Vista - USB "Gigabank" 8 gig portable device not found
Old 03-28-2008   #1 (permalink)
jrmartinez23
I've tried disk management, I've tried disabling all my usb ports, I still
have no answers.
When I first go this device, it worked. No problems. After I removed it
from my system and plugged it back in a few days later, it doesn't work. I
think?
You can hear the USB chime, but nothing ever shows up. If I look in disk
management, it appears something is there, but when i right click it I only
get the "help" option, unlike the other disks that let me assign drive
letters and what have you.
Any Suggestions?
"Disable" or "Uninstall" a device in Device Manager? Vista General
error code 39 on all device type: "Modems" & "Ports (COM & LPT)" Vista hardware & devices
LightScribe Drive/Device "Not Found" General Discussion
Re: Problem with Hyper-V, NCQ SATA drives; Event ID 129 from nvstor64 saying "Reset to device, \Device\RaidPort0, was issued". Virtual Server
