Vista - Drowning in Tasks - Help?
Old 04-01-2008   #1 (permalink)
Julian
Vista HP, SP1
I rebooted my system at about 18:30 and it's now 22:30 and now I have 47
separate Taskeng.exe processes running - need help in stopping them from
mutliplying further!
I can't tell from the Process tab of the Task Manager what the taskeng.exe
processes refer to, and the Task Scheduler says there are only 8 running
tasks.
There are 5 tasks that I created myself and know about, and they all say
under Settings "Don't start a new instance" if already running. I can find
all these tasks in the Process Tab of the Task Manager via the Process ID,
where I see that the apps they started appear in the Image Name column
(rather than as taskeng.exe processes).
In trying to work out the rest I looked at the "Command Line" column of Task
Manager Processes which shows that each taskeng.exe has a long {hex}code
assocaited with it - the {HEX} being what I assume are GUID's of some
description but since they don't correspond to the "Correlation ID" codes
in the Task Scheduler "History" I'm lost...
Can anyone suggest how to work out what is going on or how to stop the
endless multiplication of tasks?
TIA
Julian I-Do-Stuff
Some Vista stuff, but mostly just Stuff at http://berossus,blogspot.com
Old 04-01-2008   #2 (permalink)
Julian
Re: Drowning in Tasks - Help?
Aha! Looks like a buglet from RC1 that leaked through into SP1 proper...
(corrupt User_Feed_Synchronisation)...
The answer is here
http://forums.microsoft.com/TechNet/...7879&SiteID=17
Thanks to the guys there for sorting this one out...
"Julian" <msforums@xxxxxx> wrote in message
news:eDohtlDlIHA.4076@xxxxxx
Quote:
> Vista HP, SP1
> tasks.
> Task Manager Processes which shows that each taskeng.exe has a long
> {hex}code assocaited with it - the {HEX} being what I assume are GUID's of
> some description but since they don't correspond to the "Correlation ID"
> codes in the Task Scheduler "History" I'm lost...
> TIA
> Julian I-Do-Stuff
Julian I-Do-Stuff
Old 04-01-2008   #3 (permalink)
NoStop
Julian wrote:
Quote:
> Vista HP, SP1
Are you suggesting that Vista is a virus?
Cheers.
A US president declared war on poverty. Poverty won.
Another US president declared a war on drugs. Drugs won.
This US president declared a war on terror. Terror won.
Next?
Old 04-02-2008   #4 (permalink)
Julian
"NoStop" <nospam@xxxxxx> wrote in message
news:fsunf262uug@xxxxxx
Quote:
> Julian wrote:
Quote:
>> Vista HP, SP1
> Cheers.
LOL.... but Hmmmm... it's not actually a living thing and it can't actually
reproduce without external "machinery". Possibly.
From another perspective though, propagating errors in self-reproducing and
self-modifying code without adequate error-checking and combined with
inadequate apoptotic protection leading to eventual collapse of the whole
organism suggest familial carcinoma.
"Vista SP1 Prone to Cancer" might be a closer <g>
Julian I-Do-Stuff
Old 04-02-2008   #5 (permalink)
NoStop
Quote:
>> Julian wrote:
Quote:
>>> Vista HP, SP1
>> Cheers.
> actually reproduce without external "machinery". Possibly.
> and self-modifying code without adequate error-checking and combined with
Vista is a cancer. Ask anyone why their hard drive gets filled up so
quickly.
Cheers.
Next?
Old 04-02-2008   #6 (permalink)
Julian
news:ft07ma325nd@xxxxxx
Quote:
Quote:
>>> Julian wrote:
>>>> Vista HP, SP1
>>>> 47
>>>> from
>>> Cheers.
> quickly.
That's not cancer, that's just subcutaneous fat... stop buying pizzas for
Vista
Julian I-Do-Stuff
WLM Tasks Live Mail
Tasks Vista mail
Why do i get tasks that i know nothing about?? VB Script
scheduled tasks with WMP or MCE Vista General
Tasks GONE from Task Bar!! Vista General
