Still have a problem with asx/asf files
  1. #1
    Don Harvey Guest
    This problem is driving me crazy. About 10 days ago this HP machine with
    Vista Premium will no longer load asx files. I have tested the links on my
    XP machines with no problem. I have not installed any new programs so I
    assume that one of the automatic updates changed something in the system.
    Google search has not given an answer.
    Thanks for any help to solve this.
  2. #2
    dev Guest
    Re: Still have a problem with asx/asf files
    When looking at START menu|DEFAULT PROGRAMS - the top two items...
    Is WMPlayer shown as handling, and being associated with .asx?
  3. #3
    Don Harvey Guest
    Yes, just double checked, the file association for both asx and asf is
    WMPlayer. It is very strange. I even did a System Restore to about 2 weeks
    back and the problem still persists.
    <dev@xxxxxx> wrote in message
    news:%23e0dS$skIHA.3400@xxxxxx
    >> my
  4. #4
    John Barnes Guest
    If you think that one of the automatic updates caused your problem, go to
    installed updates and uninstall all updates since your problem started. If
    that fixes the problem, install them one by one until you find the problem
    one. There has only been 1 update on my compute since 3/13.
    Sadly I don't think this will help, but it will eliminate your assumption.
    You probably would be wise to try System Restore. It is easily reversible
    if it doesn't solve the problem.
    "Don Harvey" <dharvey@xxxxxx> wrote in message
    news:47f03761$0$30715$4c368faf@xxxxxx
    > my
  5. #5
    zachd [MSFT] Guest
    What protocols are listed under WMP's Tools:Options:Network menu tab?
    This sounds like your networking folder has become corrupted - it's easy to
    fix. The symptom would be that the box in that menu tab would be empty. =\
    Speaking for myself only.
    See http://zachd.com/pss/pss.html for some helpful WMP info.
    > my
Still have a problem with asx/asf files problems?
OT: Problem with PDF files Rob Vista General 3 23 Sep 2009
New Files Problem BigE Vista networking & sharing 0 16 Dec 2008
problem with RAR files sahitanand Vista General 7 18 Feb 2008
Problem with txt files talkinggoat Vista General 1 11 Jul 2007
Odd problem with .ini files SonnySee Vista General 2 30 Apr 2007
