BLUE SCREEN - Driver Power State Driver
  1. #1
    Seidell23231 Guest
    I have had the Blue Screen of Death happen 3 times in the last 3 days! The
    error is identified as, "Driver Power State Driver". The recovery although
    fast is a pain and not good. When I select Visat to find a solution, it
    comes back and says the errror is from Microsoft and to ensure I have the
    updated driver and to get that by using the Windows Update program. I have
    downloaded everything available, still happens.
    Has this been happening to anyone else? My OS is Vista Ultimate 32-Bit.
    Thanks for the HELP ~~ Gunny
  2. #2
    Seidell23231 Guest
    RE: BLUE SCREEN - Driver Power State Driver
    We to MS Crash info and was directed to download 929762. Appartently it has
    to do with the PC coming out of sleep or hibernation. Now I know why mine
    was not.. Will see if this fixes it!
    Gunny
BLUE SCREEN - Driver Power State Driver problems?
BLUE SCREEN - Driver Power State Failure - PLS HELP ME songryong Vista General 1 14 Mar 2010
Power State Drive Failure and Blue Screen Hot Rod Todd Drivers 2 22 Nov 2009
driver power state failure mchrisokc Crashes and Debugging 13 27 Sep 2009
Driver Power State Failure.... Ninetyfourgoali Drivers 13 20 Sep 2009
Driver State Power Failure Xth09 Vista performance & maintenance 3 20 Aug 2009
