Vista - Help! Command Prompt box flashing like a strobe light on my screen
Old 03-10-2008   #1 (permalink)
Bookworm0383
Please help. The little black Command Prompt box is flashing on my screen
very quickly. There's also something flashing in the taskbar. Sometimes I can
open a window on top of the flashing, but other times I can't, and the
flashing window is on top. This prevents me from accessing the window I'm
trying to work in. I don't know what caused this to happen. I first noticed
it a couple of nights ago when I was trying to uninstall a toolbar I had
accidentally downloaded with some other software. The flashing began when I
tried to uninstall and nearly prevented me from completing the uninstall.
This makes me wonder if it's a virus, but my Nortan Security scan says I'm
all clear. I would greatly appreciate any assistance.
Old 03-10-2008   #2 (permalink)
Mark L. Ferguson
Re: Help! Command Prompt box flashing like a strobe light on my screen
Open the Start/.../system tools/"Internet Explorer(No Add ons)" icon. If the
flashing stops, use IE, tools menu "Manage Add-ons" to disable add ons till
it stops in the regular IE.
Was this helpful? Then click the Ratings button. Voting helps the web
interface.
http://www.microsoft.com/wn3/locales....htm#RateAPost
Mark L. Ferguson
"Bookworm0383" <Bookworm0383@xxxxxx> wrote in message
news:08EE0B78-32BD-4129-AE09-88DD43283046@xxxxxx
> can
> noticed
> I
Old 03-10-2008   #3 (permalink)
Bookworm0383
Opening the Internet Explorer (No Add ons) icon didn't stop the flashing. The
icon says my add-ons are disabled. When I go to IE Tools, Manage Add-ons,
they are all listed as enabled. I'm afraid I'm still very confused. Do you
think the flashing Command Prompt box is caused by something within Internet
Explorer? It flashes whether or not I'm online or using IE.
> interface.
> Mark L. Ferguson
> > can
> > noticed
> > I
Old 03-10-2008   #4 (permalink)
Mark L. Ferguson
The toolbar you downloaded sounds like some form of Malware to me. You will
have to try to remove it. I would try System Restore.
interface.
Mark L. Ferguson
news:6896683C-8065-4957-884E-E71332A0A88F@xxxxxx
> The
> Internet
>> the
>> till
>> interface.
>> Mark L. Ferguson
>> > screen
>> > I
>> > can
>> > I'm
>> > noticed
>> > had
>> > when
>> > I
>> > uninstall.
>> > I'm
Old 03-10-2008   #5 (permalink)
Bookworm0383
I tried System Restore twice and it didn't work. I was able to uninstall the
suspected toolbar after I noticed this problem, and the problem didn't stop.
I don't know if the problem is related to the toolbar or not, but that's when
I first noticed it. However, the persistence of the problem even after the
toolbar is removed makes me think it might be coincidence.
> interface.
> Mark L. Ferguson
> > The
> > Internet
> >> the
> >> till
> >> interface.
> >> Mark L. Ferguson
> >> > screen
> >> > I
> >> > can
> >> > I'm
> >> > noticed
> >> > had
> >> > when
> >> > I
> >> > uninstall.
> >> > I'm
Old 11-20-2008   #6 (permalink)
Vista HOme premium 32 bit
I found the answer to this problem by contacting HP.
It is caused by corrupt USB Composite Device driver.
To resolve:
1. Open Device Manager. ie. Start>Run>devmgmt.msc >Enter Or click Properties on My Computer Context menu. Open Device Manager.
2. Click on the + on Universal Serial Bus Controllers to expand
3. Uninstall USB Composite Device
4. There may be 2 or more of them listed. Uninstall all before restarting.
5. Restart Computer.
Worked for me. Hope this helps others
Dell - flashing amber light before post Vista hardware & devices
flashing light help Vista General
Command prompt for flashing a bios Vista performance & maintenance
Flashing led light Vista performance & maintenance
Command Prompt can be full-screen?? Vista General
