| | #11 (permalink) |
| | Re: Major Troubles: Power Supply or Corrupt Install?? On Mar 12, 5:29 pm, Tyrenta <dougre...@xxxxxx> wrote: Quote: > .... So two questions: > 1) is it possible to 'blow' a PS by overloading it (I assume it is -- > the currrent supply is a 400w Antec smartpower 2 I think). > 2) even if I correct the PS -- it still seems my Windows install has > corrupted somehow, or could that all be explained by the PS? shorted together and power supply still must not be harmed. This being a load larger than everything in the computer combined. Intel specs even define how large this shorting wire must be - and no damage. Nothing in a computer should damage its power supply. And a properly designed power supply must never damage any other computer part. 2) An undersized power supply (causing low output voltages) will only make Windows appear defective. Windows should not be corrupted by an undersized (overloaded) supply. However if peripherals were not working properly, then Windows might not see them; might not load correct drivers for those peripherals. Did this happen? Answers are obtained from Device Manager and the system (event) logs. One correction from a previous posts. Provided low voltage numbers do not take into account how voltages are measured. Minimum voltages for a power supply must be measured when everything is being accessed (multitasked) simultaneously. IOW display complex graphics (ie a movie), while playing the sound card, while defragging a hard drive, while accessing a data on a floppy, while downloading from the internet, while reading from a CD, while ... all simultaneously. Now measure power supply voltages. Those numbers must exceed 3.23, 4.87, and 11.7 volts DC on any one of orange, red, purple, and yellow power supply wires. If not, then the power supply is either undersized or defective. |
| | #12 (permalink) |
| | Re: Major Troubles: Power Supply or Corrupt Install?? On Mar 14, 6:25 pm, w_tom <w_t...@xxxxxx> wrote: Quote: > On Mar 12, 5:29 pm,Tyrenta<dougre...@xxxxxx> wrote: > Quote: > > .... So two questions: > > 1) is it possible to 'blow' a PS by overloading it (I assume it is -- > > the currrent supply is a 400w Antec smartpower 2 I think). > > 2) even if I correct the PS -- it still seems my Windows install has > > corrupted somehow, or could that all be explained by the PS? > 1) Any power supply even 30 years ago could have all voltage outputs > shorted together and power supply still must not be harmed. This > being a load larger than everything in the computer combined. Intel > specs even define how large this shorting wire must be - and no > damage. Nothing in a computer should damage its power supply. And a > properly designed power supply must never damage any other computer > part. > > 2) An undersized power supply (causing low output voltages) will only > make Windows appear defective. Windows should not be corrupted by an > undersized (overloaded) supply. However if peripherals were not > working properly, then Windows might not see them; might not load > correct drivers for those peripherals. Did this happen? Answers are > obtained from Device Manager and the system (event) logs. > > One correction from a previous posts. Provided low voltage numbers > do not take into account how voltages are measured. Minimum voltages > for a power supply must be measured when everything is being accessed > (multitasked) simultaneously. IOW display complex graphics (ie a > movie), while playing the sound card, while defragging a hard drive, > while accessing a data on a floppy, while downloading from the > internet, while reading from a CD, while ... all simultaneously. Now > measure power supply voltages. Those numbers must exceed 3.23, 4.87, > and 11.7 volts DC on any one of orange, red, purple, and yellow power > supply wires. If not, then the power supply is either undersized or > defective. fine now, the caveat being I unplugged the 3 new RAID drives to see if that solved my current windows problems. it did not, so now it seems my voltages are OK with the new drives unplugged, but I still have the following issues: can no longer shut down (hangs) can't access Drive Manager from control panel (hangs) can't always launch IE (hangs trying to connect, or doesn't launch at all; is in processes though and other sw does get an internet connection i.e. Skype) can't launch the nVidia contol panel (hourglass then no window; but can see it start in processes) random reboots every 10-20min (i'm currently letting it sit in BIO to see if it reboots there) => basically seems to have trouble with any system / explorer functions as other software seems OK Voltage Rail Minimum Maximum 3.3VDC 3.14V 3.47V *3.4* 5.0VDC 4.75V 5.25V *5.12* 12.0VDC 11.40V 12.60V *12.75* 5.0VSB 4.75V 5.25V (Stand By) *vcore voltage 1.35* I tried the repair from DVD but it found no errors. I also tried a system restore with no change. two things to note also -- the nVivia control panel issue was my original issue, and the device manager was recognzing the new hardware with no errors. given that there are three new drives and the dm saw them I don't think it is a bad hardware issue per se. any ideas how I should proceed? Is there another way to reinstall/ repair vista so to spreak without having to do a full reinstall of all my software -- I'd really like to avoid this....I appreciate all your help. |
| | #13 (permalink) |
| | Re: Major Troubles: Power Supply or Corrupt Install?? On Mar 14, 7:15 pm, Tyrenta <dougre...@xxxxxx> wrote: Quote: > On Mar 14, 6:25 pm, w_tom <w_t...@xxxxxx> wrote: > > > Quote: > > On Mar 12, 5:29 pm,Tyrenta<dougre...@xxxxxx> wrote: Quote: Quote: > > > .... So two questions: > > > 1) is it possible to 'blow' a PS by overloading it (I assume it is -- > > > the currrent supply is a 400w Antec smartpower 2 I think). > > > 2) even if I correct the PS -- it still seems my Windows install has > > > corrupted somehow, or could that all be explained by the PS? Quote: > > 1) Any power supply even 30 years ago could have all voltage outputs > > shorted together and power supply still must not be harmed. This > > being a load larger than everything in the computer combined. Intel > > specs even define how large this shorting wire must be - and no > > damage. Nothing in a computer should damage its power supply. And a > > properly designed power supply must never damage any other computer > > part. Quote: > > 2) An undersized power supply (causing low output voltages) will only > > make Windows appear defective. Windows should not be corrupted by an > > undersized (overloaded) supply. However if peripherals were not > > working properly, then Windows might not see them; might not load > > correct drivers for those peripherals. Did this happen? Answers are > > obtained from Device Manager and the system (event) logs. Quote: > > One correction from a previous posts. Provided low voltage numbers > > do not take into account how voltages are measured. Minimum voltages > > for a power supply must be measured when everything is being accessed > > (multitasked) simultaneously. IOW display complex graphics (ie a > > movie), while playing the sound card, while defragging a hard drive, > > while accessing a data on a floppy, while downloading from the > > internet, while reading from a CD, while ... all simultaneously. Now > > measure power supply voltages. Those numbers must exceed 3.23, 4.87, > > and 11.7 volts DC on any one of orange, red, purple, and yellow power > > supply wires. If not, then the power supply is either undersized or > > defective. > thanks all -- I checked the voltages from BIOS and everything seems > fine now, the caveat being I unplugged the 3 new RAID drives to see if > that solved my current windows problems. it did not, so now it seems > my voltages are OK with the new drives unplugged, but I still have the > following issues: > > can no longer shut down (hangs) > can't access Drive Manager from control panel (hangs) > can't always launch IE (hangs trying to connect, or doesn't launch at > all; is in processes though and other sw does get an internet > connection i.e. Skype) > can't launch the nVidia contol panel (hourglass then no window; but > can see it start in processes) > random reboots every 10-20min (i'm currently letting it sit in BIO to > see if it reboots there) > => basically seems to have trouble with any system / explorer > functions as other software seems OK > > Voltage Rail Minimum Maximum > 3.3VDC 3.14V 3.47V *3.4* > 5.0VDC 4.75V 5.25V *5.12* > 12.0VDC 11.40V 12.60V *12.75* > 5.0VSB 4.75V 5.25V (Stand By) > *vcore voltage 1.35* > > I tried the repair from DVD but it found no errors. I also tried a > system restore with no change. > > two things to note also -- the nVivia control panel issue was my > original issue, and the device manager was recognzing the new hardware > with no errors. given that there are three new drives and the dm saw > them I don't think it is a bad hardware issue per se. > > any ideas how I should proceed? Is there another way to reinstall/ > repair vista so to spreak without having to do a full reinstall of all > my software -- I'd really like to avoid this....I appreciate all your > help. me if anything is not running properly in windows? |
| | #14 (permalink) |
| | Re: Major Troubles: Power Supply or Corrupt Install?? BIOS cannot measure accurate voltage. It is a monitor. Its purpose is to detect change; therefore not calibrated. BIOS is not sufficient until calibrated by the same required tool - a 3.5 digit multimeter. Voltage measurements are mostly useless if every system component is not included AND accessed. IOW change no hardware; disconnect nothing. Power supply must have a maximum load when measured. Execute (multitask) to everything (or as much as possible) to measure voltages. Do nothing else yet since everything (as those symptoms demonstrate) tell us nothing useful without first establishing the power supply 'system' as 'definitively good'. Objective is to, step by step, move each component or sub-system from 'unknown' to either 'definitively good' or 'definitively bad'. Power system is still unknown. An 'unknown' power system means everything else remains unknown. Note the word 'system'. Supply is only one component of a 'system' that must be 'definitively good' before anything else can be diagnosed. No reason exists to suspect Vista (yet) because most everything (hardware and software) is 'unknown'. Break a problem down into parts. Then move each part from 'unknown' to 'definitively something'. With a complex problem, then simplify it. Avoid Windows completely - first establish hardware integrity. Ignore those other Control Panels, etc. that are not yet relevant. Essential at this point was information from Device Manager and from system (event) log. Neither will be 'complicated' by Windows (but require Windows to read that stored information). Both are also essential information. Planning for the next step: Hardware that can crash Windows is a shorter list of sound card, video processor, CPU, memory, power supply, and some motherboard functions. Disk drives and many other computer parts are not on that list. These hardware require diagnostics (without Windows) to verify integrity - move it from 'unknown'. If your computer is not from a responsible manufacturer, then a full system comprehensive hardware diagnostic does not exist. So hardware diagnostics are obtained, one by one, from component manufacturers or from third parties. For example, video processor diagnostic is from nVidia. Memory diagnostic is from a third party - memtst86. A useful diagnostic executes without the complications of Windows - to break a problem down into parts. Start collecting relevant hardware diagnostics. On Mar 14, 6:15 pm, Tyrenta <dougre...@xxxxxx> wrote: Quote: > thanks all -- I checked the voltages from BIOS and everything seems > fine now, the caveat being I unplugged the 3 new RAID drives to see if > that solved my current windows problems. it did not, so now it seems > my voltages are OK with the new drives unplugged, but I still have the > following issues: > > can no longer shut down (hangs) > can't access Drive Manager from control panel (hangs) > can't always launch IE (hangs trying to connect, or doesn't launch at > all; is in processes though and other sw does get an internet > connection i.e. Skype) > can't launch the nVidia contol panel (hourglass then no window; but > can see it start in processes) > random reboots every 10-20min (i'm currently letting it sit in BIO to > see if it reboots there) > => basically seems to have trouble with any system / explorer > functions as other software seems OK > > Voltage Rail Minimum Maximum > 3.3VDC 3.14V 3.47V *3.4* > 5.0VDC 4.75V 5.25V *5.12* > 12.0VDC 11.40V 12.60V *12.75* > 5.0VSB 4.75V 5.25V (Stand By) > *vcore voltage 1.35* > > I tried the repair from DVD but it found no errors. I also tried a > system restore with no change. > > two things to note also -- the nVivia control panel issue was my > original issue, and the device manager was recognzing the new hardware > with no errors. given that there are three new drives and the dm saw > them I don't think it is a bad hardware issue per se. > > any ideas how I should proceed? Is there another way to reinstall/ > repair vista so to spreak without having to do a full reinstall of all > my software -- I'd really like to avoid this....I appreciate all your > help. |
| Power supply help | Software | |||
| Bad power supply?? | Vista music pictures video | |||
| Power Supply | General Discussion | |||
| Hi & Power Supply | Chillout Room | |||
| Install UPS (uninterruptable power supply) in Vista | Vista hardware & devices | |||
