| | Taskbar is stuck in up position I have had my taskbar set to auto-hide and everything has worked fine, now it is stuck in the up position and will not hide. I have not changed any settings (auto-hide, taskbar on top, group similar items are checked.). I have tried unchecking taskbar on top to no avail. Help Please. -- Thanks... Bob |
| | Re: Taskbar is stuck in up position Try unlocking the taskbar and unchecking the items you mention. Restart the computer and try checking them again. If that doesn't clear things, you should be able to use system restore to before your problem to correct the problem. "Bob Newman" <bobnewman@xxxxxx> wrote in message news:PbkCj.32750$y05.4627@xxxxxx Quote: >I have had my taskbar set to auto-hide and everything has worked fine, now >it is stuck in the up position and will not hide. I have not changed any >settings (auto-hide, taskbar on top, group similar items are checked.). I >have tried unchecking taskbar on top to no avail. Help Please. > > -- > Thanks... Bob |
| | Re: Taskbar is stuck in up position Thanks, the reboot worked. Bob "John Barnes" <jbarnes@xxxxxx> wrote in message news:%23BPphFXhIHA.2084@xxxxxx Quote: > Try unlocking the taskbar and unchecking the items you mention. Restart > the computer and try checking them again. If that doesn't clear things, > you should be able to use system restore to before your problem to correct > the problem. > > "Bob Newman" <bobnewman@xxxxxx> wrote in message > news:PbkCj.32750$y05.4627@xxxxxx Quote: >>I have had my taskbar set to auto-hide and everything has worked fine, now >>it is stuck in the up position and will not hide. I have not changed any >>settings (auto-hide, taskbar on top, group similar items are checked.). I >>have tried unchecking taskbar on top to no avail. Help Please. >> >> -- >> Thanks... Bob |
| Vista Home Premium 64bit. | Re: Taskbar is stuck in up position Taskbar is stuck in up position permalink I have had my taskbar set to auto-hide and everything has worked fine, now it is stuck in the up position and will not hide. I have not changed any settings (auto-hide, taskbar on top, group similar items are checked.). I have tried unchecking taskbar on top to no avail. Help Please. -- Thanks... Bob ----------------------------------------------------------------------- Wish I had this problem wuaaaahahahahaha Last edited by Brian88135; 03-13-2008 at 11:16 PM.. Reason: forgot something |
| | Re: Taskbar is stuck in up position On Thu, 13 Mar 2008 21:56:41 -0400, "Bob Newman" <bobnewman@xxxxxx> wrote: Quote: > Thanks, the reboot worked. It's good to remember that rebooting solves many such problems. It's almost always worth trying as a first step whenever anything doesn't work the way you expect it to. Quote: > "John Barnes" <jbarnes@xxxxxx> wrote in message > news:%23BPphFXhIHA.2084@xxxxxx Quote: > > Try unlocking the taskbar and unchecking the items you mention. Restart > > the computer and try checking them again. If that doesn't clear things, > > you should be able to use system restore to before your problem to correct > > the problem. > > > > "Bob Newman" <bobnewman@xxxxxx> wrote in message > > news:PbkCj.32750$y05.4627@xxxxxx Quote: > >>I have had my taskbar set to auto-hide and everything has worked fine, now > >>it is stuck in the up position and will not hide. I have not changed any > >>settings (auto-hide, taskbar on top, group similar items are checked.). I > >>have tried unchecking taskbar on top to no avail. Help Please. > >> > >> -- > >> Thanks... Bob Ken Blake, Microsoft MVP - Windows Desktop Experience Please Reply to the Newsgroup |
| | #6 (permalink) |
| | Re: Taskbar is stuck in up position On Mar 14, 4:42*pm, "Ken Blake, MVP" <kbl...@xxxxxx> wrote: Quote: > On Thu, 13 Mar 2008 21:56:41 -0400, "Bob Newman" <bobnew...@xxxxxx> > wrote: > Quote: > > Thanks, the reboot worked. > It's good to remember that rebooting solves many such problems. It's > almost always worth trying as a first step whenever anything doesn't > work the way you expect it to. > > > > > Quote: > > "John Barnes" <jbar...@xxxxxx> wrote in message > >news:%23BPphFXhIHA.2084@xxxxxx Quote: > > > Try unlocking thetaskbarand unchecking the items you mention. *Restart > > > the computer and try checking them again. *If that doesn't clear things, > > > you should be able to use system restore to before your problem to correct > > > the problem. Quote: Quote: > > > "Bob Newman" <bobnew...@xxxxxx> wrote in message > > >news:PbkCj.32750$y05.4627@xxxxxx > > >>I have had mytaskbarset to auto-hide and everything has worked fine, now > > >>it isstuckin the up position and will not hide. *I have not changed any > > >>settings (auto-hide,taskbaron top, group similar items are checked.). *I > > >>have tried uncheckingtaskbaron top to no avail. *Help Please. Quote: Quote: > > >> -- > > >> Thanks... Bob > -- > Ken Blake, Microsoft MVP - Windows Desktop Experience > Please Reply to the Newsgroup- Hide quoted text - > > - Show quoted text - (with Vista Home Premium SP1) a few days ago. Rebooting is not a solution (even though it has been Microsoft's solution to everything since Windows 3.0) if I'm not willing to reboot every hour. Isn't there a REAL solution somewhere? Doug Patterson |
| | #7 (permalink) |
| Home premium 32 bit, SP1 | Re: Taskbar is stuck in up position On Mar 14, 4:42*pm, "Ken Blake, MVP" <kbl...@xxxxxx> wrote: Quote: > On Thu, 13 Mar 2008 21:56:41 -0400, "Bob Newman" <bobnew...@xxxxxx> > wrote: > > > It's good to remember that rebooting solves many such problems. It's > almost always worth trying as a first step whenever anything doesn't > work the way you expect it to. > > > > > > > > > -- > Ken Blake, Microsoft MVP - Windows Desktop Experience > Please Reply to the Newsgroup- Hide quoted text - > > - Show quoted text - (with Vista Home Premium SP1) a few days ago. Rebooting is not a solution (even though it has been Microsoft's solution to everything since Windows 3.0) if I'm not willing to reboot every hour. Isn't there a REAL solution somewhere? Doug Patterson John also suggested system restore. Have you tried that ? |
| | #8 (permalink) |
| | Re: Taskbar is stuck in up position On Apr 26, 8:56*pm, t-4-2 <gu...@xxxxxx-email.com> wrote: Quote: > drpatt;695204 Wrote: > > > Quote: > > On Mar 14, 4:42*pm, "Ken Blake, MVP" > > <kbl...@xxxxxx> wrote:> > > Quote: > > > > On Thu, 13 Mar 2008 21:56:41 -0400, "Bob Newman" <bobnew...@xxxxxx> > > > > wrote: Quote: Quote: > > > > It's good to remember that rebooting solves many such problems. It's > > > > almost always worth trying as a first step whenever anything doesn't > > > > work the way you expect it to. Quote: Quote: > > > > -- > > > > Ken Blake, Microsoft MVP - Windows Desktop Experience > > > > Please Reply to the Newsgroup- Hide quoted text - Quote: Quote: > > > > - Show quoted text - > > Quote: > > I have the same problem and have had it since I bought the laptop > > (with Vista Home Premium SP1) a few days ago. Rebooting is not a > > solution (even though it has been Microsoft's solution to everything > > since Windows 3.0) if I'm not willing to reboot every hour. Isn't > > there a REAL solution somewhere? Quote: > > Doug Patterson > Hello Doug, > John also suggested system restore. Have you tried that ? > > -- > t-4-2- Hide quoted text - > > - Show quoted text - system. It still sounds like a band-aid instead of a real fix. My real fix may be to revert to XP! |
| | #9 (permalink) |
| Home premium 32 bit, SP1 | Re: Taskbar is stuck in up position On Apr 26, 8:56*pm, t-4-2 <gu...@xxxxxx-email.com> wrote: Quote: > drpatt;695204 Wrote: > > > > > > > > > > Hello Doug, > John also suggested system restore. Have you tried that ? > > -- > t-4-2- Hide quoted text - > > - Show quoted text - system. It still sounds like a band-aid instead of a real fix. My real fix may be to revert to XP! Perhaps I should clarify one point. System restore is meant to UN-do changes made which might, or might not, cause the irregularities. It's not a band-aid solution, as you put it. Do it methodically, we could pinpoit the culprit. Thank you. |
| | #10 (permalink) |
| Vista Ultimate x32 | Re: Taskbar is stuck in up position hi, honestly, these "quote" windows are super boring, a waste of time and space, a delay of navigation, and more annoying then a parrot. Do you use them for playing? Just Drpatt uses and abuses showing these around with addition, when it comes to read, it ends up with a few lines...is it going to be like this all the time around here? Thank you. |
| IE8 gets the Prime position | Browsers & Mail | |||
| Taskbar gets stuck. | Vista General | |||
| Get the position in a DataGridView | .NET General | |||
| Windows toolbars stuck to the taskbar? | Vista General | |||
| how to show taskbar button on the taskbar-plz don't think I am jok | Vista performance & maintenance | |||
