Vista - No HTTP connections after installing Vista SP1 - Need Help
Old 03-19-2008   #1 (permalink)
kdlovell
I just installed Vista SP1 through Windows Update on my work notebook. Now I
can no longer make any HTTP connections. Email and gadgets connect fine to
the internet, but not IE. I can also connect to my work VPN.
I attempted to seek help from Microsoft but they don't seem to offer any
support for less than $59 (nice ..).
Any advice on this issue would be appreciated. For the time being, I am
going to have to borrow another notebook from IT.
I would advise anyone NOT to install Vista SP1 on a PC that you need on a
daily basis.
Old 03-19-2008   #2 (permalink)
Mark L. Ferguson
Re: No HTTP connections after installing Vista SP1 - Need Help
Click Start, and type:
CleanMgr
Clean up all your temp files, and restart Windows to try the sites again.
Was this helpful? Then click the Ratings button. Voting helps the web
interface.
http://www.microsoft.com/wn3/locales...eAPostAsAnswer
Mark L. Ferguson
"kdlovell" <kdlovell@xxxxxx> wrote in message
news:8131CE7F-7FED-408B-B413-A42B5F34CB99@xxxxxx
> Now I
> to
> daily basis.
Old 03-19-2008   #3 (permalink)
kdlovell
RE: No HTTP connections after installing Vista SP1 - Need Help
> daily basis.
Thanks for your advice Mark - that information is helpful in any case. I
did manage to figure out what the problem was. I dig around the 'read me'
docs and there were a fair number of anti-virus applications listed as having
issues with SP1. I use Kaspersky which was not on the list, but this did
give me the lead that I needed. I had Anti-Virus disabled, but apparantly it
is never truly disabled and it was blocking IE because the exe had changed.
As soon as I re-enabled it and allowed IE access everything returned to
normal.
I'll mention this again since this is good to know - check the read me files
and with your anti-virus vendor to see if it is compatible with SP1. There
were a few listed as not compatible.
Regarding Http Connections .NET General
help installing/enabling http ssl service for media sharing Vista networking & sharing
PPPOE connections created show up as Dial-up connections Vista networking & sharing
HTTP 400 in Vista x64 only Vista General
Anyluck installing Non-IIS HTTP Daemons? Vista General
