Vista - Media Center won't launch using the remote control... Please Help
Old 03-22-2008   #1 (permalink)
Paul \(in Tor,Ont\)
The problem I'm having is the remote control will not launch Media Center with the green button
(the one that came with my laptop and is stored in a slot at the side of the laptop). The remote
does work for everything else, QuickPlay, etc and will work with all the commands once Media Center
is running.
I installed MCE Customizer and was playing with some of the settings and this has caused the problem
(it work before this time). I uninstalled MCE Customizer, however, Media Center still won't launch
from the remote control.
Thank you for any help.
Cheers
Paul
HP Pavilion DV9417ca Entertainment Laptop
AMD Turion 64 x 2 core 1.8GHz
160GB/2GB/NVIDIA GeForce Go 6150
17"Wscreen/Wifi/BT/Built-in cam/RC
Vista Premium x32-bit SP1
iPAQ 2490 WM5
Old 03-22-2008   #2 (permalink)
Mark L. Ferguson
Re: Media Center won't launch using the remote control... Please Help
Your best source of info on Media Center is the Green Button site.
The Green Button - Your Media Center Community: http://thegreenbutton.com/
Was this helpful? Then click the Ratings button. Voting helps the web
interface.
http://www.microsoft.com/wn3/locales...eAPostAsAnswer
Mark L. Ferguson
"Paul (in Tor,Ont)" <p@xxxxxx> wrote in message
news:8111D59E-A647-44E0-A3D7-85A01DBE358A@xxxxxx
> with the green button (the one that came with my laptop and is stored in a
> slot at the side of the laptop). The remote does work for everything else,
> QuickPlay, etc and will work with all the commands once Media Center is
> running.
> this has caused the problem (it work before this time). I uninstalled MCE
> Customizer, however, Media Center still won't launch from the remote
> control.
> Cheers
> Paul
> iPAQ 2490 WM5
Old 03-22-2008   #3 (permalink)
Paul \(in Tor,Ont\)
"Mark L. Ferguson" <MarkLFerguson@xxxxxx> wrote in message
news:C445B251-457A-440C-8216-E597639DF4B9@xxxxxx
> interface. http://www.microsoft.com/wn3/locales...eAPostAsAnswer
> Mark L. Ferguson
>> Center is running.
>> problem (it work before this time). I uninstalled MCE Customizer, however, Media Center still
>> won't launch from the remote control.
>> Cheers
>> Paul
>> iPAQ 2490 WM5
Hi Mark,
Actually I posted there first, but still no reply
iPAQ 2490 WM5
Old 03-22-2008   #4 (permalink)
Jon
> running.
> control.
> Cheers
> Paul
May be a physically faulty button.
Jon
Old 03-22-2008   #5 (permalink)
Bob
Rerun MCE setup.
news:64C6534F-3905-4677-9C37-50863A0156AC@xxxxxx
> message news:C445B251-457A-440C-8216-E597639DF4B9@xxxxxx
>> interface.
>> Mark L. Ferguson
>>> Center with the green button (the one that came with my laptop and is
>>> stored in a slot at the side of the laptop). The remote does work for
>>> Media Center is running.
>>> MCE Customizer, however, Media Center still won't launch from the remote
>>> control.
>>> Cheers
>>> Paul
>>> iPAQ 2490 WM5
> Hi Mark,
> iPAQ 2490 WM5
Old 03-23-2008   #6 (permalink)
Paul \(in Tor,Ont\)
"Bob" <bob@xxxxxx> wrote in message news:evCdnWbMnvfsD3janZ2dnUVZ_j-dnZ2d@xxxxxx
Quote:
> Rerun MCE setup.
>>> interface.
>>> Mark L. Ferguson
>>>> control.
>>>> Cheers
>>>> Paul
>>>> iPAQ 2490 WM5
>> Hi Mark,
>> iPAQ 2490 WM5
how do I do that?!, , it's integrated with Vista Premium!?!
iPAQ 2490 WM5
Old 03-23-2008   #7 (permalink)
Paul \(in Tor,Ont\)
"Jon" <Email_Address@xxxxxx> wrote in message
news:%238Vl3dGjIHA.4356@xxxxxx
>> Center is running.
>> Cheers
>> Paul
> Jon
nope, the button works because the computer gives a led signal that it is receiving, also my iPAQ
PDA has Novi Remote programmed and sends the signal, again the computer says it sees it but doesn't
know what to do with it.
iPAQ 2490 WM5
Old 03-23-2008   #8 (permalink)
Bob
Tasks>General>Media Center Setup>Run Setup Again
news:00989AAD-364F-40B1-AA4E-D9D4C1EE53AC@xxxxxx
Quote:
>> Rerun MCE setup.
>>>> interface.
>>>> Mark L. Ferguson
>>>>> once Media Center is running.
>>>>> and this has caused the problem (it work before this time). I
>>>>> Cheers
>>>>> Paul
>>>>> iPAQ 2490 WM5
>>> Hi Mark,
>>> iPAQ 2490 WM5
> iPAQ 2490 WM5
Old 03-23-2008   #9 (permalink)
Jon
news:ebmBD7JjIHA.3512@xxxxxx
> receiving, also my iPAQ PDA has Novi Remote programmed and sends the
> signal, again the computer says it sees it but doesn't know what to do
> with it.
You may need to check your startup programs. The remote I use here gets its
green button functionality via a startup program that runs in the background
and makes sense of the signals. Perhaps there's a similar one for your setup
that's somehow become disabled.
Start > msconfig > Startup
Start > msconfig > Services (+Hide all Microsoft Services)
Jon
Old 11-24-2008   #10 (permalink)
MArtin
Mini remote control
Its necessary reinstall HP QUICK LAUNCH BUTTONS from http://welcome.hp.com/country/us/en/...plit%2Fsupport
After reboot will works.
remote control with media center Vista hardware & devices
Media Center Remote Control Vista General
Remote control windows media center Vista hardware & devices
Media Center Remote Control Vista hardware & devices
Where can I get blaster and remote control for Media Center? Vista General
