| | Home Premium over XP Pro? Hello, I have a product key for Home Premium. My husbands laptop has XP PRO on it. It is my understanding that one cannot do and *Upgrade* from XP Pro to Home Premium and a clean install is necessary. Is that correct? Any way around that if so? Thanks. |
| | Re: Home Premium over XP Pro? Only Vista Business or Vista Ultimate can perform an upgrade over an existing Windows XP Professional installation. Vista Home Premium edition would require a "clean install". Q. Any way around that if so? A. No. -- Carey Frisch Microsoft MVP Windows Shell/User --------------------------------------------------------------- "Peggy" wrote: Hello, I have a product key for Home Premium. My husbands laptop has XP PRO on it. It is my understanding that one cannot do and *Upgrade* from XP Pro to Home Premium and a clean install is necessary. Is that correct? Any way around that if so? Thanks. |
| Windows 7 RC | Re: Home Premium over XP Pro? I would first confirm the hardware in the laptop before installing Vista. Vista is an excellent OS, but needs lots of top end hardware to run smoothly. You can visit this Microsoft website that will evaluate your computer for a Vista upgrade: Windows Vista: Upgrade Advisor And if the computer meets the recommended specifications, you would be advised to backup any important data first, then do a clean install. I've heard that a clean install is preferred over an upgrade from many sources. I hope this helps. |
| Windows Vista x64 Ultimate | Re: Home Premium over XP Pro? If this is the case, the yes, you can upgrade from XP Pro to Vista H.P. But the are some rather important rules that must be adhered to first:
Download details: Windows Vista Upgrade Advisor |
| | Re: Home Premium over XP Pro? Installation choices for Windows XP Professional Editions Upgrade: If you have Windows XP Professional installed, you can upgrade to the following versions of Windows Vista: ..Windows Vista Business ..Windows Vista Ultimate Ref: http://support.microsoft.com/kb/932616 -- Carey Frisch Microsoft MVP Windows Shell/User --------------------------------------------------------------- "dzomlija" wrote: The only time you cannot perform an "upgrade" install is if you try to upgrade from a 32-Bit OS like XP to Vista x64. You didn't mention which you have, so I'm assuming that you have Vista Home Premium 32-Bit. If this is the case, the yes, you can upgrade from XP Pro to Vista H.P. But the are some rather important rules that must be adhered to first: - *Backup ALL important data (My Document, e-mails, contacts, etc) before you proceed with either an upgrade or clean install.* - Contact the laptop manufacturer (their website is the best option) and verify that you can get Vista-certified drivers for all the devices of the computer. This must be done regardless of whether you do an upgrade install, or a clean install. - For whatever external devices you have (printers, scanner, 3G modems, etc), you should also verify first that each has Vista certified drivers available for download. - Make a list of all the key software that you and your husband use every day one the laptop, and verify with those manufacturers if the programs will work unchanged, or require some form of updates first. Office 2003 is one such program.You might want to download and install the Windows Vista Upgrade Advisor to help with this task. Just remember that it serves as a guideline only, and it's results highlight where you -may- have problems. It's results are best used together with a manual check at each relevant manufacturer of hardware and software, as I've explained above. 'Download details: Windows Vista Upgrade Advisor' (http://www.microsoft.com/downloads/d...DisplayLang=en) -- dzomlija |
| | #6 (permalink) |
| | Re: Home Premium over XP Pro? Thanks for the great tips everyone! Will do! Peggy "Carey Frisch [MVP]" <cnfrisch@xxxxxx> wrote in message news:uPpO6tehIHA.748@xxxxxx Quote: > Installation choices for Windows XP Professional Editions > > Upgrade: > > If you have Windows XP Professional installed, you can upgrade > to the following versions of Windows Vista: > > .Windows Vista Business > .Windows Vista Ultimate > > Ref: http://support.microsoft.com/kb/932616 > > > -- > Carey Frisch > Microsoft MVP > Windows Shell/User > > --------------------------------------------------------------- > > "dzomlija" wrote: > > The only time you cannot perform an "upgrade" install is if you try to > upgrade from a 32-Bit OS like XP to Vista x64. You didn't mention which > you have, so I'm assuming that you have Vista Home Premium 32-Bit. > > If this is the case, the yes, you can upgrade from XP Pro to Vista H.P. > But the are some rather important rules that must be adhered to first: > > - *Backup ALL important data (My Document, e-mails, contacts, etc) > before you proceed with either an upgrade or clean install.* > - Contact the laptop manufacturer (their website is the best option) > and verify that you can get Vista-certified drivers for all the > devices of the computer. This must be done regardless of whether you > do an upgrade install, or a clean install. > - For whatever external devices you have (printers, scanner, 3G > modems, etc), you should also verify first that each has Vista > certified drivers available for download. > - Make a list of all the key software that you and your husband use > every day one the laptop, and verify with those manufacturers if the > programs will work unchanged, or require some form of updates first. > Office 2003 is one such program.You might want to download and install > the Windows Vista Upgrade Advisor > to help with this task. Just remember that it serves as a guideline > only, and it's results highlight where you -may- have problems. It's > results are best used together with a manual check at each relevant > manufacturer of hardware and software, as I've explained above. > > 'Download details: Windows Vista Upgrade Advisor' > (http://www.microsoft.com/downloads/d...DisplayLang=en) > > > -- > dzomlija > > |
| | #7 (permalink) |
| | Re: Home Premium over XP Pro? Thanks dzomlija, but I am curious about what you mean about Office 2003 which is what he indeed does have. Are there issues with Office 2003? I did previously run the Advisor and it didn't state any problems with it. Have you experienced differently? Thanks again. Peggy "dzomlija" <dzomlija.369rh3@xxxxxx-mx.forums.net> wrote in message news:dzomlija.369rh3@xxxxxx-mx.forums.net... Quote: > > Peggy;646525 Wrote: Quote: >> Hello, >> I have a product key for Home Premium. My husbands laptop has XP PRO >> on it. >> It is my understanding that one cannot do and *Upgrade* from XP Pro to >> Home >> Premium and a clean install is necessary. Is that correct? Any way >> around >> that if so? Thanks. > The only time you cannot perform an "upgrade" install is if you try to > upgrade from a 32-Bit OS like XP to Vista x64. You didn't mention which > you have, so I'm assuming that you have Vista Home Premium 32-Bit. > > If this is the case, the yes, you can upgrade from XP Pro to Vista H.P. > But the are some rather important rules that must be adhered to first: > > - *Backup ALL important data (My Document, e-mails, contacts, etc) > before you proceed with either an upgrade or clean install.* > - Contact the laptop manufacturer (their website is the best option) > and verify that you can get Vista-certified drivers for all the > devices of the computer. This must be done regardless of whether you > do an upgrade install, or a clean install. > - For whatever external devices you have (printers, scanner, 3G > modems, etc), you should also verify first that each has Vista > certified drivers available for download. > - Make a list of all the key software that you and your husband use > every day one the laptop, and verify with those manufacturers if the > programs will work unchanged, or require some form of updates first. > Office 2003 is one such program.You might want to download and install > the Windows Vista Upgrade Advisor > to help with this task. Just remember that it serves as a guideline > only, and it's results highlight where you -may- have problems. It's > results are best used together with a manual check at each relevant > manufacturer of hardware and software, as I've explained above. > > 'Download details: Windows Vista Upgrade Advisor' > (http://www.microsoft.com/downloads/d...DisplayLang=en) > > > -- > dzomlija > > _____________________ > Peter Alexander Dzomlija > -Do you hear, huh? The Alpha and The Omega? Death and Rebirth? And as > you die, so shall I be Reborn...- > > -U--nfortunately, my rig (As seen in> Show us your rig) > went south thanks to mother nature and a lightning bolt to the mains > supply that my UPS could not stop. Now I'm just waiting for the > insurance payout, so I can build a new machine.-' > ' (http://s229.photobucket.com/albums/e...zomlija/Venus/) |
| | #8 (permalink) |
| Windows Vista x64 Ultimate | Re: Home Premium over XP Pro? Thanks dzomlija, but I am curious about what you mean about Office 2003 which is what he indeed does have. Are there issues with Office 2003? I did previously run the Advisor and it didn't state any problems with it. Have you experienced differently? Thanks again. Peggy That was over a year ago... |
| | #9 (permalink) |
| | Re: Home Premium over XP Pro? OK thank you very much for your reply. Peggy "dzomlija" <dzomlija.369tk1@xxxxxx-mx.forums.net> wrote in message news:dzomlija.369tk1@xxxxxx-mx.forums.net... Quote: > > Peggy;646609 Wrote: Quote: >> Thanks dzomlija, but I am curious about what you mean about Office 2003 >> which is what he indeed does have. Are there issues with Office 2003? >> I did previously run the Advisor and it didn't state any problems with >> it. Have you experienced differently? >> Thanks again. >> Peggy > Outlook 2003 has some minor compatibility issues with Vista. The rest > of the Office 2003 suite (Word, Excel, etc) works just great. I can't > really give many specifics, because I only used Office 2003 for about 2 > weeks or so after changing to Vista. I went for Office 2007. > > That was over a year ago... > > > -- > dzomlija > > _____________________ > Peter Alexander Dzomlija > -Do you hear, huh? The Alpha and The Omega? Death and Rebirth? And as > you die, so shall I be Reborn...- > > -U--nfortunately, my rig (As seen in> Show us your rig) > went south thanks to mother nature and a lightning bolt to the mains > supply that my UPS could not stop. Now I'm just waiting for the > insurance payout, so I can build a new machine.-' > ' (http://s229.photobucket.com/albums/e...zomlija/Venus/) |
| | #10 (permalink) |
| | Re: Home Premium over XP Pro? On Fri, 14 Mar 2008 10:40:16 -0500, dzomlija <dzomlija.369rh3@xxxxxx-mx.forums.net> wrote: Quote: > > Peggy;646525 Wrote: Quote: > > Hello, > > I have a product key for Home Premium. My husbands laptop has XP PRO > > on it. > > It is my understanding that one cannot do and *Upgrade* from XP Pro to > > Home > > Premium and a clean install is necessary. Is that correct? Any way > > around > > that if so? Thanks. > The only time you cannot perform an "upgrade" install is if you try to > upgrade from a 32-Bit OS like XP to Vista x64. You didn't mention which > you have, so I'm assuming that you have Vista Home Premium 32-Bit. > > If this is the case, the yes, you can upgrade from XP Pro to Vista H.P. > But the are some rather important rules that must be adhered to first: Sorry, this is *not* correct. The 32-bit to 64-bit issue is only one of several invalid upgrade paths. Upgrading from a Professional operating system version to a Home one (such as XP Professional to Vista Home Premium) is not supported. Similarly, a generation earlier, one could not upgrade from Windows 2000 Professional to XP Home. -- Ken Blake, Microsoft MVP - Windows Desktop Experience Please Reply to the Newsgroup |
| Home Premium -> Ultimate; Can I use the old Home Premium license? | Vista installation & setup | |||
| Remote Access from Vista Home Premium to Vista Home Premium and XP Home Edition | Network & Sharing | |||
| Updating from Home Premium to Ultimate and moving Home Premium | Vista installation & setup | |||
| Retail 32bit vista Home Premium upgrade to 64 bit Home Premium - H | Vista General | |||
| Windows XP Home (Full Vers.) to Vista Home Premium Upgrade (Academ | Vista General | |||
