| | Search Problem I have a problem with Search in Vista. In Windows XP, I could choose Start | Search | All Files and Folders, and then search for *.doc, *.pst, or something like that to find all files with a specific file name extension. Vista doesn't seem to work like that. In Vista, I can search for *.doc and that seems to work okay. But, when I try to search for *.pst, Vista finds no files, though there are files with that extension on my hard drive. What's the trick about using Search in Vista? GordonP |
| | Re: Search Problem You cannot find files when you search a Windows Vista-based computer even though the files exist on the computer: http://support.microsoft.com/kb/932989 -- Regards, Ramesh Srinivasan, Microsoft MVP [Windows Shell/User] Windows® Troubleshooting http://www.winhelponline.com Winhelponline.com blog http://www.winhelponline.com/blog "Gordon Padwick" <gpadwick@xxxxxx> wrote in message news:ukPjTN9iIHA.1132@xxxxxx I have a problem with Search in Vista. In Windows XP, I could choose Start | Search | All Files and Folders, and then search for *.doc, *.pst, or something like that to find all files with a specific file name extension. Vista doesn't seem to work like that. In Vista, I can search for *.doc and that seems to work okay. But, when I try to search for *.pst, Vista finds no files, though there are files with that extension on my hard drive. What's the trick about using Search in Vista? GordonP |
| Search Problem | Vista performance & maintenance | |||
| Search problem | Vista General | |||
| Search problem. | Vista General | |||
| Search Problem | Vista file management | |||
| search problem in RC1 | Vista file management | |||
