| | Logon Problem After Vista x64 SP1 Installed I installed SP1 for Vista x64 the other day and have encountered the following problem since then: Computer boots up fine and allows me (or the other user) to logon without difficulty. After logon all works as expected. I will then 'switch user' and my wife will logon Then we get a problem (same problem presents itself if she logs on first, then logs off and I log on, or we switch user, basically problem presents itself when first user 'switch user' or' logs off' and another user logs on, the problem is with the second user; interestingly, the problem also occurs if I log on, log off, then log on again! Problem only solved after a system reset). The logon begins and the desktop appears. It seems to me like the desktop will not refresh properly. The gadgets do not appear; I can no longer single-click a desktop icon (have to double-click); the taskbar remains in the up position (won't auto-hide) and when I do launch a program the button does not appear in the taskbar; the taskbar icons do not appear in the taskbar. All these problems could be caused by some sort of video card problem, maybe? Anyway, my computer specs are below. Windowes Vista Ultimate x64 SP1 (licensed copy) Intel Core 2 CPU 6600 @ 2.4GHz 4.00GB RAM Nvidia GeForce 7950GT (latest driver) Motherboard - Gigabyte 965P-DQ6 I have completed some initial research on this problem without success. |
| | Re: Logon Problem After Vista x64 SP1 Installed I'm also seeing problems with sleep that seem similar. I think it's a bug in Aero. Test your results with "Classic Windows" theme to find out. -- Was this helpful? Then click the Ratings button. Voting helps the web interface. http://www.microsoft.com/wn3/locales...eAPostAsAnswer Mark L. Ferguson .. "Wylee" <Wylee@xxxxxx> wrote in message news:C6908C91-0FCB-492B-A6F1-D45BA61AC017@xxxxxx Quote: > I installed SP1 for Vista x64 the other day and have encountered the > following > problem since then: > > Computer boots up fine and allows me (or the other user) to logon without > difficulty. > After logon all works as expected. > I will then 'switch user' and my wife will logon > Then we get a problem (same problem presents itself if she logs on first, > then logs off and I log on, or we switch user, basically problem presents > itself when first user 'switch user' or' logs off' and another user logs > on, > the problem is with the second user; interestingly, the problem also > occurs > if I log on, log off, then log on again! Problem only solved after a > system > reset). > > The logon begins and the desktop appears. > It seems to me like the desktop will not refresh properly. The gadgets do > not appear; I can no longer single-click a desktop icon (have to > double-click); the taskbar remains in the up position (won't auto-hide) > and > when I do launch a program the button does not appear in the taskbar; the > taskbar icons do not appear in the taskbar. All these problems could be > caused by some sort of video card problem, maybe? Anyway, my computer > specs > are below. > > Windowes Vista Ultimate x64 SP1 (licensed copy) > Intel Core 2 CPU 6600 @ 2.4GHz > 4.00GB RAM > Nvidia GeForce 7950GT (latest driver) > Motherboard - Gigabyte 965P-DQ6 > > I have completed some initial research on this problem without success. > |
| Windows 7 RC | Re: Logon Problem After Vista x64 SP1 Installed I installed SP1 for Vista x64 the other day and have encountered the following problem since then: Computer boots up fine and allows me (or the other user) to logon without difficulty. After logon all works as expected. I will then 'switch user' and my wife will logon Then we get a problem (same problem presents itself if she logs on first, then logs off and I log on, or we switch user, basically problem presents itself when first user 'switch user' or' logs off' and another user logs on, the problem is with the second user; interestingly, the problem also occurs if I log on, log off, then log on again! Problem only solved after a system reset). The logon begins and the desktop appears. It seems to me like the desktop will not refresh properly. The gadgets do not appear; I can no longer single-click a desktop icon (have to double-click); the taskbar remains in the up position (won't auto-hide) and when I do launch a program the button does not appear in the taskbar; the taskbar icons do not appear in the taskbar. All these problems could be caused by some sort of video card problem, maybe? Anyway, my computer specs are below. Windowes Vista Ultimate x64 SP1 (licensed copy) Intel Core 2 CPU 6600 @ 2.4GHz 4.00GB RAM Nvidia GeForce 7950GT (latest driver) Motherboard - Gigabyte 965P-DQ6 I have completed some initial research on this problem without success. There is free Microsoft tech support for SP1. You can access it here: https://support.microsoft.com/oas/de...4&gprid=500921 I hope this helps. |
| Re: Vista logon problem | Vista General | |||
| Vista Logon problem | Vista account administration | |||
| Logon Problem between Vista and 2000 Pro | Vista networking & sharing | |||
| Vista Logon problem in to 2000 Pro | Vista networking & sharing | |||
