Vista - missing live file system and mastered system
Old 03-28-2008   #1 (permalink)
Tenny
i want to burn my home pictures on to a cd. When I put the writeable cd into
the drive it doesnt recognize it. It does nothing?
Old 03-28-2008   #2 (permalink)
~Alex T.~A.K.A. Makaveli213~
RE: missing live file system and mastered system
This could be because you have your autorun action set to take no action.
Are you using something like Nero to burn these pictures? If so they blank
should be recognzied by the application when you go to burn.
Mastered File System not available in Vista Ultimate Vista General
Mastered File System not available for CD burning Vista installation & setup
Make Mastered File System default when Burning CD in Vista Vista General
CD Burning - Mastered or live File system Vista General
Missing System File Vista file management
