problem Vista General
Vista IE error display page problem Vista General
