Vista - Vista SP1 Remote Desktop Connection issue
Old 03-24-2008   #1 (permalink)
::CORY::
Just installed SP1 on Vista Business here at work and now we are unable to
RDP to a Windows 2000 box that we use.
Is there some new elevated privileges canceling this out that we can disable
and go back to?
Error: Because of a protocol error, this session will be disconnected.
Please try connecting to the remote computer again.
The server is up that I'm telneting too (we have XP machines that reach it
fine) and I can telnet to it from the Vista machine.
Any suggestions?
::CORY::
Old 03-24-2008   #2 (permalink)
Mark L. Ferguson
Re: Vista SP1 Remote Desktop Connection issue
I would hunt for a disabled service, something like RPC.
Was this helpful? Then click the Ratings button. Voting helps the web
interface.
http://www.microsoft.com/wn3/locales...eAPostAsAnswer
Mark L. Ferguson
"::CORY::" <no_ka_oii@xxxxxx> wrote in message
news:C7E29D84-BF6C-448B-882C-CFF146C64AB1@xxxxxx
> disable and go back to?
> Any suggestions?
> ::CORY::
Old 03-24-2008   #3 (permalink)
::CORY::
Didnt help. Made sure both RPC services were started and got the same error.
I am able to remote from the Vista machine to the XP machines just fine.
It's gotta be something with the old version of RDP on the 2000 box.
Maybe a registry entry to make it ignore this check?
::CORY::
"Mark L. Ferguson" <MarkLFerguson@xxxxxx> wrote in
message news:A20C24FE-EAA6-4D5A-98F1-81FF07049E79@xxxxxx
> interface.
> Mark L. Ferguson
>> to RDP to a Windows 2000 box that we use.
>> it fine) and I can telnet to it from the Vista machine.
>> Any suggestions?
>> ::CORY::
Old 03-24-2008   #4 (permalink)
Mark L. Ferguson
I would try running the RDP software from an elevated prompt or the default
admin account.
interface.
Mark L. Ferguson
news:9F53876F-31F5-4578-8DA6-F76A0EFEE2E9@xxxxxx
> error.
> ::CORY::
>> interface.
>> Mark L. Ferguson
>>> Any suggestions?
>>> ::CORY::
Old 03-24-2008   #5 (permalink)
Kerry Brown
> Any suggestions?
I don't think this is the answer but it's worth a try. Try connecting with
the /admin switch which replaces the deprecated /console switch e.g. mstsc
/admin
Kerry Brown
MS-MVP - Windows Desktop Experience: Systems Administration
http://www.vistahelp.ca/phpBB2/
Vista x64 Remote Desktop issue Network & Sharing
Remote Desktop Connection issue Vista networking & sharing
Fixed! Remote Desktop Connection (RDC) SLOW/NO Connection Issue Vista networking & sharing
Remote Desktop Connection Issue Vista General
