| | Rightclick problem after SP1 T7700, Business This problem arose since SP1, and persists after previous advice. It's the only issue amid several benefits, so I would like to fix it rather than roll back. When rightclicking a desktop icon, I'll sometimes get nothing. Rightclicking again produces a NOT RESPONDING and then a white Explorer reboot. Then all is well... until next time. It's unpredictable -- I cannot define the circumstances that will reliably cause the problem. SFC /scannow in safe mode found zero faults. Various malware checks found nothing. There are no other problems (it runs great!). I installed the ShellExView tool but learned little and solved nothing. Any ideas? Ike PS - please don't suggest changing my OS. Those whose hobby is Linux probably don't use a computer in their job, because most professions (including mine) require apps that run on another OS. |
| Windows 7 RC | Re: Rightclick problem after SP1 T7700, Business This problem arose since SP1, and persists after previous advice. It's the only issue amid several benefits, so I would like to fix it rather than roll back. When rightclicking a desktop icon, I'll sometimes get nothing. Rightclicking again produces a NOT RESPONDING and then a white Explorer reboot. Then all is well... until next time. It's unpredictable -- I cannot define the circumstances that will reliably cause the problem. SFC /scannow in safe mode found zero faults. Various malware checks found nothing. There are no other problems (it runs great!). I installed the ShellExView tool but learned little and solved nothing. Any ideas? Ike PS - please don't suggest changing my OS. Those whose hobby is Linux probably don't use a computer in their job, because most professions (including mine) require apps that run on another OS. Sounds like you've tried many things to resolve the issues. Maybe do a hand off to the gurus at Microsoft and see if they can fix them for you. They are giving customers free tech support for SP1. Here's the link: https://support.microsoft.com/oas/de...4&gprid=500921 |
| | Re: Rightclick problem after SP1 Right-click is slow or weird behavior caused by context menu handlers http://windowsxp.mvps.org/slowrightclick.htm -- Carey Frisch Microsoft MVP Windows Desktop Experience - Windows System & Performance --------------------------------------------------------------- "e" <binarydotike@xxxxxx> wrote in message news:fstgca$dt3$1@xxxxxx T7700, Business This problem arose since SP1, and persists after previous advice. It's the only issue amid several benefits, so I would like to fix it rather than roll back. When rightclicking a desktop icon, I'll sometimes get nothing. Rightclicking again produces a NOT RESPONDING and then a white Explorer reboot. Then all is well... until next time. It's unpredictable -- I cannot define the circumstances that will reliably cause the problem. SFC /scannow in safe mode found zero faults. Various malware checks found nothing. There are no other problems (it runs great!). I installed the ShellExView tool but learned little and solved nothing. Any ideas? Ike PS - please don't suggest changing my OS. Those whose hobby is Linux probably don't use a computer in their job, because most professions (including mine) require apps that run on another OS. |
| | Re: Rightclick problem after SP1 Carey Frisch [MVP] wrote: Quote: > Right-click is slow or weird behavior caused by context menu handlers > http://windowsxp.mvps.org/slowrightclick.htm > > I'll give it another try, as I may well have missed something last time. There are some items listed in the Context Menu column that really don't seem to belong there... If it's not found I'll go to Microsoft with my hat in hand. Thanks to both of you. Ike |
| | Re: Rightclick problem after SP1 e wrote: Quote: > Carey Frisch [MVP] wrote: Quote: >> Right-click is slow or weird behavior caused by context menu handlers >> http://windowsxp.mvps.org/slowrightclick.htm >> >> > > I'll give it another try, as I may well have missed something last time. > > There are some items listed in the Context Menu column that really don't > seem to belong there... > > If it's not found I'll go to Microsoft with my hat in hand. > > Thanks to both of you. > > Ike non-Microsoft Context Menu items. The problem persists. Rightclick on a desktop icon, see the spinning blue ring, click again and watch Explorer die. It happens once or twice for each boot, and not at any predictable time. At some point, the problem dies and the unit functions properly. If no one has other ideas, perhaps the next step is Microsoft. This should be interesting... Ike |
| | #6 (permalink) |
| | Re: Rightclick problem after SP1 Checked the Event logs for any clue? It might reveal the module name that crashed explorer.exe. -- Regards, Ramesh Srinivasan, Microsoft MVP [Windows Shell/User] Windows® Troubleshooting http://www.winhelponline.com Winhelponline.com blog http://www.winhelponline.com/blog "e" <binarydotike@xxxxxx> wrote in message news:ft02n1$1g5$1@xxxxxx e wrote: Quote: > Carey Frisch [MVP] wrote: Quote: >> Right-click is slow or weird behavior caused by context menu handlers >> http://windowsxp.mvps.org/slowrightclick.htm >> >> > > I'll give it another try, as I may well have missed something last time. > > There are some items listed in the Context Menu column that really don't > seem to belong there... > > If it's not found I'll go to Microsoft with my hat in hand. > > Thanks to both of you. > > Ike non-Microsoft Context Menu items. The problem persists. Rightclick on a desktop icon, see the spinning blue ring, click again and watch Explorer die. It happens once or twice for each boot, and not at any predictable time. At some point, the problem dies and the unit functions properly. If no one has other ideas, perhaps the next step is Microsoft. This should be interesting... Ike |
| | #7 (permalink) |
| | Re: Rightclick problem after SP1 Ramesh, MS-MVP wrote: Quote: > Checked the Event logs for any clue? It might reveal the module name that crashed explorer.exe. > |
| | #8 (permalink) |
| | Re: Rightclick problem after SP1 Windows Vista Help: What information appears in event logs? (Event Viewer): http://windowshelp.microsoft.com/Win...dfa4f1033.mspx -- Regards, Ramesh Srinivasan, Microsoft MVP [Windows Shell/User] Windows® Troubleshooting http://www.winhelponline.com Winhelponline.com blog http://www.winhelponline.com/blog "e" <binarydotike@xxxxxx> wrote in message news:ft08u1$7b6$1@xxxxxx Ramesh, MS-MVP wrote: Quote: > Checked the Event logs for any clue? It might reveal the module name that crashed explorer.exe. > |
| | #9 (permalink) |
| | Re: Rightclick problem after SP1 Thank you. I examined the Event Viewer, but remain confused. There is a river of information there, and I'm probably looking for a single drop of dirty water. Next step is to call Microsoft... Ike Ramesh, MS-MVP wrote: Quote: > Windows Vista Help: What information appears in event logs? (Event Viewer): > http://windowshelp.microsoft.com/Win...dfa4f1033.mspx > |
| | #10 (permalink) |
| Bookmark!!! There's no add bookmark when I rightclick the bar in I | .NET General | |||
| Rightclick > Send To > Mail Recipient | Vista mail | |||
| no desktop icons yes taskbar yes rightclick | Vista General | |||
| RightClick Error | Vista General | |||
| Vista Upgrade Problem - Windows Explorer Loop problem | Vista installation & setup | |||
