| | Use XP Pro upgrade on a Vista Home machine ? New PC bought with Vista pre-installed. I own an unused XP Professional Upgrade CD. Can I upgrade / crossgrade / downgrade from Vista to XP Pro using the upgrade CD ? I'm anticipating failure when it doesn't detect a previous complying product - is this so, and if so what media and licensing steps offer a workaround ? Thanks, Phil |
| Vista Ultimate 64 / win xp 32 | Re: Use XP Pro upgrade on a Vista Home machine ? Hi Phil, no that won't work, some oem do offer a revert back to xp disc, depending on manufacturer. Do you have a old windows 98 disk, u can use that as your previous os, you just install win xp upgrade disc, it will ask for a previous version which u put in for a couple of minutes, then xp will continue to install. |
| Vista Ultimate 64 / win xp 32 | Re: Use XP Pro upgrade on a Vista Home machine ? PS, too do this you will need to boot off XP disc to work. |
| Vista Ultimate 64 / win xp 32 | Re: Use XP Pro upgrade on a Vista Home machine ? Anddd!! also most probably you will need to delete the vista partition & start a fresh partition & install on that. |
| | Re: Use XP Pro upgrade on a Vista Home machine ? There is no workaround and no end-user right to change from Vista to XP. You need to contact the source you bought the computer from and either have them supply Windows XP for it or replace it with a Windows XP system. -- Richard G. Harper [MVP Shell/User] rgharper@xxxxxx * NEW! Catch my blog ... http://msmvps.com/blogs/rgharper/ * PLEASE post all messages and replies in the newsgroups * The Website - http://rgharper.mvps.org/ "PhilT" <newsnet@xxxxxx> wrote in message news:e40e68a9-5a37-4163-9c21-e6a71be34840@xxxxxx Quote: > New PC bought with Vista pre-installed. I own an unused XP > Professional Upgrade CD. > > Can I upgrade / crossgrade / downgrade from Vista to XP Pro using the > upgrade CD ? > > I'm anticipating failure when it doesn't detect a previous complying > product - is this so, and if so what media and licensing steps offer a > workaround ? > > Thanks, > > > Phil |
| | #6 (permalink) |
| | RE: Use XP Pro upgrade on a Vista Home machine ? Vista considers XP to be a downgrade, as it is an older OS, and won't do it. If you manage to get a '98 and upgrade from there, first check out your computer's manufacturer website to see if XP drivers are available for the Hardware installed in it(Mobo, etc) -- Mick Murphy - Qld - Australia "PhilT" wrote: Quote: > New PC bought with Vista pre-installed. I own an unused XP > Professional Upgrade CD. > > Can I upgrade / crossgrade / downgrade from Vista to XP Pro using the > upgrade CD ? > > I'm anticipating failure when it doesn't detect a previous complying > product - is this so, and if so what media and licensing steps offer a > workaround ? > > Thanks, > > > Phil > |
| | #7 (permalink) |
| | Re: Use XP Pro upgrade on a Vista Home machine ? On Mar 18, 9:02 am, "Richard G. Harper" <rghar...@xxxxxx> wrote: Quote: > There is no workaround and no end-user right to change from Vista to XP. Vista business upgrade followed by the downgrade rights to XP ? Phil |
| | #8 (permalink) |
| | Re: Use XP Pro upgrade on a Vista Home machine ? Nope, not unless you have a valid key and media for XP, you can't. -- Richard G. Harper [MVP Shell/User] rgharper@xxxxxx * NEW! Catch my blog ... http://msmvps.com/blogs/rgharper/ * PLEASE post all messages and replies in the newsgroups * The Website - http://rgharper.mvps.org/ "PhilT" <newsnet@xxxxxx> wrote in message news:16e0b98d-c6a2-4b7d-9cc5-4dac065ae7e0@xxxxxx Quote: > On Mar 18, 9:02 am, "Richard G. Harper" <rghar...@xxxxxx> wrote: Quote: >> There is no workaround and no end-user right to change from Vista to XP. > apart from Vista Business and its downgrade rights, so could I use a > Vista business upgrade followed by the downgrade rights to XP ? > > > Phil |
| Vista Utimate upgrade/transfer to new machine (bad kitty) | Windows Updates | |||
| Vista Home and Ultimate on same machine | Vista installation & setup | |||
| Upgrading Windows 2000 Upgrade to Vista Home Premium Upgrade | Vista General | |||
| Windows XP Home (Full Vers.) to Vista Home Premium Upgrade (Academ | Vista General | |||
| Upgrade fm XP Home ( Greek vers) to Vista home premium (upgrade) E | Vista General | |||
