| Guest | Monitor resolution forcibly changed after resuming from sleep whenusing KVM - how to fix? Hello, I put the computer to sleep using the Sleep option on the Vista start menu. I then, at a later time, wake up the computer. If the KVM switch is currently set to this PC Windows will resume normally and the login screen appears. If the KVM switch is set to my other PC Windows will resume and the login screen appears. However once I login Vista changes the monitore resolution from the monitor's native 1680 x 1050 to 1280 x 960. Presumably the KVM switch doesn't provide the same list of video modes via ESSID as the monitor. So my question is: How do I stop Vista from changing the resolution? OR How do I get Vista to _automatically_ switch the resolution back to 1680 x 150 when I switch the KVM back to this PC? I am using Windows Vista Ultimate with an ATI Radeon X1300 series card. The VGA output from the card is plugged into an Aten KVM switch. The VGA output from the switch is plugged into an Acer X223W widescreen monitor. Regards, Chris |
| Way to force monitor standby when resuming from sleep | Vista hardware & devices | |||
| Changed monitor also changed position of Window Mail Send/Receivewindow | Vista mail | |||
| Monitor flashes 3 times after Resuming Vista | Vista General | |||
| BSOD after resuming from sleep | Vista General | |||
| RE: Help Computer Keeps Resuming From Sleep at 4:25 AM !!!!! | Vista General | |||
