vista (business) sidebar problem, loading lots of same gadgets
  1. #1
    HJ Guest
    I have a sidebar problem same as the one raised by D L Hess in "Sidebar loads
    100+ gadgets on startup". That is, the same gadget duplicately loaded when
    starting up, just like there are thirty more clocks and calenders...... And
    the gadget can not be removed and uninstalled since the desktop is then
    frozen when clicking to do that. "D L Hess " suggest to edit the setting.ini,
    however, i can not find such file in the link he provided. As well, i
    searched in c:\ and found some, but it seems there is no duplicate entries on
    it ...
    So, who can help me?
  2. #2
    Mark L. Ferguson Guest
    Re: vista (business) sidebar problem, loading lots of same gadgets
    This site will probably help:
    Windows Sidebar will not Start in Vista
    Was this helpful? Then click the Ratings button. Voting helps the web
    interface.
    http://www.microsoft.com/wn3/locales...eAPostAsAnswer
    Mark L. Ferguson
    "HJ" <HJ@xxxxxx> wrote in message
    news:831989C9-6D9D-4F93-BFE5-49FA559565C9@xxxxxx
    > loads
    > when
    > And
    > setting.ini,
    > on
    > it ...
Problem With Sidebar & Gadgets Debby Hanoka Vista General 4 08 Jan 2010
Re: Vista SideBar - Gadgets Theory of Everything Vista General 0 15 Sep 2008
Gadgets for vista sidebar laffen Vista General 1 03 Jun 2008
Re: Vista Sidebar Problem - closing gadgets locks up computer dell-e521 Vista General 1 17 Mar 2008
FAQ: What to do if applications are not loading even though you have lots of memory. David F Vista General 0 06 Dec 2007
