| | Need Help Installing RAID 0 Array With Vista Hey everyone, i installed windows Vista beat 2 x86 the other day and im using the ASUS A8n-SLi Premium Motherboard, which uses the NVIDIA nForce4 SLI shipset, i got vista installed but i cant get it to recongize my raid o array that has all my back up info on it, i've tried everything i can thing off. Does anyone know how to install a raid 0 array on vista?? please let me know if you do |
| | Re: Need Help Installing RAID 0 Array With Vista Hi, Have you installed the RAID drivers from Asus? I'm not sure if they have Vista-compatible ones, if not, use XP drivers. -- Best of Luck, Rick Rogers, aka "Nutcase" - Microsoft MVP http://mvp.support.microsoft.com/ Windows help - www.rickrogers.org "trentw" <trentw@discussions.microsoft.com> wrote in message news:C9B86380-2CE1-4421-A91A-F52F5E15AA6C@microsoft.com... > Hey everyone, i installed windows Vista beat 2 x86 the other day and im > using > the ASUS A8n-SLi Premium Motherboard, which uses the NVIDIA nForce4 SLI > shipset, i got vista installed but i cant get it to recongize my raid o > array > that has all my back up info on it, i've tried everything i can thing off. > Does anyone know how to install a raid 0 array on vista?? please let me > know > if you do |
| Vista Home Premium x64 | Re: Need Help Installing RAID 0 Array With Vista Sup all, Ok, so i have installed Vista onto my two 500GB SATA II HDD as a RAID 0. No Probs, having the system see the HDD's as one in a RAID 0 set. Can see it in the installation and will go as far as installin got the HDD, after reboot, the process again???!! WTF?? Driver are installed and in BIOS RAID is configured for the board... my question is, why do i keep going into setup? lippeonix As far as the board or installtion not seeing the HDD's its a driver or board compatability issue. Seek out driver from board CD. |
| Vista Home Premium x64 | Re: Need Help Installing RAID 0 Array With Vista Persistance has worked, all works. |
| Installing A Raid 0 Array With Vista | Vista General | |||
| Installing RAID 0 Array With Vista | Vista hardware & devices | |||
| Installing RAID 0 Array on Vista | Vista hardware & devices | |||
| Installing RAID 0 Array on vista | Vista installation & setup | |||
| Installing Beta 2 on an Nvidia raid array. | Vista General | |||
