system properties doesn't show hardware configuration! HELP!
  1.    11 Mar 2008 #1
    This is so annoying..... Guest
    I'm running Windows Vista Ultimate 32-bit. I have a Dual-Core processor with
    1.83GHz and 2GB of RAM. My system rating is 4.6. The only problem is, when I
    go to my system properties in the control panel, it doesn't show any of this.
    after "Rating:" it's just a blank space. "Processor: Not Available", "Memory
    (RAM): Not Available). it shows me my system type but that's it. I know it
    recognizes it because the welcome is able to show it (RAM and processor). Is
    there a setting I changed somewhere that's causing this? How can I get it to
    show these again? Will SP1 solve this problem? Please help
  2.    12 Mar 2008 #2
    Mick Murphy Guest
    RE: system properties doesn't show hardware configuration! HELP!
    Start> Right-click on Computer>Properties.
    Mick Murphy - Qld - Australia
  3.    12 Mar 2008 #3
    That's where it's not showing it that it's supposed to.
  4.    10 Oct 2008 #4
    azntom616 Guest
    Re: system properties doesn't show hardware configuration! HELP!
    1- Open Command Prompt
    2- At the Command Prompt enter the following command exactly as
    written:
    net localgroup "Administrators" "NT Authority\Service" /add
    then press enter and you should be ready to go. It worked like a charm
    for
    me on the two PC's that were having the exact same problem......
    i got this from the vistax64 site
    it worked for me so i hope it works for other people
    azntom616
    azntom616's Profile: http://forums.techarena.in/members/azntom616.htm
    View this thread: http://forums.techarena.in/vista-help/930392.htm
show desktop doesn't show gadgets
Hey, the show desktop icon is pretty neat... I have brand new laptop and want to use the show desktop icon to quickly access my sidebar/gadgets. ...
Vista General
Modifying OEM properties listed in system properties
I have chased Vista through the xp 64 and the Vista Betas I have it where I need to be, 5.8 on the experience level. I have modified the information...
Vista installation & setup
User Field of Event properties Doesn't show UserName in windows Vi
Hi, When i am opening Eventviewer in windows vista.and Double click any events.User field in Event properties Shows N/A.Previously in windows 2000...
Vista account administration
DNS Server Properties Configuration/Listing
Hi, I need to list, check and configure about 40 DNS server forwarder settings. I have looked up WMI's...
VB Script
c# class configuration properties.
I am trying to find the best approach to handle class configurations. I have an application that handles plugins and need to determine if the...
.NET General
New Hardware Wizard Configuration
How can I change the way the Find New Hardware wizard defaults? It's set to "Search Windows Update" and I want to change it to search my...
Vista General
Changing Hardware Configuration
I added my old hard drive to my Windows Vista computer. This caused Vista to un-activate itself. I had to call in to reactivate it. That being...
Vista General
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • Old server
    About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
    Designer Media Ltd
