| | Control panel question Hi, not sure what caused this but... when I open my control panel I'm missing from the left column- > Control panel - Switch to classic view See Also - Windows update - Help & support - Other control panel options ---- I just get control panel home & classic view (on the left side) Any suggestions? |
| Windows 7 RC | Re: Control panel question Hi, not sure what caused this but... when I open my control panel I'm missing from the left column- > Control panel - Switch to classic view See Also - Windows update - Help & support - Other control panel options ---- I just get control panel home & classic view (on the left side) Any suggestions? Hello, This tutorial talks about enabling/disabling the control panel and may help you. Here's the link: Control Panel - Enable or Disable I hope this helps. |
| | Re: Control panel question ".Joe" wrote: Quote: > > merlin2049er;655270 Wrote: Quote: > > Hi, not sure what caused this but... > > > > when I open my control panel I'm missing from the left column- > > > > > Control panel > > - Switch to classic view > > > > See Also > > - Windows update > > - Help & support > > - Other control panel options > > ---- > > > > I just get control panel home & classic view (on the left side) > > > > Any suggestions? > > Hello, > > This tutorial talks about enabling/disabling the control panel and may > help you. Here's the link: > Control Panel - Enable or Disable > > I hope this helps. > > > -- > .Joe > > _[image: > http://uswave.net/vistax64/joetmvx64.png] (\"http://www.vistax64.com/index.php?referrerid=17621\")_ > _*::Click_here_for_the_Vista_Forums::* (\"http://www.vistax64.com/index.php?referrerid=17621\")_ > _Geekbench_Score:_4050 (\"http://browse.geekbench.ca/geekbench2/view/42901\")_ > _CPU-Z_Verified (\"http://valid.x86-secret.com/show_oc.php?id=323179\")_ > fix it either. Any other suggestions? |
| How can I control the size of icons in Control Panel? | Vista General | |||
| control panel | Vista performance & maintenance | |||
| Lost Control of Control Panel | Vista General | |||
| control panel question | Vista performance & maintenance | |||
| CONTROL PANEL QUESTION | Vista General | |||
