Vista - Clock Speed Slows Down
Old 03-12-2008   #1 (permalink)
Nav
I have recently (Feb08) got a Toshiba Laptop Satellite Pro M200 with MS Vista
Business 6.0.6000 OS. Offlate I have realized the clock on the Task Bar slows
down by a min every 2 days approximately.
Is there a way to improve the clock speed. I am anyway setting the clock
every 10 days on my system.
thanks
Nav
Old 03-12-2008   #2 (permalink)
Rick Rogers
Re: Clock Speed Slows Down
A slow clock while running is nearly always due to interference from another
bit of software. This usually turns out to be your antivirus solution, with
Symantec products being the biggest offender. Solutions? Either get used to
synching your clock more often, or find a different antivirus product. You
can confirm this by simply running with your av product disabled for a few
days.
In case you hear that it may be the CMOS battery, that would not be the
cause of a clock losing time while running. A dead or dying battery would
cause the system to lose track of the time while shut down and revert back
to a default setting each time it's booted. Once Windows is loaded and
running, control of the clock is not dependent on the system BIOS.
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Windows help - www.rickrogers.org
My thoughts http://rick-mvp.blogspot.com
"Nav" <Nav@xxxxxx> wrote in message
news:383D718B-5345-4C82-B415-00B9F35176CA@xxxxxx
>Vista
> slows
> thanks
> Nav
Old 03-12-2008   #3 (permalink)
bamboozle
windows can sync with internet clocks, make sure the service is running and
the time servers not bieing blocked by firewall
"Rick Rogers" <rick@xxxxxx> wrote in message
news:%23$ZpirChIHA.6032@xxxxxx
Quote:
> Hi,
> another bit of software. This usually turns out to be your antivirus
> solution, with Symantec products being the biggest offender. Solutions?
> Either get used to synching your clock more often, or find a different
> antivirus product. You can confirm this by simply running with your av
> product disabled for a few days.
> Best of Luck,
>>Vista
>> slows
>> thanks
>> Nav
Old 03-12-2008   #4 (permalink)
Quote  Quote: Originally Posted by Nav View Post
thanks
Nav
Hi Nav,
See if this may be able to help you.
Internet Time Synchronization Update Interval
Old 03-13-2008   #5 (permalink)
Nav
Thanks there to you all.
There is a problem in internet time synchronization. When I open the clock
-> third tab 'Internet Time' -> Check the synchro. box -> time.windows.com ->
click update now ---->>>>
the message that gets displayed is:
"An error occured while windows was synchronizing with time.windows.com. The
peer is unresolved"
However, I have already made the changes for 1 day (86400) in regedit.
Thanks again. If you know how to resolve, please do reply.
"Brink" wrote:
Quote:
> Nav;643867 Wrote:
> > Vista
> > slows
> > clock
> > thanks
> > Nav
> Hi Nav,
> Shawn
> Brink
> *There are no dumb questions, just the people that do not ask them.*
> '*Vista x64 Forums*'
> (http://www.vistax64.com/index.php?referrerid=2980)
> *Please post feedback to help others.*
Old 03-13-2008   #6 (permalink)
Nav
How do we make sure that time servers are not blocked by firewall. Sorry for
being so low on system knowledge. Really appreciate your help.
thanks
Quote:
> > Hi,
> > Best of Luck,
> >>Vista
> >> slows
> >> thanks
> >> Nav
Old 03-13-2008   #7 (permalink)
bamboozle
turn off the firewall you have and try pressing the button to see if it
works.
if it does it means its your firewall
then go to the site or help file of your firewall and learn how to add
"exceptions" so that it wont be blocked
news:C9B89E07-A684-44B7-B6DD-E1423A9D0F5D@xxxxxx
> time.windows.com ->
> The
> peer is unresolved"
> "Brink" wrote:
Quote:
>> Nav;643867 Wrote:
>> > Vista
>> > slows
>> > clock
>> > thanks
>> > Nav
>> Hi Nav,
>> Shawn
>> Brink
Help Vista problem/ double clock speed Drivers
Issue with gpu clock and memory clock Graphic cards
Vista won't show the correct CPU clock speed Vista performance & maintenance
second clock gadget to match clock 2 Vista General
How to check your Speed Boost tested memory speed Vista General
