| | Printer stopped working HELP!!! I have Canon BJC-2000 Injet printer. It always worked perfectly with Vistas. Now since I changed the ink cartridges, it won't work. I send the print job and in the print queue is says "error - printing" and that's it. What is the problem. I am so frustrated I'm going to throw it out the window. Someone please help me!! -- Cynthia J. Campbell |
| | Re: Printer stopped working HELP!!! "Cindy Campbell" <cjc_bear@xxxxxx> wrote in message news:6EFC7DCD-E59F-494F-92E1-AD7CE586DEBC@xxxxxx Quote: > I have Canon BJC-2000 Injet printer. It always worked perfectly with > Vistas. > Now since I changed the ink cartridges, it won't work. I send the print > job > and in the print queue is says "error - printing" and that's it. What is > the > problem. I am so frustrated I'm going to throw it out the window. > Someone > please help me!! > -- > Cynthia J. Campbell I am not trying to be a smart-ass, but the problem is more than likely associated with the replacement cartridges. The first thing you need to do is remove the cartridges and make sure they are the proper model for your printer. The fact that you got them from a trusted source means nothing. The fact that the cartridges have the correct part number means nothing. Mistakes are made, mislabeling occurs and the manufacturing process is not always infallible. I assume you still have the original cartridges. If so, take out the new cartridges and compare the contacts with the contacts on the old ones. Do you have the same contacts in the same location? If so, are all the contacts clean? Replace the new cartridges with the old ones. Does your printer now function properly? If the old ones cause your printer to work again then the new ones are not the correct ones or there is something wrong with them. If the old ones will not allow your printer to work again you can go to Device Manager and check to see if your printer driver is OK. If it is not OK you will see a yellow triangle or exclamation mark. If Device Manager shows a problem with the printer you should go to the printer manufacturer's website and download the latest driver. However, if you have already updated the driver just prior to the installation of the new cartridges it is possible the new driver is causing the problem. If that is the case you should go back into Device Manager and roll back the driver to the previous version. If none of the above suggestions apply to your situation you should reinsert your printer installation CD and reinstall the printer. Run the software and do not plug in your printer until prompted to do so. If you don't have the installation CD or DVD you can go to the manufacturer's website and download the software from there. Again, do not plug in the printer until you are prompted to do so. C.B. -- It is the responsibility and duty of everyone to help the underprivileged and unfortunate among us. |
| | Re: Printer stopped working HELP!!! Is this the first time you have changed the cartridges? It sounds like it may be. If so, be sure that you have seated them properly and firmly. Often there is an additional "click" position when inserting new ones, and that could be the problem. LesleyO "Cindy Campbell" <cjc_bear@xxxxxx> wrote in message news:6EFC7DCD-E59F-494F-92E1-AD7CE586DEBC@xxxxxx Quote: >I have Canon BJC-2000 Injet printer. It always worked perfectly with >Vistas. > Now since I changed the ink cartridges, it won't work. I send the print > job > and in the print queue is says "error - printing" and that's it. What is > the > problem. I am so frustrated I'm going to throw it out the window. > Someone > please help me!! > -- > Cynthia J. Campbell |
| | Re: Printer stopped working HELP!!! It's not the cartridges, its not the printer driver or installation disk, all that is okay. For some reason the print jobs are not getting transmitted to the printer. This started when I (thought) I ran out of black ink. So I got new cartridges. The printer installs itself in Vista Home Premium and so does the USB port blah blah blah. Any other suggestions would be appreciated. The printer does reset itself when I press the restart button, so its not dead. -- Cynthia J. Campbell "LesleyO" wrote: Quote: > Is this the first time you have changed the cartridges? It sounds like it > may be. If so, be sure that you have seated them properly and firmly. Often > there is an additional "click" position when inserting new ones, and that > could be the problem. > > LesleyO > > "Cindy Campbell" <cjc_bear@xxxxxx> wrote in message > news:6EFC7DCD-E59F-494F-92E1-AD7CE586DEBC@xxxxxx Quote: > >I have Canon BJC-2000 Injet printer. It always worked perfectly with > >Vistas. > > Now since I changed the ink cartridges, it won't work. I send the print > > job > > and in the print queue is says "error - printing" and that's it. What is > > the > > problem. I am so frustrated I'm going to throw it out the window. > > Someone > > please help me!! > > -- > > Cynthia J. Campbell > |
| | Re: Printer stopped working HELP!!! If you had re-seated the cartridges properly, you would have been prompted by the printer's software to re-align printing on the page, and do a test page print. -- Mick Murphy - Qld - Australia "Cindy Campbell" wrote: Quote: > It's not the cartridges, its not the printer driver or installation disk, all > that is okay. For some reason the print jobs are not getting transmitted to > the printer. This started when I (thought) I ran out of black ink. So I got > new cartridges. The printer installs itself in Vista Home Premium and so > does the USB port blah blah blah. Any other suggestions would be > appreciated. The printer does reset itself when I press the restart button, > so its not dead. > -- > Cynthia J. Campbell > > > "LesleyO" wrote: > Quote: > > Is this the first time you have changed the cartridges? It sounds like it > > may be. If so, be sure that you have seated them properly and firmly. Often > > there is an additional "click" position when inserting new ones, and that > > could be the problem. > > > > LesleyO > > > > "Cindy Campbell" <cjc_bear@xxxxxx> wrote in message > > news:6EFC7DCD-E59F-494F-92E1-AD7CE586DEBC@xxxxxx Quote: > > >I have Canon BJC-2000 Injet printer. It always worked perfectly with > > >Vistas. > > > Now since I changed the ink cartridges, it won't work. I send the print > > > job > > > and in the print queue is says "error - printing" and that's it. What is > > > the > > > problem. I am so frustrated I'm going to throw it out the window. > > > Someone > > > please help me!! > > > -- > > > Cynthia J. Campbell > > |
| | #6 (permalink) |
| | Re: Printer stopped working HELP!!! I tried again and it is not the cartridges. It never prompted me to to a test page before when i changed cartridges. Anyway, it won't even do a test page, nozzle check or maintenance for me. I plugged it into a different USB port and that didn't make a difference either. I deleted all previous printers and reinstalled it again and that didn't help either. I hope I don't need a new printer! I just bought a dozen new cartridges! I'm going to call Canon tomorrow. They are closed today. Still open to more suggestions though. Thanks. -- Cynthia J. Campbell "Mick Murphy" wrote: Quote: > If you had re-seated the cartridges properly, you would have been prompted by > the printer's software to re-align printing on the page, and do a test page > print. > -- > Mick Murphy - Qld - Australia > > > "Cindy Campbell" wrote: > Quote: > > It's not the cartridges, its not the printer driver or installation disk, all > > that is okay. For some reason the print jobs are not getting transmitted to > > the printer. This started when I (thought) I ran out of black ink. So I got > > new cartridges. The printer installs itself in Vista Home Premium and so > > does the USB port blah blah blah. Any other suggestions would be > > appreciated. The printer does reset itself when I press the restart button, > > so its not dead. > > -- > > Cynthia J. Campbell > > > > > > "LesleyO" wrote: > > Quote: > > > Is this the first time you have changed the cartridges? It sounds like it > > > may be. If so, be sure that you have seated them properly and firmly. Often > > > there is an additional "click" position when inserting new ones, and that > > > could be the problem. > > > > > > LesleyO > > > > > > "Cindy Campbell" <cjc_bear@xxxxxx> wrote in message > > > news:6EFC7DCD-E59F-494F-92E1-AD7CE586DEBC@xxxxxx > > > >I have Canon BJC-2000 Injet printer. It always worked perfectly with > > > >Vistas. > > > > Now since I changed the ink cartridges, it won't work. I send the print > > > > job > > > > and in the print queue is says "error - printing" and that's it. What is > > > > the > > > > problem. I am so frustrated I'm going to throw it out the window. > > > > Someone > > > > please help me!! > > > > -- > > > > Cynthia J. Campbell > > > > > > |
| | #7 (permalink) |
| | Re: Printer stopped working HELP!!! Either uninstall and reinstall the printer or go to Help and Support, type print problems and use the troubleshoot printer problems. "Cindy Campbell" <cjc_bear@xxxxxx> wrote in message news:415B5056-29A2-45AF-8084-6F7F8791163A@xxxxxx Quote: > It's not the cartridges, its not the printer driver or installation disk, > all > that is okay. For some reason the print jobs are not getting transmitted > to > the printer. This started when I (thought) I ran out of black ink. So I > got > new cartridges. The printer installs itself in Vista Home Premium and so > does the USB port blah blah blah. Any other suggestions would be > appreciated. The printer does reset itself when I press the restart > button, > so its not dead. > -- > Cynthia J. Campbell > > > "LesleyO" wrote: > Quote: >> Is this the first time you have changed the cartridges? It sounds like it >> may be. If so, be sure that you have seated them properly and firmly. >> Often >> there is an additional "click" position when inserting new ones, and that >> could be the problem. >> >> LesleyO >> >> "Cindy Campbell" <cjc_bear@xxxxxx> wrote in message >> news:6EFC7DCD-E59F-494F-92E1-AD7CE586DEBC@xxxxxx Quote: >> >I have Canon BJC-2000 Injet printer. It always worked perfectly with >> >Vistas. >> > Now since I changed the ink cartridges, it won't work. I send the >> > job >> > and in the print queue is says "error - printing" and that's it. What >> > is >> > the >> > problem. I am so frustrated I'm going to throw it out the window. >> > Someone >> > please help me!! >> > -- >> > Cynthia J. Campbell >> |
| | #8 (permalink) |
| | Re: Printer stopped working HELP!!! "Cindy Campbell" <cjc_bear@xxxxxx> wrote in message news:6EFC7DCD-E59F-494F-92E1-AD7CE586DEBC@xxxxxx Quote: >I have Canon BJC-2000 Injet printer. It always worked perfectly with >Vistas. > Now since I changed the ink cartridges, it won't work. I send the print > job > and in the print queue is says "error - printing" and that's it. What is > the > problem. I am so frustrated I'm going to throw it out the window. > Someone > please help me!! > -- > Cynthia J. Campbell As others have responded... if it worked before you changed the cartridge, then it's either an issue with the cartridge or the printer... most likely, not Vista. Have you tried putting the old cartridge back in? What kind of msg do you get when the old cartridge is in? (Even if it's "cartridge needs replacing" might indicate a problem with the new cartridge in that it's not communicating with the printer successfully...) Have you tried any of the other dozen cartridges you purchased? Maybe just a flaky cartridge? Lang |
| | #9 (permalink) |
| | Re: Printer stopped working HELP!!! Yes, I tried other cartridges. Still won't print. I also downloaded another driver to no avail. Do I need to clean the inside of the printer? If so, how do I do that without hurting it? -- Cynthia J. Campbell "Lang Murphy" wrote: Quote: > "Cindy Campbell" <cjc_bear@xxxxxx> wrote in message > news:6EFC7DCD-E59F-494F-92E1-AD7CE586DEBC@xxxxxx Quote: > >I have Canon BJC-2000 Injet printer. It always worked perfectly with > >Vistas. > > Now since I changed the ink cartridges, it won't work. I send the print > > job > > and in the print queue is says "error - printing" and that's it. What is > > the > > problem. I am so frustrated I'm going to throw it out the window. > > Someone > > please help me!! > > -- > > Cynthia J. Campbell > > As others have responded... if it worked before you changed the cartridge, > then it's either an issue with the cartridge or the printer... most likely, > not Vista. Have you tried putting the old cartridge back in? What kind of > msg do you get when the old cartridge is in? (Even if it's "cartridge needs > replacing" might indicate a problem with the new cartridge in that it's not > communicating with the printer successfully...) > > Have you tried any of the other dozen cartridges you purchased? Maybe just a > flaky cartridge? > > Lang > |
| | #10 (permalink) |
| | Re: Printer stopped working HELP!!! "Cindy Campbell" <cjc_bear@xxxxxx> wrote in message news:3580626B-A89D-4519-A7D1-3340D30FE6AF@xxxxxx Quote: > Yes, I tried other cartridges. Still won't print. I also downloaded > another > driver to no avail. Do I need to clean the inside of the printer? If so, > how > do I do that without hurting it? > -- > Cynthia J. Campbell > Well... the only thing I can think of right now is trying to print to the printer from another computer... do you have any other computers in your house? (This would prove that the printer/cartridge are good and the problem lies with either the Vista printer driver or Vista itself...) Have you tried Mr. Barnes's suggestion to uninstall/reinstall the printer driver? Lang Quote: > > "Lang Murphy" wrote: > Quote: >> "Cindy Campbell" <cjc_bear@xxxxxx> wrote in message >> news:6EFC7DCD-E59F-494F-92E1-AD7CE586DEBC@xxxxxx Quote: >> >I have Canon BJC-2000 Injet printer. It always worked perfectly with >> >Vistas. >> > Now since I changed the ink cartridges, it won't work. I send the >> > job >> > and in the print queue is says "error - printing" and that's it. What >> > is >> > the >> > problem. I am so frustrated I'm going to throw it out the window. >> > Someone >> > please help me!! >> > -- >> > Cynthia J. Campbell >> >> As others have responded... if it worked before you changed the >> cartridge, >> then it's either an issue with the cartridge or the printer... most >> likely, >> not Vista. Have you tried putting the old cartridge back in? What kind of >> msg do you get when the old cartridge is in? (Even if it's "cartridge >> needs >> replacing" might indicate a problem with the new cartridge in that it's >> not >> communicating with the printer successfully...) >> >> Have you tried any of the other dozen cartridges you purchased? Maybe >> just a >> flaky cartridge? >> >> Lang >> |
| Printer Sharing suddenly stopped working | Network & Sharing | |||
| Printer communication system stopped working | Vista print fax & scan | |||
| Printer stopped working | General Discussion | |||
| Printer stopped working | Vista General | |||
| My printer stopped working too, what should I do? | Vista General | |||
