| | horribly slow x64 Vista on existing installation and on fresh ones For the longest time.. ive struggled to figure this one out.. only under x64 vista (sp1 now, probably rtm before).. i have cpu % at 100, svchost.exe (pnp devices and dcom services).. I couldnt figure out why.. i tried a fresh install.. it would even drag to the point where the install would take hours instead of 30 minutes.. Under x86.. no problems.. that harddrive ran fine ; i had been using x64 for the longest time without issues though... My hardware is an asus p5n32-sli se with corsair cm2x1024-6400 1GB chips x 4 (4GB).. i also have an 8600GT and a 7600GT video card. I tried everything, but now i think i'm close to figuring it out.. Its worth noting, that yeah under x86 it ran fine (which i found odd), except that occassionally if memory used hit 76% (say had a lot of tabs open in IE..) i would get out of memory errors.. perhaps this was a clue too.. though i had none of the max cpu issues here.. I went with 2 ram chips at a time.. i think a pair may be bad.. though at first i was sure.. but then i stuck the two bad ones back in, no issues.. well almost.. cpu wasnt maxing out as much for some reason.. but things still seemed sluggish.. until i had 2 blue screens in a row with those chips: I had a internal_power_error (0x000000A0) and a uncorrectable hardware error (stop 0x00000124).. so at this point i'm guessing that these 2 chips are definitely bad... as i have the other two in the same two slots and things seem ok at the moment.. the chips also felt very very hot to me, despite their cooling covers... I'm hoping this info may prove useful to someone else.. or if anyone has had similar issues.. let me know how close i am to the real solution.. |
| | Re: horribly slow x64 Vista on existing installation and on fresh ones there is a memory diagnostic available. use Help/Search for info on running it. mikeyhsd@xxxxxx "markm75" <markm75@xxxxxx> wrote in message news:6A7C41F0-FBBA-48E0-A6B6-D5683642E7CD@xxxxxx For the longest time.. ive struggled to figure this one out.. only under x64 vista (sp1 now, probably rtm before).. i have cpu % at 100, svchost.exe (pnp devices and dcom services).. I couldnt figure out why.. i tried a fresh install.. it would even drag to the point where the install would take hours instead of 30 minutes.. Under x86.. no problems.. that harddrive ran fine ; i had been using x64 for the longest time without issues though... My hardware is an asus p5n32-sli se with corsair cm2x1024-6400 1GB chips x 4 (4GB).. i also have an 8600GT and a 7600GT video card. I tried everything, but now i think i'm close to figuring it out.. Its worth noting, that yeah under x86 it ran fine (which i found odd), except that occassionally if memory used hit 76% (say had a lot of tabs open in IE..) i would get out of memory errors.. perhaps this was a clue too.. though i had none of the max cpu issues here.. I went with 2 ram chips at a time.. i think a pair may be bad.. though at first i was sure.. but then i stuck the two bad ones back in, no issues.. well almost.. cpu wasnt maxing out as much for some reason.. but things still seemed sluggish.. until i had 2 blue screens in a row with those chips: I had a internal_power_error (0x000000A0) and a uncorrectable hardware error (stop 0x00000124).. so at this point i'm guessing that these 2 chips are definitely bad... as i have the other two in the same two slots and things seem ok at the moment.. the chips also felt very very hot to me, despite their cooling covers... I'm hoping this info may prove useful to someone else.. or if anyone has had similar issues.. let me know how close i am to the real solution.. |
| | Re: horribly slow x64 Vista on existing installation and on fresh "mikeyhsd" wrote: Quote: > there is a memory diagnostic available. > use Help/Search for info on running it. |
| Vista Ultimate x64 | Re: horribly slow x64 Vista on existing installation and on fresh ones A good first step is to use a memory test application that is bootable. Do one stick at a time. I believe MemTest is the name of one such app. Paul |
| Can Windows Vista Anytime Upgrade DVD do fresh install of an existing version? | General Discussion | |||
| Vista x64 Horribly Choppy and Slow | Vista performance & maintenance | |||
| Old vista still existing after fresh install | Vista installation & setup | |||
| vista is horribly slow today after cleaning my cpu fan. | Vista hardware & devices | |||
| p5n32-sli se deluxe and Vista x64 and 2gb (slow enough) then 4gb (horribly slow issues) | Vista hardware & devices | |||
