| | Need help with a downgrade of Vista Home Premium to XP!!! Hello all, As I have said in my other posts I am having a lot of trouble with my new computer and Windows Vista. The trouble is I can't find anyone willing or able to work on a Vista OPS. I'm not able to stream live events from EspN360.COM or NBA League Pass Broadband on NBA.com. So I would like to install my old XP Pro. I got everything into the computer last night and I guess I was missing some drivers, because my cpu wouldn't read the PCI or video card, and it wouldn't even allow me to go into sleep mode, as well as not get onto the internet. So I reinstalled Vista, and of course I'm still having the same problems. I should have wrote down what all I was in need of on XP but it was 430 in the morning and apparently I was pretty tired. If you could help me figure this out and possibly give me a step by step process of what I really need to do to do this correctly I would be extremely grateful and possibly be in "AWE" of you and your skills! Here are my computer's spec's just in case: GATEWAY GT5622 3 GIGS of DDR2 Dual Channel MemoryRAM 2160 Dual core processor (1.8) 400 GB SATA II Hard Drive 15 in 1 memory card reader Intel Graphics Media Accelerator 950 Video Windows Vista Home Premium 32 bit edition Thanks and God Bless! |
| | Re: Need help with a downgrade of Vista Home Premium to XP!!! You need to install Java in order to effectively view the web sites you mentioned. Free Java download: http://www.java.com/en/download/index.jsp -- Carey Frisch Microsoft MVP Windows Shell/User --------------------------------------------------------------- "Lloyd Denny" wrote: Hello all, As I have said in my other posts I am having a lot of trouble with my new computer and Windows Vista. The trouble is I can't find anyone willing or able to work on a Vista OPS. I'm not able to stream live events from EspN360.COM or NBA League Pass Broadband on NBA.com. So I would like to install my old XP Pro. I got everything into the computer last night and I guess I was missing some drivers, because my cpu wouldn't read the PCI or video card, and it wouldn't even allow me to go into sleep mode, as well as not get onto the internet. So I reinstalled Vista, and of course I'm still having the same problems. I should have wrote down what all I was in need of on XP but it was 430 in the morning and apparently I was pretty tired. If you could help me figure this out and possibly give me a step by step process of what I really need to do to do this correctly I would be extremely grateful and possibly be in "AWE" of you and your skills! Here are my computer's spec's just in case: GATEWAY GT5622 3 GIGS of DDR2 Dual Channel MemoryRAM 2160 Dual core processor (1.8) 400 GB SATA II Hard Drive 15 in 1 memory card reader Intel Graphics Media Accelerator 950 Video Windows Vista Home Premium 32 bit edition Thanks and God Bless! |
| | Re: Need help with a downgrade of Vista Home Premium to XP!!! "Carey Frisch [MVP]" <cnfrisch@xxxxxx> wrote in message news:ecXw7fGhIHA.484@xxxxxx Quote: > You need to install Java in order to effectively view the > web sites you mentioned. > > Free Java download: http://www.java.com/en/download/index.jsp I could not see any need for Java, but he might as well install it anyway. He certainly needs the Flash Player though: http://www.adobe.com/products/flashplayer/ ss. |
| | Re: Need help with a downgrade of Vista Home Premium to XP!!! Lloyd Denny wrote: Quote: > Hello all, > As I have said in my other posts I am having a lot of trouble with my new > computer and Windows Vista. The trouble is I can't find anyone willing or > able to work on a Vista OPS. I'm not able to stream live events from > EspN360.COM or NBA League Pass Broadband on NBA.com. So I would like to > install my old XP Pro. I got everything into the computer last night and I > guess I was missing some drivers, because my cpu wouldn't read the PCI or > video card, and it wouldn't even allow me to go into sleep mode, as well > as not get onto the internet. So I reinstalled Vista, and of course I'm > still having the same problems. I should have wrote down what all I was in > need of on XP but it was 430 in the morning and apparently I was pretty > tired. If you could help me figure this out and possibly give me a step by > step process of what I really need to do to do this correctly I would be > extremely grateful and possibly be in "AWE" of you and your skills! > > Here are my computer's spec's just in case: > GATEWAY GT5622 > 3 GIGS of DDR2 Dual Channel MemoryRAM > 2160 Dual core processor (1.8) > 400 GB SATA II Hard Drive > 15 in 1 memory card reader > Intel Graphics Media Accelerator 950 Video > Windows Vista Home Premium 32 bit edition see this general guidelines for replacing Vista with XP: A. On an OEM (HP, Sony, etc.) computer: 1. Go to the OEM's website and look for XP drivers for your specific model computer. If there are no XP drivers, then you can't install XP. End of story. If there are drivers, download them and store on a CD-R or USB thumbdrive; you'll need them after you install XP. 2. Check with the OEM - either from their tech support website or by calling them - to see if you will void your warranty if you do this. If you will void the warranty, you make the decision. 3. If the OEM does support XP on the machine, call them and see if you can have downgrade rights and have them send you an XP restore disk. This will be far the easiest and best way of getting XP on the machine. 4. If XP is supported on the machine but the OEM doesn't have an XP restore disk for you, understand that you'll need to purchase a retail copy of XP from your favorite online or brick/mortar store. 5. Also understand that you will need to do a clean install of XP so if you have any data you want, back it up first. 6. If none of the above is applicable to you because you can't run XP on that machine (see Item #1 above), return the computer and purchase one running XP instead. B. On a generic/home-built computer (from non-OEM company) - You will need drivers for all your hardware. See the second link below for more details: http://michaelstevenstech.com/cleanxpinstall.html - Clean Install How-To http://www.elephantboycomputers.com/...alling_Windows - What you will need on-hand Malke -- MS-MVP Elephant Boy Computers www.elephantboycomputers.com Don't Panic! |
| Can You Downgrade from vista ultimate to home premium? | Vista performance & maintenance | |||
| Downgrade from Vista Home Premium to Home Basic | Vista General | |||
| Downgrade Vista Home Premium to XP Home | Vista installation & setup | |||
| Downgrade - Vista Home Premium to XP | Vista installation & setup | |||
| Downgrade from Vista Home Premium to XP legal? | Vista installation & setup | |||
