| | Shared Printer connected to an XP machine I have a HP4L connected to a XP Home machine. It is set as a Shared Printer, and other machines on my home network can see it and print to it. I have a Vista Home machine on the same network tht can see the XP machine, and access the shared folders, but it can not connect to the shared printer. When I try to connect to the HP4L, I get an error message, ACCESS DENIED. I was thinking the error came from the XP machine -- firewall problem or the like -- but I can't find any thing that would keep Vista out while letting all of my other machines in -- the other machines are all XP, some XP Pro, and some XP Home. The only machine that can not share the printer is the Vista machine. Do I need a printer driver on the Vista machine that works with the printer? <scratching head> |
| | RE: Shared Printer connected to an XP machine Yes. You need a Vista compatible driver for your printer installed in vista. Check at the printer's manufacturer's website for one. Vista found a driver for me when I connected to the XP's printer. I went Start>Network>Network and Sharing>Add Network device>Browsed for XP's printer, then Vista added the Driver. -- Mick Murphy - Qld - Australia "Jeff Strickland" wrote: Quote: > I have a HP4L connected to a XP Home machine. It is set as a Shared Printer, > and other machines on my home network can see it and print to it. > > I have a Vista Home machine on the same network tht can see the XP machine, > and access the shared folders, but it can not connect to the shared printer. > When I try to connect to the HP4L, I get an error message, ACCESS DENIED. I > was thinking the error came from the XP machine -- firewall problem or the > like -- but I can't find any thing that would keep Vista out while letting > all of my other machines in -- the other machines are all XP, some XP Pro, > and some XP Home. The only machine that can not share the printer is the > Vista machine. > > Do I need a printer driver on the Vista machine that works with the printer? > > <scratching head> > > |
| | Re: Shared Printer connected to an XP machine "Mick Murphy" <MickMurphy@xxxxxx> wrote in message news:33CD5047-1B7B-410F-B3B2-E2B51F064478@xxxxxx Quote: > Yes. You need a Vista compatible driver for your printer installed in > vista. > Check at the printer's manufacturer's website for one. > > Vista found a driver for me when I connected to the XP's printer. > > I went Start>Network>Network and Sharing>Add Network device>Browsed for > XP's > printer, then Vista added the Driver. > -- > Mick Murphy - Qld - Australia > > add a network printer from the Add Printer Wizard, and Connect Printer from wherever I found that option. |
| | Re: Shared Printer connected to an XP machine You can do it that way too. Just make sure you have the driver! -- Mick Murphy - Qld - Australia "Jeff Strickland" wrote: Quote: > > "Mick Murphy" <MickMurphy@xxxxxx> wrote in message > news:33CD5047-1B7B-410F-B3B2-E2B51F064478@xxxxxx Quote: > > Yes. You need a Vista compatible driver for your printer installed in > > vista. > > Check at the printer's manufacturer's website for one. > > > > Vista found a driver for me when I connected to the XP's printer. > > > > I went Start>Network>Network and Sharing>Add Network device>Browsed for > > XP's > > printer, then Vista added the Driver. > > -- > > Mick Murphy - Qld - Australia > > > > > Add Network Device. Hmmm, I would not have thought of that. I was trying to > add a network printer from the Add Printer Wizard, and Connect Printer from > wherever I found that option. > > > > > |
| | Re: Shared Printer connected to an XP machine "Jeff Strickland" <crwlr@xxxxxx> wrote in message news:GKVCj.5926$Id3.1274@xxxxxx Quote: >I have a HP4L connected to a XP Home machine. It is set as a Shared >Printer, and other machines on my home network can see it and print to it. > > I have a Vista Home machine on the same network tht can see the XP > machine, and access the shared folders, but it can not connect to the > shared printer. When I try to connect to the HP4L, I get an error message, > ACCESS DENIED. I was thinking the error came from the XP machine -- > firewall problem or the like -- but I can't find any thing that would keep > Vista out while letting all of my other machines in -- the other machines > are all XP, some XP Pro, and some XP Home. The only machine that can not > share the printer is the Vista machine. > > Do I need a printer driver on the Vista machine that works with the > printer? > > <scratching head> Of course you need a printer driver on your Vista box... just because the printer is hanging off another box doesn't mean you don't need a local driver on your Vista box. (Sorry, don't mean to sound harsh...) Sorry to say, I don't have an answer for you. I went through the -exact- same issue with my ten year old NEC SuperScript 1260 hanging off an XP Home box. For months whenever I tried, out of curiousity, to connect to the printer, I got the access denied msg. Then after numerous Vista system updates, and numerous months, I tried again and it worked, out of the blue. Well, I was happy but had no clue as to what got it working. For all I know it might have been XP updates, not Vista updates, that fixed it... That said... are your XP and Vista boxes up to date, patch wise? Lang |
| | #6 (permalink) |
| | Re: Shared Printer connected to an XP machine "Lang Murphy" <lang_murphy@xxxxxx> wrote in message news:ulN%23o7yhIHA.4140@xxxxxx Quote: > "Jeff Strickland" <crwlr@xxxxxx> wrote in message > news:GKVCj.5926$Id3.1274@xxxxxx Quote: >>I have a HP4L connected to a XP Home machine. It is set as a Shared >>Printer, and other machines on my home network can see it and print to it. >> >> I have a Vista Home machine on the same network tht can see the XP >> machine, and access the shared folders, but it can not connect to the >> shared printer. When I try to connect to the HP4L, I get an error >> message, ACCESS DENIED. I was thinking the error came from the XP >> machine -- firewall problem or the like -- but I can't find any thing >> that would keep Vista out while letting all of my other machines in -- >> the other machines are all XP, some XP Pro, and some XP Home. The only >> machine that can not share the printer is the Vista machine. >> >> Do I need a printer driver on the Vista machine that works with the >> printer? >> >> <scratching head> > > Of course you need a printer driver on your Vista box... just because the > printer is hanging off another box doesn't mean you don't need a local > driver on your Vista box. (Sorry, don't mean to sound harsh...) > > Sorry to say, I don't have an answer for you. I went through the -exact- > same issue with my ten year old NEC SuperScript 1260 hanging off an XP > Home box. For months whenever I tried, out of curiousity, to connect to > the printer, I got the access denied msg. Then after numerous Vista system > updates, and numerous months, I tried again and it worked, out of the > blue. Well, I was happy but had no clue as to what got it working. For all > I know it might have been XP updates, not Vista updates, that fixed it... > > That said... are your XP and Vista boxes up to date, patch wise? > > Lang PS Access to the printer is not predicated on the driver. When the connection is allowed, the driver automatically loads. I loaded the HP4L driver into the Vista box, and the printer showed up as a Local Printer, but it would still not connect as a Network Printer. |
| | #7 (permalink) |
| Vista Home Premium 64bit. | Re: Shared Printer connected to an XP machine Hi I have a new Vista box, my wife has my old XP Pro box, I had to download Vista printer drivers to my Vista box as Mike described above, I had to go into my wifes PC and share the printer, then download and install a patch into the XP box so my vista box will see the XP box (Google Vista can't see XP PC) you'll find the patch Then I added the network printer in vista, it searched for available printers, found the printer hooked up to the XP box, I added it...done Hope that helps Brian |
| | #8 (permalink) |
| | Re: Shared Printer connected to an XP machine "Jeff Strickland" <crwlr@xxxxxx> wrote in message news:%K5Dj.10490$hP3.6436@xxxxxx Quote: > > "Lang Murphy" <lang_murphy@xxxxxx> wrote in message > news:ulN%23o7yhIHA.4140@xxxxxx Quote: >> "Jeff Strickland" <crwlr@xxxxxx> wrote in message >> news:GKVCj.5926$Id3.1274@xxxxxx Quote: >>>I have a HP4L connected to a XP Home machine. It is set as a Shared >>>Printer, and other machines on my home network can see it and print to >>>it. >>> >>> I have a Vista Home machine on the same network tht can see the XP >>> machine, and access the shared folders, but it can not connect to the >>> shared printer. When I try to connect to the HP4L, I get an error >>> message, ACCESS DENIED. I was thinking the error came from the XP >>> machine -- firewall problem or the like -- but I can't find any thing >>> that would keep Vista out while letting all of my other machines in -- >>> the other machines are all XP, some XP Pro, and some XP Home. The only >>> machine that can not share the printer is the Vista machine. >>> >>> Do I need a printer driver on the Vista machine that works with the >>> printer? >>> >>> <scratching head> >> >> Of course you need a printer driver on your Vista box... just because the >> printer is hanging off another box doesn't mean you don't need a local >> driver on your Vista box. (Sorry, don't mean to sound harsh...) >> >> Sorry to say, I don't have an answer for you. I went through the -exact- >> same issue with my ten year old NEC SuperScript 1260 hanging off an XP >> Home box. For months whenever I tried, out of curiousity, to connect to >> the printer, I got the access denied msg. Then after numerous Vista >> system updates, and numerous months, I tried again and it worked, out of >> the blue. Well, I was happy but had no clue as to what got it working. >> For all I know it might have been XP updates, not Vista updates, that >> fixed it... >> >> That said... are your XP and Vista boxes up to date, patch wise? >> >> Lang > As far as I know. I have Automatic Updates set ON. > > PS > Access to the printer is not predicated on the driver. When the connection > is allowed, the driver automatically loads. I loaded the HP4L driver into > the Vista box, and the printer showed up as a Local Printer, but it would > still not connect as a Network Printer. > > Same issue I had... as previously stated, don't know what fixed my issue and it -was- fixed. (Although "behind my back" so to speak.) And while the access to the printer is not predicated on the printer driver, your Vista box will not print to your printer hanging off an XP box without the driver installed locally. That was the point I was making. Obviously, if access is denied to the printer, the driver won't get installed automagically. Access denied implies the XP box is the one doing the "denying." (Although, I admit, what appears to be logical is not always so... might be the Vista box throwing that error...) Lang |
| | #9 (permalink) |
| Vista Home Premium 64bit. | Re: Shared Printer connected to an XP machine Access denied could mean,you need to share your printer on the XP box, right click on the printer in the XP box and click on SHARE Here is the link to download the patch so vista will see the XP box, don't forget to download a vista printer driver into your vista box Why I Can’t See XP computers in Windows Vista Network Map |
| Shared Network Printer - Can't Connect From Vista Machine | Vista General | |||
| Connecting a Vista machine to a printer shared on an XP machine. | Vista print fax & scan | |||
| Unable to connected to shared printer in Vista, XP works ok | Vista print fax & scan | |||
| CAn't Print To a Shared Printer on XP Machine | Vista networking & sharing | |||
| Cannot print to a shared USB printer of a XP machine on the networ | Vista General | |||
