Vista - Vista Ultimate 64bit upgrade over Vista Ultimate 32bit???
Old 03-22-2008   #1 (permalink)
Sweet Baby Alice
is it posible to install vista ultimate 64bit Upgrade over vista ultimate
32bit???
Alice
Old 03-22-2008   #2 (permalink)
Dustin Harper
Re: Vista Ultimate 64bit upgrade over Vista Ultimate 32bit???
No. Installing a 64 bit version of Vista requires a clean install. Just make
sure you back up your settings and files.
Dustin Harper
dharper@xxxxxx
http://www.vistarip.com | Vista Resource & Information Page
"Sweet Baby Alice" <babyalice@xxxxxx> wrote in message
news:9DEF244C-0908-4B9A-9395-4AA348CBF8F2@xxxxxx
> 32bit???
> Alice
Old 03-22-2008   #3 (permalink)
Sweet Baby Alice
Microsoft doesn't like to make any thing easy. got computer that can
install 8gb of ram buts because its has 32bit will only use 4gb. its an hp
computer so don't evens know how mes cans install the 64 since all the
drivers n op install save on hard drive.
Alice
"Dustin Harper" <dharper@xxxxxx> wrote in message
news:AA89CE44-3FD8-4659-96FB-5BF19695FA9E@xxxxxx
> make sure you back up your settings and files.
> Dustin Harper
> dharper@xxxxxx
>> 32bit???
>> Alice
Old 03-22-2008   #4 (permalink)
Richard G. Harper
You need to check with your computer manufacturer to see if 64-bit Windows
is supported on your model (ie, drivers) - if it's not then you would be ill
advised to install the 64-bit version. You also should check to see how to
either create or obtain a restore disc set so you can reinstall Windows
should it ever become necessary.
Richard G. Harper [MVP Shell/User] rgharper@xxxxxx
* NEW! Catch my blog ... http://msmvps.com/blogs/rgharper/
* PLEASE post all messages and replies in the newsgroups
* The Website - http://rgharper.mvps.org/
news:98C1FF16-1E2C-48E2-A59A-7AE120D540F5@xxxxxx
> hp computer so don't evens know how mes cans install the 64 since all the
> Alice
>> Dustin Harper
>> dharper@xxxxxx
>>> ultimate 32bit???
>>> Alice
Old 03-22-2008   #5 (permalink)
Vista Ultimate x86-32 SP1 dual boot with Windows XP SP3
Quote  Quote: Originally Posted by Sweet Baby Alice View Post
computer
[/quote]
How can HP give u a computer with 8 GB memory and not install a 64 bit os?? You should sue Hp for this!
You can NEVER use greater than 4GB of memory unless you have 64 bit OS.
Old 03-22-2008   #6 (permalink)
Windows 7 RC
32bit???
Alice
For more information comparing 64 bit vs 32 bit, you can visit this Microsoft site: A description of the differences between 32-bit versions of Windows Vista and 64-bit versions of Windows Vista
Solved vista ultimate 32bit and ultimate 64bit General Discussion
RAID-0 XP 32bit Upgrade to Vista 64bit Ultimate Vista installation & setup
Upgrade from Vista Home 32bit(OEM) to Vista Ultimate 64bit(Retail)? Vista installation & setup
vista premium 32bit to ultimate 64bit upgrade gone wrong! Vista installation & setup
Vista Home Premium 32bit Upgrade to Vista Ultimate 64bit Vista installation & setup
