| | Vista - Shadow Copy issue |
| 03-26-2008 | #1 |
| | Shadow Copy issue Hi, I made this test.. 1) Created a folder called test 2) Folder is saved on desktop 3) Made a system restore at this point 4) Deleted the test folder from desktop and removed from recycle bin 5) Tried to restore a shadow copy, but none is available What is wrong? I have Vista Ultimate (danish) no SP1 yet Regards -- Intel E8400 C2D 3.0 GForce 8600 GTS 512 2GB DDR2 6400 WD 80GB Vista Ultimate (danish) |
| My System Specs |
| 03-26-2008 | #2 |
| | Re: Shadow Copy issue Hi, I made this test.. 1) Created a folder called test 2) Folder is saved on desktop 3) Made a system restore at this point 4) Deleted the test folder from desktop and removed from recycle bin 5) Tried to restore a shadow copy, but none is available What is wrong? I have Vista Ultimate (danish) no SP1 yet Regards -- Intel E8400 C2D 3.0 GForce 8600 GTS 512 2GB DDR2 6400 WD 80GB Vista Ultimate (danish) Shadow Copies doesn't work like that. If you accidentally overwrite a file, right-click on the file, then select "Restore Previous Verions". In the case of a deleted file, right-click on the folder that contained the file. |
| My System Specs |
| 03-26-2008 | #3 |
| | Re: Shadow Copy issue The issue is that there are no "previous versions" Neither changing the content, deleting or overwrite a folder, made "previous versions" available. In my test after deleting the folder, after making a restore point, and trying to retrieve it again from "previous versions" did not work. Example a subfolder folder called "test", saved in my documents folder and accidentally deleted after restore point could not be restored as shadow copy. If you have a suggestion about how to perform such a test, please let me know. Regards -- Intel E8400 C2D 3.0 GForce 8600 GTS 512 2GB DDR2 6400 WD 80GB Vista Ultimate (danish) "Dzomlija" wrote: Quote: > > bimbobo;662771 Wrote: Quote: > > Hi, > > I made this test.. > > > > 1) Created a folder called test > > 2) Folder is saved on desktop > > 3) Made a system restore at this point > > 4) Deleted the test folder from desktop and removed from recycle bin > > 5) Tried to restore a shadow copy, but none is available > > What is wrong? > > I have Vista Ultimate (danish) no SP1 yet > > Regards > > -- > > Intel E8400 C2D 3.0 > > GForce 8600 GTS 512 > > 2GB DDR2 6400 > > WD 80GB > > Vista Ultimate (danish) > How did you try to restore this shadow copy? By restoring back to a > point prior to the restore point you created? > > Shadow Copies doesn't work like that. If you accidentally overwrite a > file, right-click on the file, then select "Restore Previous Verions". > In the case of a deleted file, right-click on the folder that contained > the file. > > > -- > Dzomlija > > Peter Alexander Dzomlija > -Do you hear, huh? The Alpha and The Omega? Death and Rebirth? And as > you die, so shall I be Reborn...- > > _*Prometheus*_ > MOBO: ASUS MB-M3A32-MVP Deluxe/WiFi-AP > CPU: AMD Phenom 9600 Quad > RAM: 2 x A-Data 2GB DDR2-800 > GPU: ASUS ATI Radeon HD 2400PRO, 256MB > BOX: Thermaltake Tai-Chi Water Cooled > OS: Windows Vista Ultimate x64 > '' (http://valid.x86-secret.com/show_oc.php?id=333562)'[image: > http://valid.x86-secret.com/cache/banner/333562.png]' > (http://valid.x86-secret.com/cache/banner/333562.png) > |
| My System Specs |
| 03-27-2008 | #4 |
| | Re: Shadow Copy issue Where are you looking for/how are you trying to invoke "Previous Versions"? It should be a tab on file or folder properties; it isn't AFAIK a context menu/right-click thing for example. Lookin in the normally hidden system folder "System Volume Information" - could you list the file you see there with their sizes? I suspect there will be files if creating a System Restore point was reported as successful... if so the question remains how to get at them. If we knew e.g. the properties tab was missing that would be a start... -- Julian I-Do-Stuff Some Vista stuff, but mostly just Stuff at http://berossus,blogspot.com "bimbobo" <bimbobo@xxxxxx> wrote in message news:66FD58D2-78F0-4B6F-B4BE-A5EE7C2B2610@xxxxxx Quote: > The issue is that there are no "previous versions" > Neither changing the content, deleting or overwrite a folder, made > "previous > versions" available. > In my test after deleting the folder, after making a restore point, and > trying to retrieve it again from "previous versions" did not work. > Example a subfolder folder called "test", saved in my documents folder and > accidentally deleted after restore point could not be restored as shadow > copy. > > If you have a suggestion about how to perform such a test, please let me > know. > Regards > > -- > Intel E8400 C2D 3.0 > GForce 8600 GTS 512 > 2GB DDR2 6400 > WD 80GB > Vista Ultimate (danish) > > > "Dzomlija" wrote: > Quote: >> >> bimbobo;662771 Wrote: Quote: >> > Hi, >> > I made this test.. >> > >> > 1) Created a folder called test >> > 2) Folder is saved on desktop >> > 3) Made a system restore at this point >> > 4) Deleted the test folder from desktop and removed from recycle bin >> > 5) Tried to restore a shadow copy, but none is available >> > What is wrong? >> > I have Vista Ultimate (danish) no SP1 yet >> > Regards >> > -- >> > Intel E8400 C2D 3.0 >> > GForce 8600 GTS 512 >> > 2GB DDR2 6400 >> > WD 80GB >> > Vista Ultimate (danish) >> How did you try to restore this shadow copy? By restoring back to a >> point prior to the restore point you created? >> >> Shadow Copies doesn't work like that. If you accidentally overwrite a >> file, right-click on the file, then select "Restore Previous Verions". >> In the case of a deleted file, right-click on the folder that contained >> the file. >> >> >> -- >> Dzomlija >> >> Peter Alexander Dzomlija >> -Do you hear, huh? The Alpha and The Omega? Death and Rebirth? And as >> you die, so shall I be Reborn...- >> >> _*Prometheus*_ >> MOBO: ASUS MB-M3A32-MVP Deluxe/WiFi-AP >> CPU: AMD Phenom 9600 Quad >> RAM: 2 x A-Data 2GB DDR2-800 >> GPU: ASUS ATI Radeon HD 2400PRO, 256MB >> BOX: Thermaltake Tai-Chi Water Cooled >> OS: Windows Vista Ultimate x64 >> '' (http://valid.x86-secret.com/show_oc.php?id=333562)'[image: >> http://valid.x86-secret.com/cache/banner/333562.png]' >> (http://valid.x86-secret.com/cache/banner/333562.png) >> |
| My System Specs |
| 03-27-2008 | #5 |
| | Re: Shadow Copy issue I will send a list from home... -- Intel E8400 C2D 3.0 GForce 8600 GTS 512 2GB DDR2 6400 WD 80GB Vista Ultimate (danish) "Julian" wrote: Quote: > Where are you looking for/how are you trying to invoke "Previous Versions"? > > It should be a tab on file or folder properties; it isn't AFAIK a context > menu/right-click thing for example. > > Lookin in the normally hidden system folder "System Volume Information" - > could you list the file you see there with their sizes? I suspect there will > be files if creating a System Restore point was reported as successful... > if so the question remains how to get at them. If we knew e.g. the > properties tab was missing that would be a start... > > -- > Julian I-Do-Stuff > > Some Vista stuff, but mostly just Stuff at http://berossus,blogspot.com > > > > "bimbobo" <bimbobo@xxxxxx> wrote in message > news:66FD58D2-78F0-4B6F-B4BE-A5EE7C2B2610@xxxxxx Quote: > > The issue is that there are no "previous versions" > > Neither changing the content, deleting or overwrite a folder, made > > "previous > > versions" available. > > In my test after deleting the folder, after making a restore point, and > > trying to retrieve it again from "previous versions" did not work. > > Example a subfolder folder called "test", saved in my documents folder and > > accidentally deleted after restore point could not be restored as shadow > > copy. > > > > If you have a suggestion about how to perform such a test, please let me > > know. > > Regards > > > > -- > > Intel E8400 C2D 3.0 > > GForce 8600 GTS 512 > > 2GB DDR2 6400 > > WD 80GB > > Vista Ultimate (danish) > > > > > > "Dzomlija" wrote: > > Quote: > >> > >> bimbobo;662771 Wrote: > >> > Hi, > >> > I made this test.. > >> > > >> > 1) Created a folder called test > >> > 2) Folder is saved on desktop > >> > 3) Made a system restore at this point > >> > 4) Deleted the test folder from desktop and removed from recycle bin > >> > 5) Tried to restore a shadow copy, but none is available > >> > What is wrong? > >> > I have Vista Ultimate (danish) no SP1 yet > >> > Regards > >> > -- > >> > Intel E8400 C2D 3.0 > >> > GForce 8600 GTS 512 > >> > 2GB DDR2 6400 > >> > WD 80GB > >> > Vista Ultimate (danish) > >> > >> How did you try to restore this shadow copy? By restoring back to a > >> point prior to the restore point you created? > >> > >> Shadow Copies doesn't work like that. If you accidentally overwrite a > >> file, right-click on the file, then select "Restore Previous Verions". > >> In the case of a deleted file, right-click on the folder that contained > >> the file. > >> > >> > >> -- > >> Dzomlija > >> > >> Peter Alexander Dzomlija > >> -Do you hear, huh? The Alpha and The Omega? Death and Rebirth? And as > >> you die, so shall I be Reborn...- > >> > >> _*Prometheus*_ > >> MOBO: ASUS MB-M3A32-MVP Deluxe/WiFi-AP > >> CPU: AMD Phenom 9600 Quad > >> RAM: 2 x A-Data 2GB DDR2-800 > >> GPU: ASUS ATI Radeon HD 2400PRO, 256MB > >> BOX: Thermaltake Tai-Chi Water Cooled > >> OS: Windows Vista Ultimate x64 > >> '' (http://valid.x86-secret.com/show_oc.php?id=333562)'[image: > >> http://valid.x86-secret.com/cache/banner/333562.png]' > >> (http://valid.x86-secret.com/cache/banner/333562.png) > >> > |
| My System Specs |
| 03-27-2008 | #6 |
| | Re: Shadow Copy issue Hi, I have 17 files for a total of 2.54GB So there are "restore points" there, at least -- Intel E8400 C2D 3.0 GForce 8600 GTS 512 2GB DDR2 6400 WD 80GB Vista Ultimate (danish) "Julian" wrote: Quote: > Where are you looking for/how are you trying to invoke "Previous Versions"? > > It should be a tab on file or folder properties; it isn't AFAIK a context > menu/right-click thing for example. > > Lookin in the normally hidden system folder "System Volume Information" - > could you list the file you see there with their sizes? I suspect there will > be files if creating a System Restore point was reported as successful... > if so the question remains how to get at them. If we knew e.g. the > properties tab was missing that would be a start... > > -- > Julian I-Do-Stuff > > Some Vista stuff, but mostly just Stuff at http://berossus,blogspot.com > > > > "bimbobo" <bimbobo@xxxxxx> wrote in message > news:66FD58D2-78F0-4B6F-B4BE-A5EE7C2B2610@xxxxxx Quote: > > The issue is that there are no "previous versions" > > Neither changing the content, deleting or overwrite a folder, made > > "previous > > versions" available. > > In my test after deleting the folder, after making a restore point, and > > trying to retrieve it again from "previous versions" did not work. > > Example a subfolder folder called "test", saved in my documents folder and > > accidentally deleted after restore point could not be restored as shadow > > copy. > > > > If you have a suggestion about how to perform such a test, please let me > > know. > > Regards > > > > -- > > Intel E8400 C2D 3.0 > > GForce 8600 GTS 512 > > 2GB DDR2 6400 > > WD 80GB > > Vista Ultimate (danish) > > > > > > "Dzomlija" wrote: > > Quote: > >> > >> bimbobo;662771 Wrote: > >> > Hi, > >> > I made this test.. > >> > > >> > 1) Created a folder called test > >> > 2) Folder is saved on desktop > >> > 3) Made a system restore at this point > >> > 4) Deleted the test folder from desktop and removed from recycle bin > >> > 5) Tried to restore a shadow copy, but none is available > >> > What is wrong? > >> > I have Vista Ultimate (danish) no SP1 yet > >> > Regards > >> > -- > >> > Intel E8400 C2D 3.0 > >> > GForce 8600 GTS 512 > >> > 2GB DDR2 6400 > >> > WD 80GB > >> > Vista Ultimate (danish) > >> > >> How did you try to restore this shadow copy? By restoring back to a > >> point prior to the restore point you created? > >> > >> Shadow Copies doesn't work like that. If you accidentally overwrite a > >> file, right-click on the file, then select "Restore Previous Verions". > >> In the case of a deleted file, right-click on the folder that contained > >> the file. > >> > >> > >> -- > >> Dzomlija > >> > >> Peter Alexander Dzomlija > >> -Do you hear, huh? The Alpha and The Omega? Death and Rebirth? And as > >> you die, so shall I be Reborn...- > >> > >> _*Prometheus*_ > >> MOBO: ASUS MB-M3A32-MVP Deluxe/WiFi-AP > >> CPU: AMD Phenom 9600 Quad > >> RAM: 2 x A-Data 2GB DDR2-800 > >> GPU: ASUS ATI Radeon HD 2400PRO, 256MB > >> BOX: Thermaltake Tai-Chi Water Cooled > >> OS: Windows Vista Ultimate x64 > >> '' (http://valid.x86-secret.com/show_oc.php?id=333562)'[image: > >> http://valid.x86-secret.com/cache/banner/333562.png]' > >> (http://valid.x86-secret.com/cache/banner/333562.png) > >> > |
| My System Specs |
| 03-27-2008 | #7 |
| | Re: Shadow Copy issue Hi, I have 17 files in this folder and a total of 2.54Gb So now we knoe there are restore points -- Intel E8400 C2D 3.0 GForce 8600 GTS 512 2GB DDR2 6400 WD 80GB Vista Ultimate (danish) "bimbobo" wrote: Quote: > I will send a list from home... > -- > Intel E8400 C2D 3.0 > GForce 8600 GTS 512 > 2GB DDR2 6400 > WD 80GB > Vista Ultimate (danish) > > > "Julian" wrote: > Quote: > > Where are you looking for/how are you trying to invoke "Previous Versions"? > > > > It should be a tab on file or folder properties; it isn't AFAIK a context > > menu/right-click thing for example. > > > > Lookin in the normally hidden system folder "System Volume Information" - > > could you list the file you see there with their sizes? I suspect there will > > be files if creating a System Restore point was reported as successful... > > if so the question remains how to get at them. If we knew e.g. the > > properties tab was missing that would be a start... > > > > -- > > Julian I-Do-Stuff > > > > Some Vista stuff, but mostly just Stuff at http://berossus,blogspot.com > > > > > > > > "bimbobo" <bimbobo@xxxxxx> wrote in message > > news:66FD58D2-78F0-4B6F-B4BE-A5EE7C2B2610@xxxxxx Quote: > > > The issue is that there are no "previous versions" > > > Neither changing the content, deleting or overwrite a folder, made > > > "previous > > > versions" available. > > > In my test after deleting the folder, after making a restore point, and > > > trying to retrieve it again from "previous versions" did not work. > > > Example a subfolder folder called "test", saved in my documents folder and > > > accidentally deleted after restore point could not be restored as shadow > > > copy. > > > > > > If you have a suggestion about how to perform such a test, please let me > > > know. > > > Regards > > > > > > -- > > > Intel E8400 C2D 3.0 > > > GForce 8600 GTS 512 > > > 2GB DDR2 6400 > > > WD 80GB > > > Vista Ultimate (danish) > > > > > > > > > "Dzomlija" wrote: > > > > > >> > > >> bimbobo;662771 Wrote: > > >> > Hi, > > >> > I made this test.. > > >> > > > >> > 1) Created a folder called test > > >> > 2) Folder is saved on desktop > > >> > 3) Made a system restore at this point > > >> > 4) Deleted the test folder from desktop and removed from recycle bin > > >> > 5) Tried to restore a shadow copy, but none is available > > >> > What is wrong? > > >> > I have Vista Ultimate (danish) no SP1 yet > > >> > Regards > > >> > -- > > >> > Intel E8400 C2D 3.0 > > >> > GForce 8600 GTS 512 > > >> > 2GB DDR2 6400 > > >> > WD 80GB > > >> > Vista Ultimate (danish) > > >> > > >> How did you try to restore this shadow copy? By restoring back to a > > >> point prior to the restore point you created? > > >> > > >> Shadow Copies doesn't work like that. If you accidentally overwrite a > > >> file, right-click on the file, then select "Restore Previous Verions". > > >> In the case of a deleted file, right-click on the folder that contained > > >> the file. > > >> > > >> > > >> -- > > >> Dzomlija > > >> > > >> Peter Alexander Dzomlija > > >> -Do you hear, huh? The Alpha and The Omega? Death and Rebirth? And as > > >> you die, so shall I be Reborn...- > > >> > > >> _*Prometheus*_ > > >> MOBO: ASUS MB-M3A32-MVP Deluxe/WiFi-AP > > >> CPU: AMD Phenom 9600 Quad > > >> RAM: 2 x A-Data 2GB DDR2-800 > > >> GPU: ASUS ATI Radeon HD 2400PRO, 256MB > > >> BOX: Thermaltake Tai-Chi Water Cooled > > >> OS: Windows Vista Ultimate x64 > > >> '' (http://valid.x86-secret.com/show_oc.php?id=333562)'[image: > > >> http://valid.x86-secret.com/cache/banner/333562.png]' > > >> (http://valid.x86-secret.com/cache/banner/333562.png) > > >> > > |
| My System Specs |
| Similar Threads for: Shadow Copy issue | ||||
| Shadow Copy | Server General | |||
| about shadow copy | Vista General | |||
| Shadow Copy: Force Copy Creation? | Vista General | |||
| Shadow Copy Bug?! | Vista General | |||
