Vista - HP dv2210us will not 'restart' (warm) but will 'shutdown' and'reboot' (cold)
Old 03-18-2008   #1 (permalink)
Kaushik Ghose
My dv2210us has been running fine for 8months or so. Suddenly from
March 16th the computer will now:
1. Not wake from sleep
2. Will not restart (warm reboot, e.g. after a software install)
3. Will start cold
4. Will shutdown
Removing the hibernation file does not make a difference.
I reinstalled vista using the restore disks and I still have the same
problem.
Does any one have any ideas?
Thanks
-Kaushik
Troubleshoot Restart With Warm OR Cold Boot? Vista General
Shutdown & restart problems Vista General
Vista won't restart / shutdown Vista performance & maintenance
wont restart/shutdown Vista performance & maintenance
Slow Shutdown / Restart Vista performance & maintenance
