| | i have a problem with vista. the problem is that i can't get vista to load. it has told me that winlog.exe is corrupt and that i need to run start up repair. the main problem with this is that windows won't start so i can't run the repair program i have ran the advanced boot options as suggested in the help and support options. i dont see the repair comp option. i have tried every other option, nothing is working. what do i do? and more importantly how do i do it? |
| | Re: i have a problem with vista. "Startup Repair" will be the first option offered on every system. You press F8 during the 'black screen' portion of a restart, right after the BIOS screen. Whatever other options the system maker made available is up to them. You may have been expected to create a backup to restore from. It varies by maker. -- Was this helpful? Then click the Ratings button. Voting helps the web interface. http://www.microsoft.com/wn3/locales...eAPostAsAnswer Mark L. Ferguson .. "the killer klown" <the killer klown@xxxxxx> wrote in message news:82FE60C0-4AFE-4B2F-BC2F-08A8DBBCE11A@xxxxxx Quote: > the problem is that i can't get vista to load. > it has told me that winlog.exe is corrupt and that i need to run start up > repair. the main problem with this is that windows won't start so i can't > run > the repair program i have ran the advanced boot options as suggested in > the > help and support options. i dont see the repair comp option. i have tried > every other option, nothing is working. > > what do i do? and more importantly how do i do it? > > |
| | Re: i have a problem with vista. You will need to boot off of the Vista install DVD. If you don't have the DVD (one didn't come with your computer) you can download the recovery disk at http://neosmart.net/blog/2008/window...disc-download/ Cheers, Chris the killer klown wrote: Quote: > the problem is that i can't get vista to load. > it has told me that winlog.exe is corrupt and that i need to run start up > repair. the main problem with this is that windows won't start so i can't run > the repair program i have ran the advanced boot options as suggested in the > help and support options. i dont see the repair comp option. i have tried > every other option, nothing is working. > > what do i do? and more importantly how do i do it? > > |
| | Re: i have a problem with vista. the options available are:- safe mode safe mode with networking safe mode with comand prompt enable boot logging enable low resolution video last known good config advanced directory service restore mode debugging mode disable automatic restart on system failure disable drive signature enforcement start windows normally --- none of these options work on running safe modes the last thing to load is drivers/crcdisk.sys when it gets this far it stops and won't go any further........... so the question still stands what do i do? and how? |
| | Re: i have a problem with vista. You should probably seek local help with understanding how your system can boot to a startup disk. -- Mark L. Ferguson .. "the killer klown" <thekillerklown@xxxxxx> wrote in message news:8839BA94-C5F6-459D-83B7-5084FE8F0799@xxxxxx Quote: > the options available are:- > > safe mode > safe mode with networking > safe mode with comand prompt > > enable boot logging > enable low resolution video > last known good config advanced > directory service restore mode > debugging mode > disable automatic restart on system failure > disable drive signature enforcement > > start windows normally > > > --- none of these options work > on running safe modes the last thing to load is drivers/crcdisk.sys > > when it gets this far it stops and won't go any further........... > > so the question still stands what do i do? and how? |
| I have problem starting up Vista - problem with driver | Drivers | |||
| Vista problem, or keyboard problem? | Vista General | |||
| Generic McAfee Problem Message in Vista Problem Reports | Vista performance & maintenance | |||
| Vista Sleep Problem / Network Problem | Vista networking & sharing | |||
| Vista Upgrade Problem - Windows Explorer Loop problem | Vista installation & setup | |||
